REST API reference
View a WebAuthn global setting entry
Overview
This API endpoint retrieves WebAuthn global settings for the cluster or SVM. Specify the owner UUID and the unique identifier for the cluster or SVM to retrieve the WebAuthn global settings for the cluster or SVM. The PATCH method is used to update relying party domains of the cluster. Only the 'rp_domains' parameter can be modified. Modification of other parameters is not supported.
Retrieving the WebAuthn global settings for the cluster or SVM
# The API:
GET "/api/security/webauthn/global-settings/{owner.uuid}"
# The call:
curl https://<mgmt-ip>/api/security/webauthn/global-settings/d49de271-8c11-11e9-8f78-005056bbf6ac
Modifying the relying party domain list for a cluster or SVM
# The API:
PATCH "/api/security/webauthn/global-settings/{owner.uuid}"
# The call:
curl -X PATCH https://<mgmt-ip>/api/security/webauthn/global-settings/d49de271-8c11-11e9-8f78-005056bbf6ac -d '{"rp_domains": ["example.com"]}'
