cluster-peer
cluster-peer-active-address-insert
PATCH /api/cluster/peers/{uuid}
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
| ONTAPI attribute | REST attribute | Comment |
active-address |
remote.ip_addresses |
cluster-name |
name |
cluster-peer-active-addresses-get
GET /api/cluster/peers
cluster-name |
name |
peer-addresses |
cluster-peer-active-addresses-register
Note: This is an unsupported ONTAPI operation.
This ONTAPI call does not have an equivalent REST API call.
cluster-peer-authn-offer-cancel
cluster-peer-authn-offer-get
GET /api/cluster/peers/{uuid}
auth-status-admin |
authentication.in_use |
auth-status-operational |
authentication.state |
encryption-protocol-proposed |
encryption.proposed |
initial-allowed-vserver-peers |
initial_allowed_svms |
offer-creation |
No REST Equivalent |
offer-expiration |
authentication.expiry_time |
peer-cluster-name |
name |
peer-cluster-uuid |
uuid |
cluster-peer-authn-offer-get-iter
auth-status-admin |
offer-creation |
offer-expiration |
peer-cluster-name |
name |
peer-cluster-uuid |
uuid |
max-records |
max_records |
Specifies the maximum number of records to return before paging |
cluster-peer-authn-offer-modify
offer-expiration |
peer-cluster-name |
name |
cluster-peer-connection-destroy
cluster-peer-connections-get
cluster-peer-connections-get-iter
cluster-peer-create
POST /api/cluster/peers
address-family |
applications |
peer_applications |
generate-passphrase |
authentication.generate_passphrase |
ipspace-name |
ipspace.name |
local-name |
remote.name |
offer-expiration |
passphrase |
authentication.passphrase |
password |
peer-addresses |
rpc-connect-timeout |
timeout |
update-ping-timeout |
user-name |
cluster-peer-delete
DELETE /api/cluster/peers/{uuid}
cluster-name |
cluster-peer-get
cluster-name |
name |
active-addresses |
address-family |
auth-status-admin |
availability |
status.state |
cluster-uuid |
uuid |
encryption-protocol |
encryption.state |
ipspace-name |
ipspace.name |
is-cluster-healthy |
last-updated |
status.update_time |
peer-addresses |
psk-algorithm |
remote-cluster-name |
remote.name |
remote-cluster-nodes |
serial-number |
remote.serial_number |
timeout |
unreachable-local-nodes |
cluster-peer-get-iter
active-addresses |
address-family |
auth-status-admin |
availability |
status.state |
cluster-name |
name |
cluster-uuid |
uuid |
encryption.state |
ipspace-name |
ipspace.name |
last-updated |
peer-addresses |
psk-algorithm |
remote.name |
serial-number |
timeout |
max-records |
max_records |
Specifies the maximum number of records to return before paging. |
cluster-peer-health-info-get
cluster-peer-health-info-get-iter
cluster-peer-modify
address-family |
auth-status-admin |
cluster-name |
name |
ipspace-name |
ipspace.name |
offer-expiration |
passphrase |
peer-addresses |
timeout |
cluster-peer-modify-local-name
cluster-name |
new-name |
name |
cluster-peer-ping-iter
cluster-peer-policy-get
GET /api/cluster
is-unauthenticated-access-permitted |
peering_policy.authentication_required |
is-unencrypted-access-permitted |
peering_policy.encryption_required |
passphrase-minimum-length |
peering_policy.minimum_passphrase_length |
cluster-peer-policy-modify
cluster-peer-stable-addresses-get
