template-management
template-management-choices-get
GET /api/private/cli/template/get-choices
Note: Available through the REST API by using the CLI passthrough.
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
| ONTAPI attribute | REST attribute | Comment |
attribute |
No REST Equivalent |
choices |
default-val |
descriptions |
object |
object |
template-management-template-copy
This ONTAPI call does not have an equivalent REST API call.
template-management-template-delete
template-management-template-download
template-management-template-get
template-management-template-get-iter
description |
missing-prerequisites |
name |
parent-template |
permission |
uuid |
version |
max-records |
max_records |
Specifies the maximum number of records to return before paging. |
template-management-template-parameter-get
template-management-template-parameter-get-iter
template-management-template-parameter-modify
template-management-template-parameter-modify-iter
template-management-template-provision
POST /api/svm/svms
Note: Create and configure the SVM with data access protocols, data and management interfaces, and service configurations using template provision.
custom-inputs |
template |
template-management-template-provision-error-clean
POST /api/private/cli/template/clean-error
jobid |
template-management-template-provision-error-get
GET /api/private/cli/template/show-provision-error
failure-errornum |
failure-reason |
input-params |
jobid |
jobid |
template-management-template-read
template-management-template-refresh
template-management-template-rename
template-management-template-upload
