cluster-image
cluster-image-get
GET /api/cluster/software
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
current-version
nodes.version
date-installed
No REST Equivalent
cluster-image-get-download-progress
GET /api/cluster/software/download
progress-details
message
progress-status
No REST Equivalent
failure-reason
No REST Equivalent
cluster-image-get-iter
current-version
nodes.version
date-installed
No REST Equivalent
cluster-image-get-upgrade-plan
This ONTAPI call does not have an equivalent REST API call.
cluster-image-metrocluster-update-progress-info-get
completed-node-count
No REST Equivalent
dr-validation-reports
No REST Equivalent
intermediate-version
No REST Equivalent
is-two-stage-upgrade
No REST Equivalent
is-validation-done-by-update
No REST Equivalent
metrocluster
metrocluster.clusters
This attribute is specific to Two node Metrocluster Configuration
ndu-node-update-list
nodes
node-estimated-duration
update_details.estimated_duration
overall-elapsed-duration
elapsed_duration
overall-estimated-duration
estimated_duration
overall-status
state
package-version
pending_version
paused-node-count
No REST Equivalent
phase-comments
No REST Equivalent
progress-detail
metrocluster.progress_details
progress-summary
metrocluster.progress_summary
source-version
version
target-version
pending_version
total-node-count
No REST Equivalent
upgrade-stage
No REST Equivalent
validation-reports
update_check_list
cluster-image-node-update-progress-info
GET /api/cluster/software?status_details.node={node}
node-name
generic_status_details.node
node-update-task-info-list
cluster-image-package-delete
DELETE /api/cluster/software/packages/{version}
package-version
version
cluster-image-package-download
POST /api/cluster/software/download
package-url
url
replace-package
No REST Equivalent
cluster-image-package-download-abort
cluster-image-package-local-get
GET /api/cluster/software/packages/{version}
package-build-time
create_time
package-details
No REST Equivalent
package-version
version
cluster-image-package-local-get-iter
package-build-time
create_time
package-details
No REST Equivalent
package-version
version
num-records
num_records
Specifies the maximum number of records to return before paging.
cluster-image-update
PATCH /api/cluster/software?stabilize_minutes={minutes}&skip_warnings={skip}
estimate-only
No REST Equivalent
force-rolling
No REST Equivalent
ignore-validation-warning
skip_warnings
nodes
No REST Equivalent
package-version
pending_version
pause-after
No REST Equivalent
stabilize-minutes
stabilize_minutes
cluster-image-update-cancel
PATCH /api/cluster/software?action=cancel
action
Value of attribute must be: cancel
cluster-image-update-history-get-iter
GET /api/cluster/software/history
completion-time
end_time
component-id
node.name
component-name
No REST Equivalent
package-version
No REST Equivalent
previous-version
from_version
start-time
start_time
update-status
state
updated-version
to_version
num-records
num_records
cluster-image-update-log-get-iter
cluster-image-update-pause
PATCH /api/cluster/software?action=pause
action
Value of attribute must be: pause
cluster-image-update-progress-get-iter
duration
update_details.elapsed_duration
ndu-phase
update_details.phase
phase-comments
No REST Equivalent
If an error has occurred, this attribute describes the required recovery action. If the phase is completed, it provides the duration of the phase.
phase-status
update_details.state
num-records
num_records
cluster-image-update-progress-info
Note: The REST API GET method contains some of this information, but not all, and not in the desired format.
No REST Equivalent
No REST Equivalent
No REST Equivalent
No REST Equivalent
update_details.node.name
elapsed_duration
estimated_duration
overall-status
state
package-version
pending_version
paused-node-count
No REST Equivalent
phase-comments
No REST Equivalent
source-version
No REST Equivalent
target-version
No REST Equivalent
total-node-count
No REST Equivalent
upgrade-stage
No REST Equivalent
validation-reports
update_check_list
cluster-image-update-resume
PATCH /api/cluster/software?action=resume
action
Value of attribute must be: resume
cluster-image-validate
PATCH /api/cluster/software?validate_only=true
nodes
No REST Equivalent
package-version
pending_version
