flash-device
flash-device-get-iter
GET /api/cluster/nodes/{uuid}
| ONTAPI attribute | REST attribute | Comment |
average-erase-cycle-count |
No REST Equivalent |
capacity |
controller.flash_cache.capacity |
The capacity is returned in bytes instead of GB. |
device-id |
firmware-file |
firmware-revision |
controller.flash_cache.firmware_version |
hardware-revision |
controller.flash_cache.hardware_revision |
last-change-time |
model-name |
controller.flash_cache.model |
node |
name |
part-number |
controller.flash_cache.part_number |
percent-online |
serial-number |
controller.flash_cache.serial_number |
service-time |
slot-number |
slot-string |
controller.flash_cache.slot |
status |
controller.flash_cache.state |
subslot-number |
threshold-profile |
max-records |
max_records |
The maximum number of records to return before paging |
flash-device-list-info
This ONTAPI call does not have an equivalent REST API call.
