snapmirror-policy
snapmirror-policy-add-rule
PATCH /api/snapmirror/policies/{uuid}
Note: SnapMirror policy rule is referred as SnapMirror policy retention object. To add a new retention object, use this API after appending the new retention object to the existing list of "retention" objects.
| ONTAPI attribute | REST attribute | Comment |
keep |
retention.count |
policy-name |
name |
prefix |
retention.prefix |
preserve |
No REST Equivalent |
schedule |
retention.creation_schedule.uuid |
snapmirror-label |
retention.label |
warn |
snapmirror-policy-create
POST /api/snapmirror/policies
archive-after-days |
are-data-ops-sequentially-split |
comment |
comment |
common-snapshot-schedule |
sync_common_snapshot_schedule.uuid |
discard-configs |
ignore-atime |
is-network-compression-enabled |
network_compression_enabled |
keep |
retention.count |
owner |
scope |
policy-name |
name |
prefix |
retention.prefix |
preserve |
restart |
return-record |
schedule |
snapmirror-label |
retention.label |
transfer-priority |
tries |
type |
sync_type |
warn |
window-size-for-tdp-mirror |
snapmirror-policy-delete
DELETE /api/snapmirror/policies/{uuid}
Note: The SnapMirror policy UUID uniquely identifies the policy that should be deleted.
policy-name |
snapmirror-policy-get
GET /api/snapmirror/policies
comment |
comment |
create-snapshot |
discard-configs |
ignore-atime |
owner |
scope |
policy-name |
name |
restart |
snapmirror-policy-rules |
retention |
total-keep |
total-rules |
transfer-priority |
tries |
type |
sync_type |
vserver-name |
svm.uuid |
policy-name |
name |
snapmirror-policy-get-iter
comment |
comment |
create-snapshot |
discard-configs |
ignore-atime |
owner |
scope |
policy-name |
name |
restart |
retention |
total-keep |
total-rules |
transfer-priority |
tries |
type |
sync_type |
vserver-name |
svm.uuid |
max-records |
max_records |
The maximum number of records to return before paging |
snapmirror-policy-modify
comment |
comment |
discard-configs |
ignore-atime |
keep |
retention.count |
owner |
policy-name |
name |
prefix |
retention.prefix |
preserve |
restart |
schedule |
snapmirror-label |
retention.label |
transfer-priority |
tries |
warn |
snapmirror-policy-modify-rule
Note: A SnapMirror policy rule is referred to as a SnapMirror policy retention object. To modify a retention object, use this API by appending the modified retention object to the existing list of "retention" objects.
keep |
retention.count |
policy-name |
name |
prefix |
retention.prefix |
preserve |
schedule |
snapmirror-label |
retention.label |
warn |
snapmirror-policy-remove-rule
Note: SnapMirror policy rule is referred as SnapMirror policy retention object. To delete a retention object, use this API by specifying the final list of "retention" objects excluding the retention object that must be deleted.
policy-name |
snapmirror-label |
