ONTAP ONTAPI-to-REST mapping
template-management
template-management-choices-get
GET /api/private/cli/template/get-choices
Note: Available through the REST API by using the CLI passthrough.
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
attribute
No REST Equivalent
choices
No REST Equivalent
default-val
No REST Equivalent
descriptions
No REST Equivalent
object
No REST Equivalent
object
No REST Equivalent
template-management-template-copy
This ONTAPI call does not have an equivalent REST API call.
template-management-template-delete
template-management-template-download
template-management-template-get
template-management-template-get-iter
description
No REST Equivalent
missing-prerequisites
No REST Equivalent
name
No REST Equivalent
parent-template
No REST Equivalent
permission
No REST Equivalent
uuid
No REST Equivalent
version
No REST Equivalent
max-records
max_records
Specifies the maximum number of records to return before paging.
template-management-template-parameter-get
template-management-template-parameter-get-iter
template-management-template-parameter-modify
template-management-template-parameter-modify-iter
template-management-template-provision
POST /api/svm/svms
Note: Create and configure the SVM with data access protocols, data and management interfaces, and service configurations using template provision.
custom-inputs
No REST Equivalent
template
No REST Equivalent
template-management-template-provision-error-clean
POST /api/private/cli/template/clean-error
jobid
No REST Equivalent
template-management-template-provision-error-get
GET /api/private/cli/template/show-provision-error
failure-errornum
No REST Equivalent
failure-reason
No REST Equivalent
input-params
No REST Equivalent
jobid
No REST Equivalent
jobid
No REST Equivalent
template-management-template-read
template-management-template-refresh
template-management-template-rename
template-management-template-upload
