disk-encrypt
disk-encrypt-get
GET /api/storage/disks/{name}
| ONTAPI attribute | REST attribute | Comment |
data-key-id |
key_id.data |
disk-name |
name |
fips-key-id |
key_id.fips |
is-fips-certified |
fips_certified |
is-sed |
self_encrypting |
protection-mode |
protection_mode |
type |
type |
disk-encrypt-get-iter
GET /api/storage/disks?self_encrypting=true
data-key-id |
key_id.data |
disk-name |
name |
fips-key-id |
key_id.fips |
is-fips-certified |
fips_certified |
is-sed |
self_encrypting |
protection-mode |
protection_mode |
type |
type |
max-records |
max_records |
The maximum number of records to return before paging |
disk-encrypt-modify
This ONTAPI call does not have an equivalent REST API call.
disk-encrypt-modify-iter
PATCH /api/storage/disks
Note: REST only supports modifying data authentication key of all encrypting drives. encryption_operation query parameter must be supplied.
continue-on-failure |
No REST Equivalent |
data-key-id |
This is automatically generated in REST based on the encryption_operation query parameter |
fips-key-id |
max-failure-count |
max-records |
max_records |
disk-name |
is-fips-certified |
is-sed |
protection-mode |
type |
return-failure-list |
return-success-list |
disk-encrypt-sanitize
disk-encrypt-sanitize-iter
disk-encrypt-status-get
disk-encrypt-status-get-iter
