storage-switch
storage-switch-get
GET /api/storage/switches/{name}
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
blades
blades
domain-id
domain_id
fabric-name
fabric_name
firmware-version
firmware_version
ip-address
ip_address
is-director-class
director_class
is-local-attach
local
is-monitoring-enabled
monitoring_enabled
model
model
name
name
role
role
status
state
storage-switch-connectivity-list
connections
storage-switch-error-list
errors
storage-switch-fan-list
fans
storage-switch-path-list
paths
storage-switch-port-list
ports
storage-switch-port-statistics-list
No REST Equivalent
storage-switch-power-supply-unit-list
power_supply_units
storage-switch-sfp-list
ports.sfp
storage-switch-temperature-sensor-list
temperature_sensors
storage-switch-vsan-list
vsans
storage-switch-zone-list
zones
symbolic-name
symbolic_name
vendor
vendor
wwn
wwn
storage-switch-get-iter
blades
blades
domain-id
domain_id
fabric-name
fabric_name
firmware-version
firmware_version
ip-address
ip_address
is-director-class
director_class
is-local-attach
local
monitoring_enabled
model
model
name
name
role
role
status
state
connections
errors
fans
paths
ports
No REST Equivalent
power_supply_units
ports.sfp
temperature_sensors
vsans
zones
symbolic-name
symbolic_name
vendor
vendor
wwn
wwn
max-records
max_records
Specifies the maximum number of records to return before paging.
