ONTAP ONTAPI-to-REST mapping
fileservice-audit
fileservice-audit-config-create
POST /api/protocols/audit
Usage: This ONTAPI call can be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
destination
log_path
events
events
format
log.format
retention-duration
log.retention.duration
return-record
return_records
rotate-limit
log.retention.count
rotate-schedule-day
log.rotation.schedule.days
rotate-schedule-dayofweek
log.rotation.schedule.weekdays
rotate-schedule-hour
log.rotation.schedule.hours
rotate-schedule-minute
log.rotation.schedule.minutes
rotate-schedule-month
log.rotation.schedule.months
rotate-size
log.rotation.size
fileservice-audit-config-get
GET /api/protocols/audit/{svm.uuid}
audit-guarantee
guarantee
destination
log_path
events
events
format
log.format
is-enabled
enabled
retention-duration
rotate-limit
log.retention.count
rotate-schedule-day
rotate-size
log.rotation.size
rotation-schedule-description
No REST Equivalent
vserver
svm.name
fileservice-audit-config-get-iter
audit-guarantee
No REST Equivalent
destination
log_path
events
events
format
log.format
is-enabled
enabled
retention-duration
rotate-limit
log.retention.count
rotate-schedule-day
rotate-size
log.rotation.size
No REST Equivalent
vserver
svm.name
max-records
max_records
Specifies the maximum number of records to return before paging.
fileservice-audit-config-get-total-records
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
There are no attributes defined for this ONTAPI call.
fileservice-audit-config-modify
PATCH /api/protocols/audit/{svm.uuid}
audit-guarantee
guarantee
destination
log_path
events
events
format
log.format
retention-duration
rotate-limit
log.retention.count
rotate-schedule-day
rotate-size
log.rotation.size
fileservice-audit-disable
fileservice-audit-enable
force
No REST Equivalent
fileservice-audit-remove
DELETE /api/protocols/audit/{svm.uuid}
force
force
fileservice-audit-repair
This ONTAPI call does not have an equivalent REST API call.
fileservice-audit-rotate-log
