cluster-image
cluster-image-get
GET /api/cluster/software
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute | REST attribute | Comment |
current-version |
nodes.version |
date-installed |
No REST Equivalent |
cluster-image-get-download-progress
GET /api/cluster/software/download
progress-details |
message |
'message' holds details of all the cases including failure case |
progress-status |
state |
'state' will have simplier values than 'progress-status' |
failure-reason |
message |
'message' will hold reason of failure only in case of package download failed or aborted. |
cluster-image-get-iter
current-version |
nodes.version |
date-installed |
cluster-image-get-upgrade-plan
This ONTAPI call does not have an equivalent REST API call.
cluster-image-metrocluster-update-progress-info-get
completed-node-count |
dr-validation-reports |
intermediate-version |
is-two-stage-upgrade |
is-validation-done-by-update |
metrocluster |
metrocluster.clusters |
This attribute is specific to Two node Metrocluster Configuration |
ndu-node-update-list |
nodes |
node-estimated-duration |
update_details.estimated_duration |
overall-elapsed-duration |
elapsed_duration |
overall-estimated-duration |
overall-status |
state |
package-version |
pending_version |
paused-node-count |
phase-comments |
progress-detail |
metrocluster.progress_details |
progress-summary |
metrocluster.progress_summary |
source-version |
version |
target-version |
pending_version |
total-node-count |
upgrade-stage |
update_check_list |
cluster-image-node-update-progress-info
GET /api/cluster/software?status_details.node={node}
node-name |
generic_status_details.node |
node-update-task-info-list |
generic_status_details |
cluster-image-package-delete
DELETE /api/cluster/software/packages/{version}
package-version |
version |
cluster-image-package-download
POST /api/cluster/software/download
package-url |
url |
replace-package |
cluster-image-package-download-abort
cluster-image-package-local-get
GET /api/cluster/software/packages/{version}
package-build-time |
create_time |
package-details |
package-version |
version |
cluster-image-package-local-get-iter
create_time |
package-details |
package-version |
version |
num-records |
num_records |
Specifies the maximum number of records to return before paging. |
cluster-image-update
PATCH /api/cluster/software?stabilize_minutes={minutes}&skip_warnings={skip}
estimate-only |
force-rolling |
ignore-validation-warning |
skip_warnings |
nodes |
package-version |
pending_version |
pause-after |
stabilize-minutes |
stabilize_minutes |
cluster-image-update-cancel
PATCH /api/cluster/software?action=cancel
action |
Value of attribute must be: cancel |
cluster-image-update-history-get-iter
GET /api/cluster/software/history
completion-time |
end_time |
component-id |
node.name |
component-name |
package-version |
previous-version |
from_version |
start-time |
start_time |
update-status |
state |
updated-version |
to_version |
num-records |
num_records |
cluster-image-update-log-get-iter
cluster-image-update-pause
PATCH /api/cluster/software?action=pause
action |
Value of attribute must be: pause |
cluster-image-update-progress-get-iter
duration |
update_details.elapsed_duration |
ndu-phase |
update_details.phase |
phase-comments |
If an error has occurred, this attribute describes the required recovery action. If the phase is completed, it provides the duration of the phase. |
phase-status |
update_details.state |
num-records |
num_records |
cluster-image-update-progress-info
Note: The REST API GET method contains some of this information, but not all, and not in the desired format.
node-name |
update_details.node.name |
node-status |
elapsed_duration |
overall-status |
state |
package-version |
pending_version |
paused-node-count |
phase-comments |
source-version |
target-version |
total-node-count |
upgrade-stage |
update_check_list |
cluster-image-update-resume
PATCH /api/cluster/software?action=resume
action |
Value of attribute must be: resume |
cluster-image-validate
Note: To GET below attributes values PATCH "api/cluster/software?validate=true" is required at first
ndu-check |
update_check_list.update_check |
ndu-status |
update_check_list.status |
error |
update_check_list.issue.message |
action |
Not a ui attribute |
advice |
update_check_list.action.message |
