license-v2
license-v2-add
POST /api/cluster/licensing/licenses
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute | REST attribute | Comment |
codes |
keys |
license-v2-apply
content |
keys |
Each element of the keys attribute MUST be a JSON string, enclosed |
license-v2-capacity-create
license-input |
keys |
Applies only to ONTAP Select. |
license-v2-capacity-get-iter
GET /api/cluster/licensing/licenses
current-capacity |
licenses.capacity.used_size |
expiration-time |
licenses.expiry_time |
max-capacity |
licenses.capacity.maximum_size |
owner |
licenses.owner |
package |
name |
reported-state |
state |
serial-number |
licenses.serial_number |
max-records |
max_records |
Specifies the maximum number of records to return before paging. |
license-v2-cleanup-list-info
This ONTAPI call does not have an equivalent REST API call.
license-v2-delete
DELETE /api/cluster/licensing/licenses/{name}?serial_number={serial_number}
package |
name |
serial-number |
serial_number |
license-v2-delete-expired
license-v2-delete-unused
license-v2-entitlement-risk-get-iter
There are no attributes defined for this ONTAPI call.
license-v2-leases-update
license-v2-license-manager-config-get
GET /api/cluster/licensing/license-managers/{uuid}
host |
uri.host |
license-v2-license-manager-config-modify
PATCH /api/cluster/licensing/license-managers/{uuid}
host |
uri.host |
license-v2-license-manager-status-get-iter
license-v2-list-info
Note: This ONTAPI does NOT apply to capacity pool licenses.
serial-number |
package |
name |
owner |
licenses.owner |
description |
No REST Equivalent |
type |
expiration-time |
legacy |
customer-id |
license-v2-status-get-iter
GET /api/cluster/licensing/licenses/{name}
detailed-status |
license |
name |
scope |
scope |
status |
state |
max-records |
max_records |
license-v2-status-list-info
license-input |
license-v2-subscription-get-iter
GET /api/cluster/licensing/licenses?name=cloud
alert |
description |
expiration |
is-default |
owner |
licenses.owner |
package |
name |
serial-number |
state |
max-records |
max_records |
system-license-aggregate-get-iter
