security-ssl
security-ssl-get
GET /api/security/certificates/{uuid}
Usage: This ONTAPI call can be issued against Storage VM (SVM) management LIFs.
| ONTAPI attribute | REST attribute | Comment |
certificate-authority |
ca |
Certificate authority. |
certificate-serial-number |
serial_number |
Serial number of certificate. |
client-authentication-enabled |
No REST Equivalent |
See "client_enabled" in /api/cluster/web and /api/svm/svms/\{svm.uuid\}/web. |
common-name |
common_name |
FQDN or custom common name. |
ocsp-default-responder |
ocsp-enabled |
See "ocsp_enabled" in /api/cluster/web and /api/svm/svms/\{svm.uuid\}/web. |
ocsp-max-response-age |
ocsp-max-response-time-skew |
ocsp-override-responder |
ocsp-responder-timeout |
ocsp-use-request-nonce |
server-authentication-enabled |
vserver |
svm.name |
The name of the SVM. |
security-ssl-get-iter
ca |
serial_number |
common-name |
common_name |
ocsp-enabled |
vserver |
svm.name |
max-records |
max_records |
Specifies the maximum number of records to return before paging. |
security-ssl-modify
PATCH /api/svm/svms/{svm.uuid}/web
Note: The certificate's UUID is used to identify the certificate to use for the SVM. To update the certificate of the admin SVM, use PATCH /api/cluster/web.
Example:
curl -XPATCH "https://{mgmt-ip}/api/svm/svms/1cd8a442-86d1-11e0-ae1c-123478563412/web" -d '{"certificate": { "uuid": "abc8a442-86d1-11e0-ae1c-123478563333" } }'
The certificate authority associated with the certificate. |
The serial number for the certificate. |
client_enabled |
Indicates whether client authentication is enabled. |
common-name |
FQDN or custom common name for the certificate. |
ocsp-enabled |
ocsp_enabled |
Indicates whether online certificate status protocol verification is enabled. |
SSL server authentication. To disable this field, delete the certificate using DELETE /api/security/certificates/{uuid}. |
vserver |
name |
