ntp-server
ntp-server-create
POST /api/cluster/ntp/servers
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
| ONTAPI attribute | REST attribute | Comment |
is-preferred |
No REST Equivalent |
key-id |
key.id |
return-record |
server-name |
server |
version |
version |
ntp-server-delete
DELETE /api/cluster/ntp/servers/{server}
server-name |
server |
ntp-server-get
GET /api/cluster/ntp/servers/{server}
is-authentication-enabled |
authentication_enabled |
is-preferred |
is-public-default |
key-id |
key.id |
server-name |
server |
version |
version |
ntp-server-get-iter
is-preferred |
is-public-default |
key-id |
key.id |
server-name |
server |
version |
version |
max-records |
max_records |
Specifies the maximum number of records to return before paging. |
ntp-server-key-create
POST /api/cluster/ntp/keys
id |
id |
return-record |
type |
digest_type |
value |
value |
ntp-server-key-delete
DELETE /api/cluster/ntp/keys/{id}
id |
ntp-server-key-get-iter
GET /api/cluster/ntp/keys
id |
id |
type |
digest_type |
value |
value |
max-records |
max_records |
ntp-server-key-modify
PATCH /api/cluster/ntp/keys/{id}
id |
type |
digest_type |
value |
value |
ntp-server-modify
PATCH /api/cluster/ntp/servers/{server}
is-preferred |
key-id |
key.id |
server-name |
server |
server-name is not a patchable field |
version |
version |
ntp-server-reset
This ONTAPI call does not have an equivalent REST API call.
ntp-server-security-get
ntp-server-security-set
ntp-server-status-get
ntp-server-status-get-iter
ntp-server-validate
