fileservice-audit
fileservice-audit-config-create
POST /api/protocols/audit
Usage: This ONTAPI call can be issued against Storage VM (SVM) management LIFs.
| ONTAPI attribute | REST attribute | Comment |
destination |
log_path |
events |
events |
format |
log.format |
retention-duration |
log.retention.duration |
return-record |
return_records |
rotate-limit |
No REST Equivalent |
rotate-schedule-day |
log.rotation.schedule.days |
rotate-schedule-dayofweek |
log.rotation.schedule.weekdays |
rotate-schedule-hour |
log.rotation.schedule.hours |
rotate-schedule-minute |
log.rotation.schedule.minutes |
rotate-schedule-month |
log.rotation.schedule.months |
rotate-size |
log.rotation.size |
fileservice-audit-config-get
GET /api/protocols/audit/{svm.uuid}
audit-guarantee |
destination |
log_path |
events |
events |
format |
log.format |
is-enabled |
enabled |
rotate-limit |
rotate-size |
log.rotation.size |
rotation-schedule-description |
vserver |
svm.name |
fileservice-audit-config-get-iter
audit-guarantee |
destination |
log_path |
events |
events |
format |
log.format |
is-enabled |
enabled |
rotate-limit |
rotate-size |
log.rotation.size |
vserver |
svm.name |
max-records |
max_records |
Specifies the maximum number of records to return before paging. |
fileservice-audit-config-get-total-records
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
There are no attributes defined for this ONTAPI call.
fileservice-audit-config-modify
PATCH /api/protocols/audit/{svm.uuid}
audit-guarantee |
destination |
log_path |
events |
events |
format |
log.format |
rotate-limit |
rotate-size |
log.rotation.size |
fileservice-audit-disable
fileservice-audit-enable
force |
fileservice-audit-remove
DELETE /api/protocols/audit/{svm.uuid}
force |
fileservice-audit-repair
This ONTAPI call does not have an equivalent REST API call.
fileservice-audit-rotate-log
