storage-port
storage-port-disable
This ONTAPI call does not have an equivalent REST API call.
storage-port-enable
storage-port-info-get
GET /api/storage/ports/{node.uuid}/{name}
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
| ONTAPI attribute | REST attribute | Comment |
board-name |
board_name |
cable-end-id |
No REST Equivalent |
cable-identifier |
cable.identifier |
cable-length |
cable.length |
connection-mode |
connector-capabilities-array |
connector-part-number |
cable.part_number |
connector-serial-number |
cable.serial_number |
connector-technology |
connector-type |
connector-vendor |
corrective-action |
error.corrective_action |
date-code |
description |
description |
device-type |
error-severity |
error-text |
error.message |
error-type |
firmware-rev |
firmware_version |
is-dedicated |
mac-address |
mac_address |
mfg-part-number |
mode |
mode |
node |
node.name |
nvdata-rev |
part-number |
part_number |
phys |
port |
name |
port-speed |
speed |
port-type |
type |
ONTAPI port-type → REST API type |
serial-number |
serial_number |
state |
status |
state |
ONTAPI Status → REST API State |
vlan-id |
wwn |
wwn |
wwn contains ":" in ONTAPI, but not in the REST API call. |
wwnn |
wwpn |
wwpn |
wwpn contains ":" in ONTAPI, but not in the REST API call. |
storage-port-info-get-iter
board-name |
board_name |
cable-end-id |
cable-identifier |
cable.identifier |
cable-length |
cable.length |
connection-mode |
cable.part_number |
connector-type |
connector-vendor |
corrective-action |
date-code |
description |
description |
device-type |
error-severity |
error-text |
error.message |
error-type |
firmware-rev |
firmware_version |
is-dedicated |
mac-address |
mac_address |
mfg-part-number |
mode |
mode |
node |
node.name |
nvdata-rev |
part-number |
part_number |
phys |
port |
name |
port-speed |
speed |
port-type |
type |
serial-number |
serial_number |
state |
status |
state |
vlan-id |
wwn |
wwn |
wwnn |
wwpn |
wwpn |
max-records |
max_records |
Specifies the maximum number of records to return before paging. |
storage-port-rescan
storage-port-reset
storage-port-reset-device
