ntp-server
ntp-server-create
POST /api/cluster/ntp/servers
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
is-preferred
No REST Equivalent
key-id
key.id
return-record
No REST Equivalent
server-name
server
version
version
ntp-server-delete
DELETE /api/cluster/ntp/servers/{server}
server-name
server
ntp-server-get
GET /api/cluster/ntp/servers/{server}
is-authentication-enabled
authentication_enabled
is-preferred
No REST Equivalent
is-public-default
No REST Equivalent
key-id
key.id
server-name
server
version
version
ntp-server-get-iter
is-preferred
No REST Equivalent
is-public-default
No REST Equivalent
key-id
key.id
server-name
server
version
version
max-records
max_records
Specifies the maximum number of records to return before paging.
ntp-server-key-create
POST /api/cluster/ntp/keys
id
id
return-record
No REST Equivalent
type
digest_type
value
value
ntp-server-key-delete
DELETE /api/cluster/ntp/keys/{id}
id
No REST Equivalent
ntp-server-key-get-iter
GET /api/cluster/ntp/keys
id
id
type
digest_type
value
value
max-records
max_records
ntp-server-key-modify
PATCH /api/cluster/ntp/keys/{id}
id
No REST Equivalent
type
digest_type
value
value
ntp-server-modify
PATCH /api/cluster/ntp/servers/{server}
is-preferred
No REST Equivalent
key-id
key.id
server-name
server
server-name is not a patchable field
version
version
ntp-server-reset
This ONTAPI call does not have an equivalent REST API call.
ntp-server-security-get
ntp-server-security-set
ntp-server-status-get
ntp-server-status-get-iter
ntp-server-validate
