ONTAP SAN Host Utilities
Configure Rocky Linux 9.x for FCP and iSCSI with ONTAP storage
Contributors netapp-pcarriga netapp-camdenc
The Linux Host Utilities software provides management and diagnostic tools for Linux hosts that are connected to ONTAP storage. When you install Linux Host Utilities on a Rocky Linux 9.x host, you can use the Host Utilities to help you manage FCP and iSCSI protocol operations with ONTAP LUNs.
Step 1: Optionally, enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability.
Before you begin
Use the Interoperability Matrix Tool to verify that your Linux OS, host bus adapter (HBA), HBA firmware, HBA boot BIOS, and ONTAP version support SAN booting.
Steps
  1. Create a SAN boot LUN and map it to the host.
  2. Enable SAN booting in the server BIOS for the ports to which the SAN boot LUN is mapped.
    For information on how to enable the HBA BIOS, see your vendor-specific documentation.
  3. Verify that the configuration was successful by rebooting the host and verifying that the OS is up and running.
Step 2: Install the Linux Host Utilities
NetApp strongly recommends installing the Linux Host Utilities to support ONTAP LUN management and assist technical support with gathering configuration data.
Rocky Linux is a RHEL-compatible distribution and does not have a separate Linux Host Utilities package. Use the Linux Host Utilities package for the corresponding RHEL version.
Note Installing the Linux Host Utilities doesn't change any host timeout settings on your Linux host.
Step 3: Confirm the multipath configuration for your host
You can use multipathing with Rocky Linux 9.x to manage ONTAP LUNs.
To ensure that multipathing is configured correctly for your host, verify that the /etc/multipath.conf file is defined and that you have the NetApp recommended settings configured for your ONTAP LUNs.
Steps
  1. Verify that the /etc/multipath.conf file exits. If the file doesn't exist, create an empty, zero-byte file:
    touch /etc/multipath.conf
  2. The first time the multipath.conf file is created, you might need to enable and start the multipath services to load the recommended settings:
    systemctl enable multipathd
    systemctl start multipathd
  3. Each time you boot the host, the empty /etc/multipath.conf zero-byte file automatically loads the NetApp recommended host multipath parameters as the default settings. You shouldn't need to make changes to the /etc/multipath.conf file for your host because the operating system is compiled with the multipath parameters that recognize and manage ONTAP LUNs correctly.
    The following table shows the Linux OS native compiled multipath parameter settings for ONTAP LUNs.
    Show parameter settings
    Parameter Setting
    detect_prio
    yes
    dev_loss_tmo
    "infinity"
    failback
    immediate
    fast_io_fail_tmo
    5
    features
    "2 pg_init_retries 50"
    flush_on_last_del
    "yes"
    hardware_handler
    "0"
    no_path_retry
    queue
    path_checker
    "tur"
    path_grouping_policy
    "group_by_prio"
    path_selector
    "service-time 0"
    polling_interval
    5
    prio
    "ontap"
    product
    LUN
    retain_attached_hw_handler
    yes
    rr_weight
    "uniform"
    user_friendly_names
    no
    vendor
    NETAPP
  4. Verify the parameter settings and path status for your ONTAP LUNs:
    multipath -ll
    The default multipath parameters support ASA, AFF, and FAS configurations. In these configurations, a single ONTAP LUN shouldn't require more than four paths. Having more than four paths can cause problems during a storage failure.
    The following example outputs show the correct parameter settings and path status for ONTAP LUNs in an ASA, AFF, or FAS configuration.
    ASA configuration
    An ASA configuration optimizes all paths to a given LUN, keeping them active. This improves performance by serving I/O operations through all paths at the same time.
    Show example
    multipath -ll
    3600a098038314c4a433f577471797958 dm-2 NETAPP,LUN C-Mode
    size=180G features='3 queue_if_no_path pg_init_retries 50' hwhandler='1 alua' wp=rw
    `-+- policy='service-time 0' prio=50 status=active
      |- 14:0:0:0  sdc  8:32   active ready running
      |- 17:0:0:0  sdas 66:192 active ready running
      |- 14:0:3:0  sdar 66:176 active ready running
      `- 17:0:3:0  sdch 69:80  active ready running
    AFF or FAS configuration
    An AFF or FAS configuration should have two groups of paths with higher and lower priorities. Higher priority Active/Optimized paths are served by the controller where the aggregate is located. Lower priority paths are active but non-optimized because they are served by a different controller. Non-optimized paths are only used when optimized paths aren’t available.
    The following example displays the output for an ONTAP LUN with two Active/Optimized paths and two Active/Non-Optimized paths:
    Show example
    multipath -ll
    3600a0980383149764b5d567257516273 dm-0 NETAPP,LUN C-Mode
    size=150G features='3 queue_if_no_path pg_init_retries 50' hwhandler='1 alua' wp=rw
    | |- 16:0:3:0  sdcg 69:64  active ready running
    | `- 10:0:0:0  sdb  8:16   active ready running
    `-+- policy='service-time 0' prio=10 status=enabled
      |- 10:0:1:0  sdc  8:32   active ready running
      `- 16:0:2:0  sdcf 69:48  active ready running
Step 4: Confirm the iSCSI configuration for your host
Ensure that iSCSI is configured correctly for your host.
About this task
You perform the following steps on the iSCSI host.
Steps
  1. Verify that the iSCSI initiator package (iscsi-initiator-utils) is installed:
    rpm -qa | grep iscsi-initiator-utils
    You should see an output similar to the following example:
    iscsi-initiator-utils-6.2.1.11-0.git4b3e853.el9.x86_64
  2. Verify the iSCSI initiator node name, which is located in the /etc/iscsi/initiatorname.iscsi file:
    InitiatorName=iqn.YYYY-MM.com.<vendor>:<host_name>
  3. Configure the iSCSI session timeout parameter located in the /etc/iscsi/iscsid.conf file:
    node.session.timeo.replacement_timeout = 5
    The iSCSI replacement_timeout parameter controls how long the iSCSI layer should wait for a timed-out path or session to reestablish itself before failing any commands on it. You should set the value of replacement_timeout to 5 in the iSCSI configuration file.
  4. Enable the iSCSI service:
    $systemctl enable iscsid
  5. Start the iSCSI service:
    $systemctl start iscsid
  6. Verify that the iSCSI service is running:
    $systemctl status iscsid
    Show example
    ● iscsid.service - Open-iSCSI
         Loaded: loaded (/usr/lib/systemd/system/iscsid.service; enabled; preset: disabled)
         Active: active (running) since Tue 2025-12-02 11:36:21 EST; 2 weeks 1 day ago
    TriggeredBy: ● iscsid.socket
           Docs: man:iscsid(8)
                 man:iscsiuio(8)
                 man:iscsiadm(8)
       Main PID: 2263 (iscsid)
         Status: "Ready to process requests"
          Tasks: 1 (limit: 816061)
         Memory: 18.5M
            CPU: 14.480s
         CGroup: /system.slice/iscsid.service
                 └─2263 /usr/sbin/iscsid -f -d2
  7. Discover the iSCSI targets:
    $iscsiadm --mode discovery --op update --type sendtargets --portal <target_IP>
    show example
    iscsiadm --mode discovery --op update --type sendtargets --portal  192.168.30.87
    192.168.30.87:3260,1139 iqn.1992-08.com.netapp:sn.064a9b19b3ee11f09dcad039eabac370:vs.23
    192.168.31.97:3260,1142 iqn.1992-08.com.netapp:sn.064a9b19b3ee11f09dcad039eabac370:vs.23
    192.168.31.87:3260,1141 iqn.1992-08.com.netapp:sn.064a9b19b3ee11f09dcad039eabac370:vs.23
    192.168.30.97:3260,1140 iqn.1992-08.com.netapp:sn.064a9b19b3ee11f09dcad039eabac370:vs.23
  8. Log in to the targets:
    $iscsiadm --mode node -l all
  9. Set iSCSI to log in automatically when the host boots:
    $iscsiadm --mode node -T <target_name> -p <ip:port> -o update -n node.startup -v automatic
    Replace <target_name> with the target name that you want to log in to automatically when the host boots. Replace <ip:port> with the IP address and port number of the target. For example:
    iscsiadm --mode node -T iqn.1992-08.com.netapp:sn.064a9b19b3ee11f09dcad039eabac370:vs.23 -p 192.168.30.87:3260 -o update -n node.startup -v automatic
  10. Verify the iSCSI sessions:
    $iscsiadm --mode session
    Show example
    tcp: [1] 192.168.30.87:3260,1139 iqn.1992-08.com.netapp:sn.064a9b19b3ee11f09dcad039eabac370:vs.23 (non-flash)
    tcp: [2] 192.168.31.97:3260,1142 iqn.1992-08.com.netapp:sn.064a9b19b3ee11f09dcad039eabac370:vs.23 (non-flash)
    tcp: [3] 192.168.31.87:3260,1141 iqn.1992-08.com.netapp:sn.064a9b19b3ee11f09dcad039eabac370:vs.23 (non-flash)
    tcp: [4] 192.168.30.97:3260,1140 iqn.1992-08.com.netapp:sn.064a9b19b3ee11f09dcad039eabac370:vs.23 (non-flash)
Step 5: Optionally, exclude a device from multipathing
If required, you can exclude a device from multipathing by adding the WWID for the unwanted device to the "blacklist" stanza for the multipath.conf file.
Steps
  1. Determine the WWID:
    /lib/udev/scsi_id -gud /dev/sda
    "sda" is the local SCSI disk that you want to add to the blacklist.
    An example WWID is 360030057024d0730239134810c0cb833.
  2. Add the WWID to the "blacklist" stanza:
    blacklist {
            wwid   360030057024d0730239134810c0cb833
            devnode "^(ram|raw|loop|fd|md|dm-|sr|scd|st)[0-9]*"
            devnode "^hd[a-z]"
            devnode "^cciss.*"
Step 6: Customize multipath parameters for ONTAP LUNs
If your host is connected to LUNs from other vendors and any of the multipath parameter settings are overridden, you need to correct them by either modifying an existing stanza or adding a new stanza in the multipath.conf file that applies specifically to ONTAP LUNs. You need to scroll down in the file to review the changes that apply to your host. If you don't correct the parameters, the ONTAP LUNs might not work as expected.
Check your /etc/multipath.conf file, especially in the defaults section, for settings that might be overriding the default settings for multipath parameters.
Caution You shouldn't override the recommended parameter settings for ONTAP LUNs. These settings are required for optimal performance of your host configuration. Contact NetApp support, your OS vendor, or both for more information.
The following example shows how to correct an overridden default. In this example, the multipath.conf file defines values for path_checker and no_path_retry that aren't compatible with ONTAP LUNs, and you can't remove these parameters because ONTAP storage arrays are still attached to the host. Instead, you correct the values for path_checker and no_path_retry by adding a device stanza to the multipath.conf file that applies specifically to the ONTAP LUNs.
Show example
defaults {
   path_checker      readsector0
   no_path_retry     fail
devices {
   device {
      vendor          "NETAPP"
      product         "LUN"
      no_path_retry   queue
      path_checker    tur
Step 7: Review the known issues
Rocky Linux 9.x with ONTAP storage has the following known issues.
9.3
NetApp Bug ID Title Description JIRA ID
1508554
NetApp Linux Host Utilities CLI requires additional library package dependencies to support Emulex host bus adapter (HBA) adapter discovery
In RHEL 9.x, the NetApp Linux SAN Host Utilities CLI sanlun fcp show adapter -v fails because the library package dependencies to support Emulex host bus adapter (HBA) discovery cannot be found.
Not applicable
1593771
A Red Hat Enterprise Linux 9.3 QLogic SAN host encounters loss of partial multipaths during storage mobility operations
During the ONTAP storage controller takeover operation, half of the multipaths are expected to go down or switch to a failover mode and then recover to full path count during the giveback workflow. However, with a Red Hat Enterprise Linux (RHEL) 9.3 QLogic host, only partial multipaths are recovered after a storage failover giveback operation.
RHEL 17811
9.2
1508554
NetApp Linux Host Utilities CLI requires additional library package dependencies to support Emulex HBA adapter discovery
In RHEL 9.2, the NetApp Linux SAN Host Utilities CLI sanlun fcp show adapter -v fails because the library package dependencies to support HBA discovery cannot be found.
1537359
A Red Hat Linux 9.2 SAN booted host with Emulex HBA encounters stalled tasks leading to kernel disruption
During a storage failover giveback operation, a Red Hat Linux 9.2 SAN booted host with an Emulex host bus adapeter (HBA) encounters stalled tasks leading to kernel disruption. The kernel disruption causes the operating system to reboot and if kdump is configured, it generates the vmcore file under the /var/crash/ directory. The issue is being triaged with the lpfc driver but it cannot be reproduced consistently.
9.1
1508554
In Rocky Linux 9.1, the NetApp Linux SAN Host Utilities CLI sanlun fcp show adapter -v fails because the library package dependencies to support HBA discovery cannot be found.
What's next
  • Learn about using the Linux Host Utilities tool.
  • Learn about ASM mirroring
    Automatic Storage Management (ASM) mirroring might require changes to the Linux multipath settings to allow ASM to recognize a problem and switch over to an alternate failure group. Most ASM configurations on ONTAP use external redundancy, which means that data protection is provided by the external array and ASM doesn't mirror data. Some sites use ASM with normal redundancy to provide two-way mirroring, normally across different sites. See Oracle databases on ONTAP for further information.
  • Learn about Rocky Linux Virtualization (KVM)
    Rocky Linux can serve as a KVM host. This enables you to run multiple virtual machines on a single physical server using the Linux Kernel-based Virtual Machine (KVM) technology. The KVM host doesn't require explicit host configuration settings for ONTAP LUNs.
