ONTAP 9.10.1 ONTAPI-to-REST mapping
snapmirror-policy
snapmirror-policy-add-rule
PATCH /api/snapmirror/policies/{uuid}
Note: A SnapMirror policy rule is referred to as SnapMirror policy retention object. To add a new retention object, use this REST API after appending the new retention object to the existing list of "retention" objects.
Usage: This ONTAPI call can be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
keep
retention.count
policy-name
name
prefix
retention.prefix
preserve
No REST Equivalent
schedule
retention.creation_schedule.uuid
snapmirror-label
retention.label
warn
No REST Equivalent
snapmirror-policy-create
POST /api/snapmirror/policies
archive-after-days
No REST Equivalent
are-data-ops-sequentially-split
No REST Equivalent
comment
comment
common-snapshot-schedule
sync_common_snapshot_schedule.uuid
discard-configs
No REST Equivalent
ignore-atime
No REST Equivalent
is-network-compression-enabled
network_compression_enabled
keep
retention.count
owner
scope
policy-name
name
prefix
retention.prefix
preserve
No REST Equivalent
restart
No REST Equivalent
return-record
No REST Equivalent
schedule
snapmirror-label
retention.label
transfer-priority
No REST Equivalent
tries
No REST Equivalent
type
sync_type
warn
No REST Equivalent
window-size-for-tdp-mirror
No REST Equivalent
snapmirror-policy-delete
DELETE /api/snapmirror/policies/{uuid}
Note: The SnapMirror policy UUID uniquely identifies the policy that should be deleted.
policy-name
No REST Equivalent
snapmirror-policy-get
GET /api/snapmirror/policies
archive-after-days
No REST Equivalent
No REST Equivalent
comment
comment
create-snapshot
No REST Equivalent
discard-configs
No REST Equivalent
ignore-atime
No REST Equivalent
owner
scope
policy-name
name
restart
No REST Equivalent
snapmirror-policy-rules
retention
total-keep
No REST Equivalent
total-rules
No REST Equivalent
transfer-priority
No REST Equivalent
tries
No REST Equivalent
type
sync_type
vserver-name
svm.uuid
No REST Equivalent
policy-name
name
snapmirror-policy-get-iter
archive-after-days
No REST Equivalent
No REST Equivalent
comment
comment
create-snapshot
No REST Equivalent
discard-configs
No REST Equivalent
ignore-atime
No REST Equivalent
owner
scope
policy-name
name
restart
No REST Equivalent
retention
total-keep
No REST Equivalent
total-rules
No REST Equivalent
transfer-priority
No REST Equivalent
tries
No REST Equivalent
type
sync_type
vserver-name
svm.uuid
No REST Equivalent
max-records
max_records
Specifies the maximum number of records to return before paging.
snapmirror-policy-modify
archive-after-days
No REST Equivalent
No REST Equivalent
comment
comment
discard-configs
No REST Equivalent
ignore-atime
No REST Equivalent
keep
retention.count
owner
No REST Equivalent
policy-name
name
prefix
retention.prefix
preserve
No REST Equivalent
restart
No REST Equivalent
schedule
snapmirror-label
retention.label
transfer-priority
No REST Equivalent
tries
No REST Equivalent
warn
No REST Equivalent
No REST Equivalent
snapmirror-policy-modify-rule
Note: A SnapMirror policy rule is referred to as a SnapMirror policy retention object. To modify a retention object, use this REST API by appending the modified retention object to the existing list of "retention" objects.
keep
retention.count
policy-name
name
prefix
retention.prefix
preserve
No REST Equivalent
schedule
snapmirror-label
retention.label
warn
No REST Equivalent
snapmirror-policy-remove-rule
Note: A SnapMirror policy rule is referred to as SnapMirror policy retention object. To delete a retention object, use this REST API by specifying the final list of "retention" objects excluding the retention object that must be deleted.
policy-name
No REST Equivalent
snapmirror-label
No REST Equivalent
