REST API reference
View the IPsec policy configuration for cluster network security
View the Internet Protocol Security (IPsec) policy configuration for cluster network security. Use these endpoints to retrieve all policies or a specific policy for a node.
Overview
You can use the security cluster-network ipsec policy API endpoints to view the IPsec policy configuration for cluster network security. The following operations are supported:
  • GET to retrieve IPsec policy configurations for cluster network security: GET security/cluster-network/ipsec/policies
  • GET to retrieve a specific IPsec policy by UUID for a given node: GET security/cluster-network/ipsec/policies/{node.uuid}/{uuid}
Retrieving all IPsec policies for cluster network security
# The API:
GET /api/security/cluster-network/ipsec/policies
# The call:
curl -X GET "https://<mgmt-ip>/api/security/cluster-network/ipsec/policies?fields=*&return_records=true" -H "accept: application/json"
# The response:
"records": [
    "node": {
      "uuid": "4ea7a442-86d1-11e0-ae1c-123478563412",
      "name": "node1"
    "uuid": "b3c9e220-74af-11e3-9c7d-00505682a1a0",
    "name": "policy1",
    "authentication_method": "pki",
    "certificate": {
      "uuid": "1cd8a442-86d1-11e0-ae1c-123478563412",
      "name": "cluster_network_cert_1"
    "local_ip": {
      "address": "192.168.1.1",
      "netmask": 24
    "remote_ip": {
      "address": "192.168.1.2",
      "netmask": 24
    "action": "esp_transport",
        "href": "/api/security/cluster-network/ipsec/policies/4ea7a442-86d1-11e0-ae1c-123478563412/b3c9e220-74af-11e3-9c7d-00505682a1a0"
"num_records": 1,
    "href": "/api/security/cluster-network/ipsec/policies"
Retrieving a specific IPsec policy for a given node
# The API:
GET /api/security/cluster-network/ipsec/policies/{node.uuid}/{uuid}
# The call:
curl -X GET "https://<mgmt-ip>/api/security/cluster-network/ipsec/policies/4ea7a442-86d1-11e0-ae1c-123478563412/b3c9e220-74af-11e3-9c7d-00505682a1a0" -H "accept: application/json"
# The response:
"node": {
  "name": "node1"
"name": "policy1",
"certificate": {
"local_ip": {
  "netmask": 24
"remote_ip": {
  "netmask": 24
