ONTAP ONTAPI-to-REST mapping
cluster-peer
cluster-peer-active-address-insert
PATCH /api/cluster/peers/{uuid}
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
active-address
remote.ip_addresses
cluster-name
name
cluster-peer-active-addresses-get
GET /api/cluster/peers
cluster-name
name
peer-addresses
remote.ip_addresses
cluster-peer-active-addresses-register
Note: This is an unsupported ONTAPI operation.
This ONTAPI call does not have an equivalent REST API call.
cluster-peer-authn-offer-cancel
cluster-peer-authn-offer-get
GET /api/cluster/peers/{uuid}
auth-status-admin
authentication.in_use
auth-status-operational
authentication.state
encryption-protocol-proposed
encryption.proposed
initial-allowed-vserver-peers
initial_allowed_svms
offer-creation
No REST Equivalent
offer-expiration
authentication.expiry_time
peer-cluster-name
name
peer-cluster-uuid
uuid
cluster-peer-authn-offer-get-iter
auth-status-admin
encryption.proposed
offer-creation
No REST Equivalent
offer-expiration
peer-cluster-name
name
peer-cluster-uuid
uuid
max-records
max_records
Specifies the maximum number of records to return before paging
cluster-peer-authn-offer-modify
offer-expiration
peer-cluster-name
name
cluster-peer-connection-destroy
cluster-peer-connections-get
cluster-peer-connections-get-iter
cluster-peer-create
POST /api/cluster/peers
address-family
No REST Equivalent
applications
peer_applications
encryption.proposed
generate-passphrase
authentication.generate_passphrase
ipspace-name
ipspace.name
local-name
remote.name
offer-expiration
passphrase
authentication.passphrase
password
No REST Equivalent
peer-addresses
remote.ip_addresses
rpc-connect-timeout
No REST Equivalent
timeout
No REST Equivalent
update-ping-timeout
No REST Equivalent
user-name
No REST Equivalent
cluster-peer-delete
DELETE /api/cluster/peers/{uuid}
cluster-name
No REST Equivalent
cluster-peer-get
cluster-name
name
active-addresses
remote.ip_addresses
address-family
No REST Equivalent
auth-status-admin
availability
status.state
cluster-uuid
uuid
encryption-protocol
encryption.state
encryption.proposed
ipspace-name
ipspace.name
is-cluster-healthy
No REST Equivalent
last-updated
status.update_time
peer-addresses
remote.ip_addresses
psk-algorithm
No REST Equivalent
remote-cluster-name
remote.name
remote-cluster-nodes
No REST Equivalent
rpc-connect-timeout
No REST Equivalent
serial-number
remote.serial_number
timeout
No REST Equivalent
unreachable-local-nodes
No REST Equivalent
update-ping-timeout
No REST Equivalent
cluster-peer-get-iter
active-addresses
remote.ip_addresses
address-family
No REST Equivalent
auth-status-admin
availability
status.state
cluster-name
name
cluster-uuid
uuid
encryption-protocol
encryption.state
encryption.proposed
ipspace-name
ipspace.name
is-cluster-healthy
No REST Equivalent
last-updated
status.update_time
peer-addresses
remote.ip_addresses
psk-algorithm
No REST Equivalent
remote-cluster-name
remote.name
No REST Equivalent
rpc-connect-timeout
No REST Equivalent
serial-number
timeout
No REST Equivalent
No REST Equivalent
update-ping-timeout
No REST Equivalent
max-records
max_records
Specifies the maximum number of records to return before paging.
cluster-peer-health-info-get
cluster-peer-health-info-get-iter
cluster-peer-modify
address-family
No REST Equivalent
auth-status-admin
cluster-name
name
encryption.proposed
generate-passphrase
ipspace-name
ipspace.name
offer-expiration
passphrase
peer-addresses
remote.ip_addresses
rpc-connect-timeout
No REST Equivalent
timeout
No REST Equivalent
update-ping-timeout
No REST Equivalent
cluster-peer-modify-local-name
cluster-name
No REST Equivalent
new-name
name
cluster-peer-ping-iter
cluster-peer-policy-get
GET /api/cluster
is-unauthenticated-access-permitted
peering_policy.authentication_required
is-unencrypted-access-permitted
peering_policy.encryption_required
passphrase-minimum-length
peering_policy.minimum_passphrase_length
cluster-peer-policy-modify
cluster-peer-stable-addresses-get
