Manage FlexCache connection status
Retrieve the connection status between cache and origin volumes using FlexCache APIs. These endpoints help manage and verify the connectivity and operational status of your FlexCache configurations.
Overview
FlexCache is a persistent cache of an origin volume.
FlexCache supports fan-out and more than one FlexCache can be created from one origin volume. This API retrieves the connection status between cache and origin volumes.
FlexCache APIs
The following APIs can be used to perform operations related to FlexCache connection status:
– GET /api/storage/flexcache/connection-status
– GET /api/storage/flexcache/connection-status/{node}/{svm}/{local_fg_msid}/{remote_svm_uuid}/{remote_vol_const_msid}
Retrieving flexcache connection-status of all volumes.
The GET request is used to retrieve connection-status between all origins and their corresponding FlexCache volumes.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/flexcache/connection-status?" -H "accept: application/json"
# The response:
"records": [
"node": "sti42-vsim-ucs511b",
"svm": "vs0",
"local_fg_msid": 2150359768,
"remote_svm_uuid": "a9161fea-73a0-11f0-85c5-005056a7bcdb",
"remote_vol_const_msid": 2150359767,
"href": "/api/storage/flexcache/connection-status/sti42-vsim-ucs511b/vs0/2150359768/a9161fea-73a0-11f0-85c5-005056a7bcdb/2150359767"
"node": "sti42-vsim-ucs511d",
"svm": "vs0",
"href": "/api/storage/flexcache/connection-status/sti42-vsim-ucs511d/vs0/2150359768/a9161fea-73a0-11f0-85c5-005056a7bcdb/2150359767"
"node": "sti42-vsim-ucs511c",
"svm": "vs0",
"local_fg_msid": 2150359767,
"remote_vol_const_msid": 2150359769,
"href": "/api/storage/flexcache/connection-status/sti42-vsim-ucs511c/vs0/2150359767/a9161fea-73a0-11f0-85c5-005056a7bcdb/2150359769"
"svm": "vs0",
"remote_vol_const_msid": 2150359770,
"href": "/api/storage/flexcache/connection-status/sti42-vsim-ucs511c/vs0/2150359767/a9161fea-73a0-11f0-85c5-005056a7bcdb/2150359770"
"svm": "vs0",
"remote_vol_const_msid": 2150359771,
"href": "/api/storage/flexcache/connection-status/sti42-vsim-ucs511c/vs0/2150359767/a9161fea-73a0-11f0-85c5-005056a7bcdb/2150359771"
"svm": "vs0",
"remote_vol_const_msid": 2150359772,
"href": "/api/storage/flexcache/connection-status/sti42-vsim-ucs511c/vs0/2150359767/a9161fea-73a0-11f0-85c5-005056a7bcdb/2150359772"
"svm": "vs0",
"remote_vol_const_msid": 2150359773,
"href": "/api/storage/flexcache/connection-status/sti42-vsim-ucs511c/vs0/2150359767/a9161fea-73a0-11f0-85c5-005056a7bcdb/2150359773"
"svm": "vs0",
"remote_vol_const_msid": 2150359774,
"href": "/api/storage/flexcache/connection-status/sti42-vsim-ucs511c/vs0/2150359767/a9161fea-73a0-11f0-85c5-005056a7bcdb/2150359774"
"svm": "vs0",
"remote_vol_const_msid": 2150359775,
"href": "/api/storage/flexcache/connection-status/sti42-vsim-ucs511c/vs0/2150359767/a9161fea-73a0-11f0-85c5-005056a7bcdb/2150359775"
"svm": "vs0",
"remote_vol_const_msid": 2150359776,
"href": "/api/storage/flexcache/connection-status/sti42-vsim-ucs511c/vs0/2150359767/a9161fea-73a0-11f0-85c5-005056a7bcdb/2150359776"
"svm": "vs0",
"remote_vol_const_msid": 2150359777,
"href": "/api/storage/flexcache/connection-status/sti42-vsim-ucs511c/vs0/2150359767/a9161fea-73a0-11f0-85c5-005056a7bcdb/2150359777"
"svm": "vs0",
"remote_vol_const_msid": 2150359778,
"href": "/api/storage/flexcache/connection-status/sti42-vsim-ucs511c/vs0/2150359767/a9161fea-73a0-11f0-85c5-005056a7bcdb/2150359778"
"svm": "vs0",
"remote_vol_const_msid": 2150359779,
"href": "/api/storage/flexcache/connection-status/sti42-vsim-ucs511c/vs0/2150359767/a9161fea-73a0-11f0-85c5-005056a7bcdb/2150359779"
"svm": "vs0",
"remote_vol_const_msid": 2150359780,
"href": "/api/storage/flexcache/connection-status/sti42-vsim-ucs511c/vs0/2150359767/a9161fea-73a0-11f0-85c5-005056a7bcdb/2150359780"
"svm": "vs0",
"href": "/api/storage/flexcache/connection-status/sti42-vsim-ucs511c/vs0/2150359768/a9161fea-73a0-11f0-85c5-005056a7bcdb/2150359767"
"node": "sti42-vsim-ucs511a",
"svm": "vs0",
"href": "/api/storage/flexcache/connection-status/sti42-vsim-ucs511a/vs0/2150359768/a9161fea-73a0-11f0-85c5-005056a7bcdb/2150359767"
"num_records": 16,
"href": "/api/storage/flexcache/connection-status/"
Retrieving a single flexcache connection status
The GET request is used to retrieve a specific connection status between 2 volumes.
# The API:
# The call:
curl -X GET "https://<mgmt-ip>/api/storage/flexcache/connection-status/sti42-vsim-ucs511c/vs0/2150359768/a9161fea-73a0-11f0-85c5-005056a7bcdb/2150359767?" -H "accept: application/json"
# The response:
"svm": "vs0",
"svm_uuid": "a9161fea-73a0-11f0-85c5-005056a7bcdb",
"volume": "fc0",
"remote_svm": "vs0",
"remote_volume": "vol0",
"remote_cluster": "C1_sti42-vsim-ucs511a_1754576895",
"conn_state": "connected",
"remote_endpoint": "origin",
"last_update_time": "2025-08-07T11:39:31-04:00",
