storage-bridge
storage-bridge-config-dump-collect
This ONTAPI call does not have an equivalent REST API call.
storage-bridge-config-dump-delete
storage-bridge-config-dump-get-iter
storage-bridge-coredump-collect
storage-bridge-coredump-delete
storage-bridge-coredump-get-iter
storage-bridge-firmware-firmware-update
storage-bridge-get
GET /api/storage/bridges/{wwn}
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute | REST attribute | Comment |
address |
ip_address |
chassis-throughput-status |
chassis_throughput_state |
dram-single-bit-error-count |
dram_single_bit_error_count |
firmware-version |
firmware_version |
is-being-monitored |
monitoring_enabled |
is-bridge-secure |
security_enabled |
last-reboot-reason |
last_reboot.reason |
last-reboot-time |
last_reboot.time |
managed-by |
managed_by |
model |
model |
name |
name |
serial-number |
serial_number |
status |
state |
storage-bridge-connectivity-list |
paths |
storage-bridge-cooling-info |
temperature_sensor |
storage-bridge-error-list |
errors |
storage-bridge-fc-port-list |
fc_ports |
storage-bridge-fc-port-sfp-list |
fc_ports.sfp |
storage-bridge-fc-port-statistics-list |
No REST Equivalent |
storage-bridge-mini-sas-hd-list |
sas_ports.cable |
storage-bridge-power-supply-list |
power_supply_units |
storage-bridge-sas-port-list |
sas_ports |
storage-bridge-sas-port-qsfp-list |
storage-bridge-sas-port-statistics-list |
symbolic-name |
symbolic_name |
vendor |
vendor |
wwn |
wwn |
storage-bridge-get-iter
address |
ip_address |
firmware-version |
firmware_version |
is-bridge-secure |
security_enabled |
last-reboot-time |
last_reboot.time |
managed-by |
managed_by |
model |
model |
name |
name |
serial-number |
serial_number |
status |
state |
paths |
errors |
fc_ports |
fc_ports.sfp |
sas_ports.cable |
sas_ports |
symbolic-name |
symbolic_name |
vendor |
vendor |
wwn |
wwn |
max-records |
max_records |
Specifies the maximum number of records to return before paging. |
