name-mapping
name-mapping-create
POST /api/name-services/name-mappings
Usage: This ONTAPI call can be issued against Storage VM (SVM) management LIFs.
| ONTAPI attribute | REST attribute | Comment |
address |
client_match |
direction |
direction |
hostname |
client_match |
pattern |
pattern |
position |
index |
replacement |
replacement |
return-record |
return_records |
name-mapping-delete
DELETE /api/name-services/name-mappings/{svm.uuid}/{direction}/{index}
direction |
direction |
position |
index |
name-mapping-get-iter
GET /api/name-services/name-mappings
address |
client_match |
direction |
direction |
hostname |
client_match |
pattern |
pattern |
position |
index |
replacement |
replacement |
vserver |
svm.name |
max-records |
max_records |
Specifies the maximum number of records to return before paging. |
name-mapping-insert
PATCH /api/name-services/name-mappings/{svm.uuid}/{direction}/{index}
address |
client_match |
direction |
direction |
hostname |
client_match |
pattern |
pattern |
position |
index |
replacement |
replacement |
name-mapping-modify
address |
client_match |
direction |
direction |
hostname |
client_match |
pattern |
pattern |
position |
index |
replacement |
replacement |
name-mapping-refresh-hostname
This ONTAPI call does not have an equivalent REST API call.
name-mapping-swap
direction |
direction |
position |
index |
with-position |
new_index |
name-mapping-unix-group-add-user
POST /api/name-services/unix-groups/{svm.uuid}/{unix_group.name}/users
group-name |
unix_group.name |
UNIX group name should be specified as path parameter. |
user-name |
name |
'name' parameter is used to add single user to the specified group. |
name-mapping-unix-group-add-users
group-name |
unix_group.name |
user-list |
records |
'records' parameter is used to add multiple users in a single REST API call. |
name-mapping-unix-group-create
group-id |
id |
group-name |
name |
return-record |
return_records |
skip-name-validation |
skip_name_validation |
name-mapping-unix-group-delete-user
DELETE /api/name-services/unix-groups/{svm.uuid}/{unix_group.name}/users/{name}
group-name |
unix_group.name |
user-name |
name |
UNIX user to be deleted should be specified as path parameter. |
name-mapping-unix-group-destroy
DELETE /api/name-services/unix-groups/{svm.uuid}/{name}
group-name |
name |
name-mapping-unix-group-get
GET /api/name-services/unix-groups
group-id |
id |
group-name |
name |
No REST Equivalent |
skip-name-validation is a create field and will not be displayed in GET. |
users |
users |
vserver |
svm.name |
group-name |
name |
name-mapping-unix-group-get-iter
GET /api/name-services/unix-groups/{svm.uuid}/{name}
group-id |
id |
group-name |
name |
users |
users |
vserver |
svm.name |
max-records |
max_records |
name-mapping-unix-group-modify
PATCH /api/name-services/unix-groups/{svm.uuid}/{name}
group-id |
id |
group-name |
name |
name-mapping-unix-user-create
POST /api/name-services/unix-users
full-name |
full_name |
group-id |
primary_gid |
return-record |
?return_records=true |
user-id |
id |
user-name |
name |
name-mapping-unix-user-destroy
DELETE /api/name-services/unix-users/{svm.uuid}/{name}
user-name |
name |
name-mapping-unix-user-get
GET /api/name-services/unix-users/{svm.uuid}/{name}
full-name |
full_name |
group-id |
primary_gid |
This field is only available for UNIX users POST end-point. |
user-id |
id |
user-name |
name |
vserver |
svm.name |
user-name |
name |
name-mapping-unix-user-get-iter
full-name |
full_name |
group-id |
primary_gid |
user-id |
id |
user-name |
name |
vserver |
svm.name |
max-records |
max_records |
name-mapping-unix-user-modify
PATCH /api/name-services/unix-users/{svm.uuid}/{name}
full-name |
full_name |
group-id |
primary_gid |
user-id |
id |
user-name |
name |
name-service-unix-group-limits-get
name-service-unix-user-limits-get
