storage-bridge
storage-bridge-config-dump-collect
This ONTAPI call does not have an equivalent REST API call.
storage-bridge-config-dump-delete
storage-bridge-config-dump-get-iter
storage-bridge-coredump-collect
storage-bridge-coredump-delete
storage-bridge-coredump-get-iter
storage-bridge-firmware-firmware-update
storage-bridge-get
GET /api/storage/bridges/{wwn}
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
address
ip_address
chassis-throughput-status
chassis_throughput_state
dram-single-bit-error-count
dram_single_bit_error_count
firmware-version
firmware_version
is-being-monitored
monitoring_enabled
is-bridge-secure
security_enabled
last-reboot-reason
last_reboot.reason
last-reboot-time
last_reboot.time
managed-by
managed_by
model
model
name
name
serial-number
serial_number
status
state
storage-bridge-connectivity-list
paths
storage-bridge-cooling-info
temperature_sensor
storage-bridge-error-list
errors
storage-bridge-fc-port-list
fc_ports
storage-bridge-fc-port-sfp-list
fc_ports.sfp
storage-bridge-fc-port-statistics-list
No REST Equivalent
storage-bridge-mini-sas-hd-list
sas_ports.cable
storage-bridge-power-supply-list
power_supply_units
storage-bridge-sas-port-list
sas_ports
storage-bridge-sas-port-qsfp-list
No REST Equivalent
storage-bridge-sas-port-statistics-list
No REST Equivalent
symbolic-name
symbolic_name
vendor
vendor
wwn
wwn
storage-bridge-get-iter
address
ip_address
firmware-version
firmware_version
is-being-monitored
monitoring_enabled
is-bridge-secure
security_enabled
last-reboot-reason
last_reboot.reason
last-reboot-time
last_reboot.time
managed-by
managed_by
model
model
name
name
serial-number
serial_number
status
state
paths
temperature_sensor
errors
fc_ports
fc_ports.sfp
No REST Equivalent
sas_ports.cable
power_supply_units
sas_ports
No REST Equivalent
No REST Equivalent
symbolic-name
symbolic_name
vendor
vendor
wwn
wwn
max-records
max_records
Specifies the maximum number of records to return before paging.
