ONTAP ONTAPI-to-REST mapping
metrocluster-interface
metrocluster-interface-create
This ONTAPI call does not have an equivalent REST API call.
metrocluster-interface-delete
metrocluster-interface-get-iter
GET /api/cluster/metrocluster/interconnects
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
address
interfaces.address
cluster
No REST Equivalent
cluster-uuid
No REST Equivalent
config-error-info
No REST Equivalent
config-state
No REST Equivalent
dr-group-id
No REST Equivalent
gateway
interfaces.gateway
home-port
adapter
netmask
interfaces.netmask
node
node.name
node-uuid
node.uuid
vlan-id
vlan_id
max-records
max_records
Specifies the maximum number of records to return before paging.
metrocluster-interface-modify
PATCH /api/cluster/metrocluster/interconnects
address
interfaces.address
cluster-name
No REST Equivalent
gateway
interfaces.gateway
home-node
node.uuid
home-port
adapter
netmask
interfaces.netmask
