vserver-peer-permission
vserver-peer-permission-remote-get
This ONTAPI call does not have an equivalent REST API call.
vserver-peer-permission-remote-get-iter
GET /api/private/cli/vserver/peer/permission/remote-show/
Note: Lists the SVMs in peer cluster which has permission to peer with the local cluster's SVMs. Available through the REST API by using the CLI passthrough.
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
| ONTAPI attribute | REST attribute | Comment |
applications |
applications |
Specifies the applications to be filtered. |
vserver |
vserver |
Specifies the peer SVM name. |
max-records |
max_records |
Specifies the maximum number of records to return before paging. |
peer-cluster |
peer-cluster |
Specifies the peer cluster name. |
