license-v2
license-v2-add
POST /api/cluster/licensing/licenses
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
codes
keys
license-v2-apply
content
keys
Each element of the keys attribute MUST be a JSON string, enclosed
in double quotes, with all double quotes within the
original string prefaced (escaped) with a "\".
license-v2-capacity-create
license-input
keys
Applies only to ONTAP Select.
license-v2-capacity-get-iter
GET /api/cluster/licensing/licenses
current-capacity
licenses.capacity.used_size
expiration-time
licenses.expiry_time
max-capacity
licenses.capacity.maximum_size
owner
licenses.owner
package
name
reported-state
state
serial-number
licenses.serial_number
max-records
max_records
Specifies the maximum number of records to return before paging.
license-v2-cleanup-list-info
This ONTAPI call does not have an equivalent REST API call.
license-v2-delete
DELETE /api/cluster/licensing/licenses/{name}?serial_number={serial_number}
package
name
serial-number
serial_number
license-v2-delete-expired
license-v2-delete-unused
license-v2-entitlement-risk-get-iter
There are no attributes defined for this ONTAPI call.
license-v2-leases-update
license-v2-license-manager-config-get
GET /api/cluster/licensing/license-managers/{uuid}
host
uri.host
license-v2-license-manager-config-modify
PATCH /api/cluster/licensing/license-managers/{uuid}
host
uri.host
license-v2-license-manager-status-get-iter
license-v2-list-info
Note: This ONTAPI does NOT apply to capacity pool licenses.
serial-number
package
name
owner
licenses.owner
description
No REST Equivalent
type
No REST Equivalent
expiration-time
legacy
No REST Equivalent
customer-id
No REST Equivalent
license-v2-status-get-iter
GET /api/cluster/licensing/licenses/{name}
detailed-status
No REST Equivalent
license
name
scope
scope
status
state
max-records
max_records
license-v2-status-list-info
license-input
No REST Equivalent
license-v2-subscription-get-iter
GET /api/cluster/licensing/licenses?name=cloud
alert
No REST Equivalent
description
No REST Equivalent
expiration
is-default
No REST Equivalent
owner
licenses.owner
package
name
serial-number
state
No REST Equivalent
max-records
max_records
system-license-aggregate-get-iter
