vserver-peer-permission
vserver-peer-permission-remote-get
This ONTAPI call does not have an equivalent REST API call.
vserver-peer-permission-remote-get-iter
GET /api/private/cli/vserver/peer/permission/remote-show/
Note: Lists the SVMs in peer cluster which has permission to peer with the local cluster’s SVMs. Available through the REST API by using the CLI passthrough.
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
applications
applications
Specifies the applications to be filtered.
vserver
vserver
Specifies the peer SVM name.
max-records
max_records
Specifies the maximum number of records to return before paging.
peer-cluster
peer-cluster
Specifies the peer cluster name.
