snapmirror-object-store
snapmirror-object-store-config-create
POST /api/cloud/targets
Usage: This ONTAPI call can be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
access-key
access_key
aws-region
No REST Equivalent
azure-account
azure_account
azure-private-key
azure_private_key
container-name
container
ignore-warning-codes
No REST Equivalent
ipspace
ipspace.name
You can also use ispace.uuid with the REST API.
is-certificate-validation-enabled
certificate_validation_enabled
is-ssl-enabled
ssl_enabled
object-store-name
name
port
port
provider-type
provider_type
secret-password
secret_password
server
server
url-style
url_style
usage
No REST Equivalent
use-iam-role
No REST Equivalent
vserver-name
svm.name
You can also use svm.uuid with the REST API.
snapmirror-object-store-config-delete
DELETE /api/cloud/targets/{uuid}
object-store-name
No REST Equivalent
snapmirror-object-store-config-get
GET /api/cloud/targets/{uuid}
access-key
access_key
azure-account
azure_account
azure-private-key
No REST Equivalent
config-id
No REST Equivalent
confirm-warning-codes
No REST Equivalent
confirm-warning-texts
No REST Equivalent
container-name
container
No REST Equivalent
ipspace
ipspace.name
is-ssl-enabled
ssl_enabled
object-store-name
name
port
port
provider-type
provider_type
secret-password
No REST Equivalent
server
server
url-style
url_style
usage
No REST Equivalent
use-http-proxy
use_http_proxy
use-iam-role
No REST Equivalent
vserver-name
svm.name
vsuuid
svm.uuid
object-store-name
name
snapmirror-object-store-config-get-iter
access-key
access_key
azure-account
azure_account
azure-private-key
azure_private_key
config-id
No REST Equivalent
No REST Equivalent
No REST Equivalent
container-name
container
No REST Equivalent
ipspace
ipspace.name
No REST Equivalent
is-ssl-enabled
ssl_enabled
object-store-name
name
port
port
provider-type
provider_type
secret-password
No REST Equivalent
server
server
url-style
url_style
usage
No REST Equivalent
use-http-proxy
use_http_proxy
use-iam-role
No REST Equivalent
vserver-name
svm.name
vsuuid
svm.uuid
max-records
max_records
Specifies the maximum number of records to return before paging.
snapmirror-object-store-config-modify
PATCH /api/cloud/targets/{uuid}
access-key
access_key
aws-region
No REST Equivalent
azure-account
azure_account
azure-private-key
azure_private_key
No REST Equivalent
ipspace
ipspace.name
You can also use ipspace.uuid with the REST API.
is-ssl-enabled
ssl_enabled
new-object-store-name
name
object-store-name
No REST Equivalent
port
port
secret-password
secret_password
server
server
url-style
No REST Equivalent
usage
No REST Equivalent
use-iam-role
No REST Equivalent
vserver-name
No REST Equivalent
snapmirror-object-store-endpoint-delete
Note: The REST API does not support this ONTAPI.
This ONTAPI call does not have an equivalent REST API call.
snapmirror-object-store-snapshot-delete
snapmirror-object-store-snapshot-get
snapmirror-object-store-snapshot-get-iter
