ONTAP REST API Security endpoints
Use ONTAP security endpoints to manage security settings for clusters and SVMs. These endpoints help configure authentication protocols such as SAML, integrating third-party identity providers for enhanced security measures.
Overview
You can use ONTAP security APIs to manage security settings for the cluster and SVMs.
SAML
Configure the SAML 2.0 SP (Service Provider) protocol inside ONTAP. Doing so redirects the authentication task to a third-party Identity Provider (IDP) that can utilize any number of approaches for multi-factor authentication. After SAML authentication is enabled, all interactive web access (System Manager, SPI) is authenticated via SAML and a third-party IDP.
