metrocluster-interface
metrocluster-interface-create
This ONTAPI call does not have an equivalent REST API call.
metrocluster-interface-delete
metrocluster-interface-get-iter
GET /api/cluster/metrocluster/interconnects
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
| ONTAPI attribute | REST attribute | Comment |
address |
interfaces.address |
cluster |
No REST Equivalent |
cluster-uuid |
config-error-info |
config-state |
dr-group-id |
gateway |
interfaces.gateway |
home-port |
adapter |
netmask |
interfaces.netmask |
node |
node.name |
node-uuid |
node.uuid |
vlan-id |
vlan_id |
max-records |
max_records |
Specifies the maximum number of records to return before paging. |
metrocluster-interface-modify
PATCH /api/cluster/metrocluster/interconnects
address |
cluster-name |
gateway |
home-node |
node.uuid |
home-port |
adapter |
netmask |
