ONTAP ONTAPI-to-REST mapping
disk-encrypt
disk-encrypt-get
GET /api/storage/disks/{name}
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
data-key-id
key_id.data
disk-name
name
fips-key-id
key_id.fips
is-fips-certified
fips_certified
is-sed
self_encrypting
protection-mode
protection_mode
type
type
disk-encrypt-get-iter
GET /api/storage/disks?self_encrypting=true
data-key-id
key_id.data
disk-name
name
fips-key-id
key_id.fips
is-fips-certified
fips_certified
is-sed
self_encrypting
protection-mode
protection_mode
type
type
max-records
max_records
Specifies the maximum number of records to return before paging.
disk-encrypt-modify
This ONTAPI call does not have an equivalent REST API call.
disk-encrypt-modify-iter
PATCH /api/storage/disks
Note: This REST API only supports modifying the data authentication key of all encrypting drives. You must supply the "encryption_operation query" parameter.
continue-on-failure
No REST Equivalent
data-key-id
No REST Equivalent
Automatically generates in the REST API based on the encryption_operation query parameter.
fips-key-id
No REST Equivalent
max-failure-count
No REST Equivalent
max-records
max_records
disk-name
No REST Equivalent
is-fips-certified
No REST Equivalent
is-sed
No REST Equivalent
protection-mode
No REST Equivalent
type
No REST Equivalent
return-failure-list
No REST Equivalent
return-success-list
No REST Equivalent
disk-encrypt-sanitize
disk-encrypt-sanitize-iter
disk-encrypt-status-get
disk-encrypt-status-get-iter
