storage-switch
storage-switch-get
GET /api/storage/switches/{name}
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
| ONTAPI attribute | REST attribute | Comment |
blades |
blades |
domain-id |
domain_id |
fabric-name |
fabric_name |
firmware-version |
firmware_version |
ip-address |
ip_address |
is-director-class |
director_class |
is-local-attach |
local |
is-monitoring-enabled |
monitoring_enabled |
model |
model |
name |
name |
role |
role |
status |
state |
storage-switch-connectivity-list |
connections |
storage-switch-error-list |
errors |
storage-switch-fan-list |
fans |
storage-switch-path-list |
paths |
storage-switch-port-list |
ports |
storage-switch-port-statistics-list |
No REST Equivalent |
storage-switch-power-supply-unit-list |
power_supply_units |
storage-switch-sfp-list |
ports.sfp |
storage-switch-temperature-sensor-list |
temperature_sensors |
storage-switch-vsan-list |
vsans |
storage-switch-zone-list |
zones |
symbolic-name |
symbolic_name |
vendor |
vendor |
wwn |
wwn |
storage-switch-get-iter
blades |
blades |
domain-id |
domain_id |
fabric-name |
fabric_name |
firmware-version |
firmware_version |
ip-address |
ip_address |
is-director-class |
director_class |
is-local-attach |
local |
model |
model |
name |
name |
role |
role |
status |
state |
connections |
errors |
fans |
paths |
ports |
ports.sfp |
vsans |
zones |
symbolic-name |
symbolic_name |
vendor |
vendor |
wwn |
wwn |
max-records |
max_records |
Specifies the maximum number of records to return before paging. |
