ONTAP ONTAPI-to-REST mapping
name-mapping
name-mapping-create
POST /api/name-services/name-mappings
Usage: This ONTAPI call can be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
address
client_match
direction
direction
hostname
client_match
pattern
pattern
position
index
replacement
replacement
return-record
return_records
name-mapping-delete
DELETE /api/name-services/name-mappings/{svm.uuid}/{direction}/{index}
direction
direction
position
index
name-mapping-get-iter
GET /api/name-services/name-mappings
address
client_match
direction
direction
hostname
client_match
pattern
pattern
position
index
replacement
replacement
vserver
svm.name
max-records
max_records
Specifies the maximum number of records to return before paging.
name-mapping-insert
PATCH /api/name-services/name-mappings/{svm.uuid}/{direction}/{index}
address
client_match
direction
direction
hostname
client_match
pattern
pattern
position
index
replacement
replacement
name-mapping-modify
address
client_match
direction
direction
hostname
client_match
pattern
pattern
position
index
replacement
replacement
name-mapping-refresh-hostname
This ONTAPI call does not have an equivalent REST API call.
name-mapping-swap
direction
direction
position
index
with-position
new_index
name-mapping-unix-group-add-user
POST /api/name-services/unix-groups/{svm.uuid}/{unix_group.name}/users
group-name
unix_group.name
UNIX group name should be specified as path parameter.
user-name
name
'name' parameter is used to add single user to the specified group.
name-mapping-unix-group-add-users
group-name
unix_group.name
user-list
records
'records' parameter is used to add multiple users in a single REST API call.
name-mapping-unix-group-create
group-id
id
group-name
name
return-record
return_records
skip-name-validation
skip_name_validation
name-mapping-unix-group-delete-user
DELETE /api/name-services/unix-groups/{svm.uuid}/{unix_group.name}/users/{name}
group-name
unix_group.name
user-name
name
UNIX user to be deleted should be specified as path parameter.
name-mapping-unix-group-destroy
DELETE /api/name-services/unix-groups/{svm.uuid}/{name}
group-name
name
name-mapping-unix-group-get
GET /api/name-services/unix-groups
group-id
id
group-name
name
No REST Equivalent
skip-name-validation is a create field and will not be displayed in GET.
users
users
vserver
svm.name
group-name
name
name-mapping-unix-group-get-iter
GET /api/name-services/unix-groups/{svm.uuid}/{name}
group-id
id
group-name
name
No REST Equivalent
users
users
vserver
svm.name
max-records
max_records
name-mapping-unix-group-modify
PATCH /api/name-services/unix-groups/{svm.uuid}/{name}
group-id
id
group-name
name
name-mapping-unix-user-create
POST /api/name-services/unix-users
full-name
full_name
group-id
primary_gid
return-record
?return_records=true
user-id
id
user-name
name
name-mapping-unix-user-destroy
DELETE /api/name-services/unix-users/{svm.uuid}/{name}
user-name
name
name-mapping-unix-user-get
GET /api/name-services/unix-users/{svm.uuid}/{name}
full-name
full_name
group-id
primary_gid
No REST Equivalent
This field is only available for UNIX users POST end-point.
user-id
id
user-name
name
vserver
svm.name
user-name
name
name-mapping-unix-user-get-iter
full-name
full_name
group-id
primary_gid
No REST Equivalent
user-id
id
user-name
name
vserver
svm.name
max-records
max_records
name-mapping-unix-user-modify
PATCH /api/name-services/unix-users/{svm.uuid}/{name}
full-name
full_name
group-id
primary_gid
user-id
id
user-name
name
name-service-unix-group-limits-get
name-service-unix-user-limits-get
