REST API reference
Manage event filter rules
Overview
Manages a specific instance of a rule within a filter. See the documentation for /support/ems/filters for details on the various properties in a rule.
Retrieving a single instance of a rule
# The API:
GET /api/support/ems/filters/{name}/rules/{index}
# The call:
curl -X GET "https://<mgmt-ip>/api/support/ems/filters/no-info-debug-events/rules/1" -H "accept: application/hal+json"
# The response:
200 OK
# JSON Body
"name": "no-info-debug-events",
"index": 1,
"type": "include",
"message_criteria": {
  "name_pattern": "*",
  "severities": "emergency,alert,error,notice",
  "snmp_trap_types": "*",
      "href": "/api/support/ems/messages?name=*&severity=emergency,alert,error,notice&snmp_trap_type=*"
"parameter_criteria": [
    "value_pattern": "*"
    "href": "/api/support/ems/filters/no-info-debug-events/rules/1"
Updating an existing rule to use severity emergency
# The API:
PATCH /api/support/ems/filters/{name}/rules/{index}
# The call:
curl -X PATCH "https://<mgmt-ip>/api/support/ems/filters/test-filter/rules/1" -H "accept: application/hal+json" -H "Content-Type: application/json" -d "@test_ems_filter_rules_patch.txt"
test_ems_filter_rules_patch.txt(body):
  "severities": "emergency"
# The response:
200 OK
Deleting a rule from an existing filter
# The API:
DELETE /api/support/ems/filters/{name}/rules/{index}
# The call:
curl -X DELETE "https://<mgmt-ip>/api/support/ems/filters/test-filter/rules/1" -H "accept: application/hal+json"
# The response:
200 OK
