flash-device
flash-device-get-iter
GET /api/cluster/nodes/{uuid}
Usage: This ONTAPI call cannot be issued against Storage VM (SVM) management LIFs.
ONTAPI attribute REST attribute Comment
average-erase-cycle-count
No REST Equivalent
capacity
controller.flash_cache.capacity
In the REST API, capacity is returned in bytes instead of GB.
device-id
No REST Equivalent
firmware-file
No REST Equivalent
firmware-revision
controller.flash_cache.firmware_version
hardware-revision
controller.flash_cache.hardware_revision
last-change-time
No REST Equivalent
model-name
controller.flash_cache.model
node
name
part-number
controller.flash_cache.part_number
percent-online
No REST Equivalent
serial-number
controller.flash_cache.serial_number
service-time
No REST Equivalent
slot-number
No REST Equivalent
slot-string
controller.flash_cache.slot
status
controller.flash_cache.state
subslot-number
No REST Equivalent
threshold-profile
No REST Equivalent
max-records
max_records
Specifies the maximum number of records to return before paging.
flash-device-list-info
This ONTAPI call does not have an equivalent REST API call.
