config-backup
config-backup-copy
This ONTAPI call does not have an equivalent REST API call.
config-backup-create
POST /api/support/configuration-backup/backups
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
| ONTAPI attribute | REST attribute | Comment |
backup-name |
name |
backup-type |
No REST Equivalent |
backup-type is not a POSTable field. Defaults to "cluster" backup. |
node |
node.name |
config-backup-delete
DELETE /api/support/configuration-backup/backups/{node.uuid}/{name}
backup-name |
name |
node |
node.uuid |
config-backup-download
Note: Direct download of backup files is supported by using the "download_link" property of the REST API response for the /api/support/configuration-backup/backups/\{node.uuid\}/{name} endpoint
config-backup-info-get
GET /api/support/configuration-backup/backups/{node.uuid}/{name}
backup-name |
name |
backup-creation-time |
time |
backup-size |
size |
backup-type |
type |
cluster-name |
cluster-uuid |
is-auto |
auto |
node |
node.name |
nodes-in-backup |
backup_nodes |
schedule |
version |
version |
config-backup-info-get-iter
Note: Specify at least one field in the query.
time |
backup-name |
name |
backup-size |
size |
backup-type |
type |
cluster-name |
cluster-uuid |
is-auto |
auto |
node |
node.name |
nodes-in-backup |
backup_nodes.name |
schedule |
version |
version |
max-records |
max_records |
Specifies the maximum number of records to return before paging. |
config-backup-rename
config-backup-settings-get
backup-count1 |
backup-count2 |
backup-count3 |
destination-url |
url |
job-schedule1 |
job-schedule2 |
job-schedule3 |
username-for-destination-url |
username |
config-backup-settings-modify
PATCH /api/support/configuration-backup
backup-count1 |
backup-count2 |
backup-count3 |
destination-url |
url |
username |
config-backup-settings-password-set
password-for-destination-url |
password |
config-backup-upload
