Configure Solaris 11.3 for FCP and iSCSI with ONTAP storage
The Solaris Host Utilities software provides management and diagnostic tools for Solaris hosts that are connected to ONTAP storage. When you install the Solaris Host Utilities on a Solaris 11.3 host, you can use the Host Utilities to help you manage FCP and iSCSI protocol operations with ONTAP LUNs.
Step 1: Optionally, enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability. If your configuration doesn't support SAN booting, you can use a local boot.
SAN booting is the process of setting up a SAN-attached disk (a LUN) as a boot device for a Solaris host. You can set up a SAN boot LUN to work in a Solaris MPxIO environment that is using the FC protocol and running Solaris Host Utilities. The method you use to set up a SAN boot LUN depends on your volume manager and file system.
Use the Interoperability Matrix Tool to verify that your Solaris OS, protocol, and ONTAP version support SAN booting.
Follow the best practices for setting up a SAN boot in the Solaris vendor documentation.
Perform a local boot by installing the Solaris OS on the local hard disk, for example, install on an SSD, SATA, or RAID.
Step 2: Install the Solaris Host Utilities
NetApp strongly recommends installing the Solaris Host Utilities to support ONTAP LUN management and assist technical support with gathering configuration data.
Installing the Solaris Host Utilities changes some of the timeout settings on your Solaris host. |
Step 3: Confirm the multipath configuration for your host
You can use multipathing with Solaris 11.3 to manage ONTAP LUNs.
Multipathing enables you to configure multiple network paths between the host and storage systems. If one path fails, traffic continues on the remaining paths.
The Solaris Host Utilities load the NetApp recommended parameter settings for SPARC and x86_64 processors.
Show parameter settings
Parameter Value throttle_max
8
not_ready_retries
300
busy_retries
30
reset_retries
30
throttle_min
2
timeout_retries
10
physical_block_size
4096
disksort
false
cache-nonvolatile
true
If your storage configuration includes MetroCluster, Oracle Solaris virtualization, or SnapMirror active sync, change the default settings:
MetroClusterBy default, the Solaris OS fails to execute the I/O operations after 20s if all paths to a LUN are lost. This is controlled by the
fcp_offline_delayparameter. The default value forfcp_offline_delayis the appropriate for standard ONTAP clusters. However, in MetroCluster configurations, you must increase the value offcp_offline_delayto 120s to ensure that I/O doesn't prematurely time out during operations, including unplanned failovers.For additional information and recommended changes to default settings for MetroCluster, see the Knowledge Base article Solaris host support considerations in a MetroCluster configuration.
Oracle Solaris virtualization-
Solaris virtualization options include Solaris Logical Domains (also called LDOMs or Oracle VM Server for SPARC), Solaris Dynamic Domains, Solaris Zones, and Solaris Containers. These technologies are also referred to as "Oracle Virtual Machines".
You can use multiple options together, for example, a Solaris Container within a particular Solaris Logical Domain.
NetApp supports the use of Solaris virtualization technologies where the overall configuration is supported by Oracle and any partition with direct access to LUNs is listed on the IMT in a supported configuration. This includes root containers, LDOM I/O domains, and LDOM using NPIV to access LUNs.
Partitions or virtual machines that use only virtualized storage resources, such as a
vdsk, don't need specific qualifications because they don't have direct access to ONTAP LUNs. You only need to verify that the partition or virtual machine that has direct access to the underlying LUN, such as an LDOM I/O domain, is listed on the IMT.
StepsWhen LUNs are used as virtual disk devices within an LDOM, the source of the LUN is masked by virtualization and the LDOM doesn't correctly detect the block sizes. To prevent this issue:
Patch the LDOM OS for Oracle Bug 15824910
Create a
vdc.conffile that sets the block size of the virtual disk to4096. See Oracle DOC: 2157669.1 for more information. -
Verify the patch installation to ensure that the recommended settings have been configured correctly:
Create a zpool:
zpool create zpool_name disk_list -
Run
zdb -Cagainst the zpool and verify that the value of ashift is12.If the value of ashift isn't
12, re runzdb -C11, and verify that the correct patch was installed and recheck the contents ofvdc.conf.Don't proceed until ashift shows a value of
12.
Patches are available for Oracle bug 15824910 on several Solaris versions. Contact Oracle if you need assistance in determining the best kernel patch. SnapMirror active syncBeginning with ONTAP 9.9.1, SnapMirror active sync setting configurations are supported in the Solaris host. To verify that the Solaris client applications are non-disruptive when an unplanned site failover switchover occurs in a SnapMirror active sync environment, you must configure the
scsi-vhci-failover-overridesetting on the Solaris host. This setting overrides the failover modulef_tpgsto prevent the execution of the code path that detects the contradiction.Steps-
Create the configuration file
/etc/driver/drv/scsi_vhci.confwith an entry similar to the following example for the NetApp storage type connected to the host:scsi-vhci-failover-override = "NETAPP LUN","f_tpgs"
Verify that the override parameter has been successfully applied:
devpropmdbShow examples
root@host-A:~# devprop -v -n /scsi_vhci scsi-vhci-failover-override scsi-vhci-failover-override=NETAPP LUN + f_tpgs root@host-A:~# echo "*scsi_vhci_dip::print -x struct dev_info devi_child | ::list struct dev_info devi_sibling| ::print struct dev_info devi_mdi_client| ::print mdi_client_t ct_vprivate| ::print struct scsi_vhci_lun svl_lun_wwn svl_fops_name"| mdb -k
svl_lun_wwn = 0xa002a1c8960 "600a098038313477543f524539787938" svl_fops_name = 0xa00298d69e0 "conf f_tpgs"
After scsi-vhci-failover-overridehas been applied,confis added tosvl_fops_name. For additional information and recommended changes to default settings, refer to the NetApp Knowledge Base article Solaris Host support recommended settings in SnapMirror active sync configuration. -
Verify that 4KB aligned I/O with zpools using ONTAP LUNs is supported:
Verify that your Solaris host is installed with the latest Support Repository Update (SRU):
pkg info entire -
Verify that the ONTAP LUN has
ostypeas "Solaris", independent of the LUN size:lun show -vserver` <vsersver_name>Show example
chat-a800-31-33-35-37::*> lun show -vserver solaris_fcp -path /vol/sol_195_zpool_vol_9/lun -fields ostype vserver path ostype ----------- ---------------------------- ------- solaris_fcp /vol/sol_195_zpool_vol_9/lun solaris
Verify the output for your ONTAP LUNs:
sanlun lun showYou should see an output similar to the following example for an ASA, AFF, or FAS configuration:
Show example
root@sparc-s7-55-148:~# sanlun lun show -pv ONTAP Path: Solaris_148_siteA:/vol/Triage/lun LUN: 0 LUN Size: 20g Host Device: /dev/rdsk/c0t600A098038314B32685D573064776172d0s2 Mode: C Multipath Provider: Sun Microsystems Multipath Policy: Native -
Verify the path status for your ONTAP LUNs:
mpathadm show lu <LUN>The following example outputs show the correct path status for ONTAP LUNs in an ASA, AFF, or FAS configuration. The path priorities are displayed against "Access State" for each LUN in the output.
ASA configurationsAn ASA configuration optimizes all paths to a given LUN, keeping them active. This improves performance by serving I/O operations through all paths at the same time.
Show example
root@sparc-s7-55-82:~# mpathadm show lu /dev/rdsk/c0t600A098038313953495D58674777794Bd0s2 Logical Unit: /dev/rdsk/c0t600A098038313953495D58674777794Bd0s2 mpath-support: libmpscsi_vhci.so Vendor: NETAPP Product: LUN C-Mode Revision: 9171 Name Type: unknown type Name: 600a098038313953495d58674777794b Asymmetric: yes Current Load Balance: round-robin Logical Unit Group ID: NA Auto Failback: on Auto Probing: NA Paths: Initiator Port Name: 100000109bd30070 Target Port Name: 20b9d039ea593393 Logical Unit Number: 0 Override Path: NA Path State: OK Disabled: no Initiator Port Name: 100000109bd30070 Target Port Name: 20b8d039ea593393 Logical Unit Number: 0 Override Path: NA Path State: OK Disabled: no Initiator Port Name: 100000109bd3006f Target Port Name: 20b3d039ea593393 Logical Unit Number: 0 Override Path: NA Path State: OK Disabled: no Initiator Port Name: 100000109bd3006f Target Port Name: 20b4d039ea593393 Logical Unit Number: 0 Override Path: NA Path State: OK Disabled: no Target Port Groups: ID: 1003 Explicit Failover: no Access State: active optimized Target Ports: Name: 20b9d039ea593393 Relative ID: 8 Name: 20b4d039ea593393 Relative ID: 3 ID: 1002 Explicit Failover: no Access State: active optimized Target Ports: Name: 20b8d039ea593393 Relative ID: 7 Name: 20b3d039ea593393 Relative ID: 2AFF or FAS configurationAn AFF or FAS configuration should have two groups of paths with higher and lower priorities. Higher priority Active/Optimized paths are served by the controller where the aggregate is located. Lower priority paths are active but non-optimized because they are served by a different controller. Non-optimized paths are only used when optimized paths aren’t available.
The following example displays the correct output for an ONTAP LUN with two Active/Optimized paths and two Active/Non-Optimized paths:
Show example
root@chatsol-54-195:~# mpathadm show lu /dev/rdsk/c0t600A0980383044376C3F4E694E506E44d0s2 Logical Unit: /dev/rdsk/c0t600A0980383044376C3F4E694E506E44d0s2 mpath-support: libmpscsi_vhci.so Vendor: NETAPP Product: LUN C-Mode Revision: 9171 Name Type: unknown type Name: 600a0980383044376c3f4e694e506e44 Asymmetric: yes Current Load Balance: round-robin Logical Unit Group ID: NA Auto Failback: on Auto Probing: NA Paths: Initiator Port Name: 100000109b56c5fb Target Port Name: 205200a098ba7afe Logical Unit Number: 1 Override Path: NA Path State: OK Disabled: no Initiator Port Name: 100000109b56c5fb Target Port Name: 205000a098ba7afe Logical Unit Number: 1 Override Path: NA Path State: OK Demoted: yes Disabled: no Initiator Port Name: 100000109b56c5fa Target Port Name: 204f00a098ba7afe Logical Unit Number: 1 Override Path: NA Path State: OK Demoted: yes Disabled: no Initiator Port Name: 100000109b56c5fa Target Port Name: 205100a098ba7afe Logical Unit Number: 1 Override Path: NA Path State: OK Disabled: no Target Port Groups: ID: 1001 Explicit Failover: no Access State: active not optimized Target Ports: Name: 205200a098ba7afe Relative ID: 8 Name: 205100a098ba7afe Relative ID: 7 ID: 1000 Explicit Failover: no Access State: active optimized Target Ports: Name: 205000a098ba7afe Relative ID: 6 Name: 204f00a098ba7afe Relative ID: 5
Step 4: Review the known issues
The Solaris 11.3 release for FCP and iSCSI with ONTAP storage has the following known issues:
| NetApp Bug ID | Title | Description | Oracle ID |
Solaris LIF problem during GB with Emulex 32G HBA on x86 Arch |
Seen with Emulex Firmware version 12.6.x and later on x86_64 Platform |
SR 3-24746803021 |
Solaris 11.x 'cfgadm -c configure' resulting in I/O error with End-to-End Emulex configuration |
Running |
Not Applicable |
