ONTAP REST API storage cluster metrics endpoints
Overview
Retrieves cluster-wide historical capacity metrics.
Retrieving cluster-wide historical space metrics for the past day
# The API:
/api/storage/cluster/metrics
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/cluster/metrics?interval=1d&fields=**" -H "accept: application/hal+json"
# The response:
Snipped most of the records
"records": [
"uuid": "03ca3ef6-8173-11ef-825d-005056bb2d85",
"timestamp": "2024-10-07T03:17:45Z",
"status": "ok",
"duration": "PT15S",
"available_space": 862216192,
"used_space": 1810432,
"size": 864026624,
"href": "/api/storage/cluster/metrics/2024-10-07T03%3A17%3A45Z?fields=**"
"timestamp": "2024-10-07T02:18:00Z",
"status": "partial_no_data",
"available_space": 0,
"used_space": 0,
"size": 0,
"href": "/api/storage/cluster/metrics/2024-10-07T02%3A18%3A00Z?fields=**"
"num_records": 240,
"href": "/api/storage/cluster/metrics?fields=**"
Retrieving historical metrics within a time range defined by timestamp
curl -X GET "https://<mgmt-ip>/api/storage/cluster/metrics?fields=**×tamp=2024-10-07T03:36:45Z..2024-10-07T03:36:30Z" -H "accept: application/hal+json"
#### Response:
"records": [
"timestamp": "2024-10-07T03:36:45Z",
"status": "ok",
"available_space": 862183424,
"used_space": 1843200,
"size": 864026624,
"href": "/api/storage/cluster/metrics/2024-10-07T03%3A36%3A45Z?fields=**"
"timestamp": "2024-10-07T03:36:30Z",
"status": "ok",
"size": 864026624,
"href": "/api/storage/cluster/metrics/2024-10-07T03%3A36%3A30Z?fields=**"
"num_records": 2,
"href": "/api/storage/cluster/metrics?fields=**×tamp=2024-10-07T03:36:45Z..2024-10-07T03:36:30Z"
