Manage a multi-admin-verify rule
Use these APIs to access and manage multi-admin verification rules that protect specific ONTAP operations. These rules require approval from multiple administrators before executing certain commands, enhancing security and control within your system.
Overview
These APIs provide information about a specific multi-admin verification rule.
Rules define the ONTAP commands (operations) that should be protected by multi-admin approval.
While the feature is turned on, any ONTAP operation that is defined with a rule will be enforced with multi-admin approval to execute the command (operation).
Retrieving a multi-admin-verify rule
Displays information about a specific multi admin verification rule.
# The API:
/api/security/multi-admin-verify/rules/{owner.uuid}/{operation}
# The call:
curl -X GET "https://<cluster-ip>/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/volume+delete"
# The response:
"owner": {
"uuid": "52b75787-7011-11ec-a23d-005056a78fd5",
"name": "cluster1",
"href": "/api/svm/svms/52b75787-7011-11ec-a23d-005056a78fd5"
"operation": "volume delete",
"auto_request_create": true,
"query": "-vserver vs0",
"required_approvers": 1,
"create_time": "2022-01-07T22:14:03-05:00",
"system_defined": false,
"href": "/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/volume+delete"
Updating a multi-admin-verify rule
Modifies the attributes of the rule.
# The API:
# The call:
curl -X PATCH "https://<cluster-ip>/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/volume+delete" -d '{"required_approvers": 1}'
Deleting a multi-admin-verify rule
Deletes the specified approval group.
# The API:
# The call:
curl -X DELETE "https://<cluster-ip>/api/security/multi-admin-verify/rules/52b75787-7011-11ec-a23d-005056a78fd5/volume+delete"
