config-backup
config-backup-copy
This ONTAPI call does not have an equivalent REST API call.
config-backup-create
POST /api/support/configuration-backup/backups
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
backup-name
name
backup-type
No REST Equivalent
backup-type is not a POSTable field. Defaults to "cluster" backup.
node
node.name
config-backup-delete
DELETE /api/support/configuration-backup/backups/{node.uuid}/{name}
backup-name
name
node
node.uuid
config-backup-download
Note: Direct download of backup files is supported by using the "download_link" property of the REST API response for the /api/support/configuration-backup/backups/\{node.uuid\}/{name} endpoint
config-backup-info-get
GET /api/support/configuration-backup/backups/{node.uuid}/{name}
backup-name
name
backup-creation-time
time
backup-size
size
backup-type
type
cluster-name
No REST Equivalent
cluster-uuid
No REST Equivalent
is-auto
auto
node
node.name
nodes-in-backup
backup_nodes
schedule
No REST Equivalent
version
version
config-backup-info-get-iter
Note: Specify at least one field in the query.
time
backup-name
name
backup-size
size
backup-type
type
cluster-name
No REST Equivalent
cluster-uuid
No REST Equivalent
is-auto
auto
node
node.name
nodes-in-backup
backup_nodes.name
schedule
No REST Equivalent
version
version
max-records
max_records
Specifies the maximum number of records to return before paging.
config-backup-rename
config-backup-settings-get
backup-count1
No REST Equivalent
backup-count2
No REST Equivalent
backup-count3
No REST Equivalent
destination-url
url
job-schedule1
No REST Equivalent
job-schedule2
No REST Equivalent
job-schedule3
No REST Equivalent
username-for-destination-url
username
config-backup-settings-modify
PATCH /api/support/configuration-backup
backup-count1
No REST Equivalent
backup-count2
No REST Equivalent
backup-count3
No REST Equivalent
destination-url
url
username
config-backup-settings-password-set
password-for-destination-url
password
config-backup-upload
