security-ssl
security-ssl-get
GET /api/security/certificates/{uuid}
Usage: This ONTAPI call can be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
certificate-authority
ca
Certificate authority.
certificate-serial-number
serial_number
Serial number of certificate.
client-authentication-enabled
No REST Equivalent
See "client_enabled" in /api/cluster/web and /api/svm/svms/\{svm.uuid\}/web.
common-name
common_name
FQDN or custom common name.
ocsp-default-responder
No REST Equivalent
ocsp-enabled
No REST Equivalent
See "ocsp_enabled" in /api/cluster/web and /api/svm/svms/\{svm.uuid\}/web.
ocsp-max-response-age
No REST Equivalent
ocsp-max-response-time-skew
No REST Equivalent
ocsp-override-responder
No REST Equivalent
ocsp-responder-timeout
No REST Equivalent
ocsp-use-request-nonce
No REST Equivalent
server-authentication-enabled
No REST Equivalent
vserver
svm.name
The name of the SVM.
security-ssl-get-iter
ca
serial_number
No REST Equivalent
common-name
common_name
No REST Equivalent
ocsp-enabled
No REST Equivalent
No REST Equivalent
No REST Equivalent
No REST Equivalent
No REST Equivalent
No REST Equivalent
No REST Equivalent
vserver
svm.name
max-records
max_records
Specifies the maximum number of records to return before paging.
security-ssl-modify
PATCH /api/svm/svms/{svm.uuid}/web
Note: The certificate’s UUID is used to identify the certificate to use for the SVM. To update the certificate of the admin SVM, use PATCH /api/cluster/web.
Example:
curl -XPATCH "https://{mgmt-ip}/api/svm/svms/1cd8a442-86d1-11e0-ae1c-123478563412/web" -d '{"certificate": { "uuid": "abc8a442-86d1-11e0-ae1c-123478563333" } }'
No REST Equivalent
The certificate authority associated with the certificate.
No REST Equivalent
The serial number for the certificate.
client_enabled
Indicates whether client authentication is enabled.
common-name
No REST Equivalent
FQDN or custom common name for the certificate.
No REST Equivalent
ocsp-enabled
ocsp_enabled
Indicates whether online certificate status protocol verification is enabled.
No REST Equivalent
No REST Equivalent
No REST Equivalent
No REST Equivalent
No REST Equivalent
No REST Equivalent
SSL server authentication. To disable this field, delete the certificate using DELETE /api/security/certificates/{uuid}.
vserver
name
