snapmirror-object-store
snapmirror-object-store-config-create
POST /api/cloud/targets
Usage: This ONTAPI call can be issued against Storage VM (SVM) management LIFs.
| ONTAPI attribute | REST attribute | Comment |
access-key |
access_key |
aws-region |
No REST Equivalent |
azure-account |
azure_account |
azure-private-key |
azure_private_key |
container-name |
container |
ignore-warning-codes |
ipspace |
ipspace.name |
You can also use ispace.uuid with the REST API. |
is-certificate-validation-enabled |
certificate_validation_enabled |
is-ssl-enabled |
ssl_enabled |
object-store-name |
name |
port |
port |
provider-type |
provider_type |
secret-password |
secret_password |
server |
server |
url-style |
url_style |
usage |
use-iam-role |
vserver-name |
svm.name |
You can also use svm.uuid with the REST API. |
snapmirror-object-store-config-delete
DELETE /api/cloud/targets/{uuid}
object-store-name |
snapmirror-object-store-config-get
GET /api/cloud/targets/{uuid}
access-key |
access_key |
azure-account |
azure_account |
azure-private-key |
config-id |
confirm-warning-codes |
confirm-warning-texts |
container-name |
container |
ipspace |
ipspace.name |
is-ssl-enabled |
ssl_enabled |
object-store-name |
name |
port |
port |
provider-type |
provider_type |
secret-password |
server |
server |
url-style |
url_style |
usage |
use-http-proxy |
use_http_proxy |
use-iam-role |
vserver-name |
svm.name |
vsuuid |
svm.uuid |
object-store-name |
name |
snapmirror-object-store-config-get-iter
access-key |
access_key |
azure-account |
azure_account |
azure-private-key |
azure_private_key |
config-id |
container-name |
container |
ipspace |
ipspace.name |
is-ssl-enabled |
ssl_enabled |
object-store-name |
name |
port |
port |
provider-type |
provider_type |
secret-password |
server |
server |
url-style |
url_style |
usage |
use-http-proxy |
use_http_proxy |
use-iam-role |
vserver-name |
svm.name |
vsuuid |
svm.uuid |
max-records |
max_records |
Specifies the maximum number of records to return before paging. |
snapmirror-object-store-config-modify
PATCH /api/cloud/targets/{uuid}
access-key |
access_key |
aws-region |
azure-account |
azure_account |
azure-private-key |
azure_private_key |
ipspace |
ipspace.name |
You can also use ipspace.uuid with the REST API. |
is-ssl-enabled |
ssl_enabled |
new-object-store-name |
name |
object-store-name |
port |
port |
secret-password |
secret_password |
server |
server |
url-style |
usage |
use-iam-role |
vserver-name |
snapmirror-object-store-endpoint-delete
Note: The REST API does not support this ONTAPI.
This ONTAPI call does not have an equivalent REST API call.
snapmirror-object-store-snapshot-delete
snapmirror-object-store-snapshot-get
snapmirror-object-store-snapshot-get-iter
