ONTAP ONTAPI-to-REST mapping
storage-port
storage-port-disable
This ONTAPI call does not have an equivalent REST API call.
storage-port-enable
storage-port-info-get
GET /api/storage/ports/{node.uuid}/{name}
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
board-name
board_name
cable-end-id
No REST Equivalent
cable-identifier
cable.identifier
cable-length
cable.length
connection-mode
No REST Equivalent
connector-capabilities-array
No REST Equivalent
connector-part-number
cable.part_number
connector-serial-number
cable.serial_number
connector-technology
No REST Equivalent
connector-type
No REST Equivalent
connector-vendor
No REST Equivalent
corrective-action
error.corrective_action
date-code
No REST Equivalent
description
description
device-type
No REST Equivalent
error-severity
No REST Equivalent
error-text
error.message
error-type
No REST Equivalent
firmware-rev
firmware_version
is-dedicated
No REST Equivalent
mac-address
mac_address
mfg-part-number
No REST Equivalent
mode
mode
node
node.name
nvdata-rev
No REST Equivalent
part-number
part_number
phys
No REST Equivalent
port
name
port-speed
speed
port-type
type
ONTAPI port-type → REST API type
SAS → sas
FC → fc
ENET → enet
serial-number
serial_number
state
No REST Equivalent
status
state
ONTAPI Status → REST API State
unknown → error
online → online
online_degraded → error
offline → offline
link_down → error
vlan-id
No REST Equivalent
wwn
wwn
wwn contains ":" in ONTAPI, but not in the REST API call.
wwnn
No REST Equivalent
wwpn
wwpn
wwpn contains ":" in ONTAPI, but not in the REST API call.
storage-port-info-get-iter
board-name
board_name
cable-end-id
No REST Equivalent
cable-identifier
cable.identifier
cable-length
cable.length
connection-mode
No REST Equivalent
No REST Equivalent
cable.part_number
cable.serial_number
No REST Equivalent
connector-type
No REST Equivalent
connector-vendor
No REST Equivalent
corrective-action
date-code
No REST Equivalent
description
description
device-type
No REST Equivalent
error-severity
No REST Equivalent
error-text
error.message
error-type
No REST Equivalent
firmware-rev
firmware_version
is-dedicated
No REST Equivalent
mac-address
mac_address
mfg-part-number
No REST Equivalent
mode
mode
node
node.name
nvdata-rev
No REST Equivalent
part-number
part_number
phys
No REST Equivalent
port
name
port-speed
speed
port-type
type
SAS → sas
FC → fc
ENET → enet
serial-number
serial_number
state
No REST Equivalent
status
state
unknown → error
online → online
offline → offline
link_down → error
vlan-id
No REST Equivalent
wwn
wwn
wwnn
No REST Equivalent
wwpn
wwpn
max-records
max_records
Specifies the maximum number of records to return before paging.
storage-port-rescan
storage-port-reset
storage-port-reset-device
