Configure Oracle Linux 9.5 with NVMe-oF for ONTAP storage
Red Hat Enterpirse Linux (RHEL) hosts support the NVMe over Fibre Channel (NVMe/FC) and NVMe over TCP (NVMe/TCP) protocols with Asymmetric Namespace Access (ANA). ANA provides multipathing functionality equivalent to asymmetric logical unit access (ALUA) in iSCSI and FCP environments.
The following support and features are available with the NVMe-oF host configuration for Oracle Linux 9.5 with ONTAP storage.
Support available:
Support for NVMe over TCP (NVMe/TCP) in addition to NVMe over Fibre Channel (NVMe/FC). The NetApp plug-in in the native nvme-cli package displays ONTAP details for both NVMe/FC and NVMe/TCP namespaces.
Running both NVMe and SCSI traffic on the same host. For example, you can configure dm-multipath on SCSI mpath devices for SCSI LUNs and use NVMe multipath to configure NVMe-oF namespace devices on the host.
Oracle Linux 9.5 enables in-kernel NVMe multipath for NVMe namespaces by default, removing the need for explicit settings.
Beginning with ONTAP 9.12.1, support for secure in-band authentication is introduced for NVMe/TCP. You can use secure in-band authentication for NVMe/TCP with Oracle Linux 9.5.
The NetApp sanlunhost utility isn't supported for NVMe-oF. Instead, you can use the NetApp plug-in included in the nativenvme-clifor all NVMe-oF transports.For additional details on supported configurations, see the Interoperability Matrix Tool.
Features available:
There are no new features in this release.
Known limitations:
Avoid issuing the
nvme disconnect-allcommand on systems booting from SAN over NVMe-TCP or NVMe-FC namespaces because it disconnects both root and data filesystems and might lead to system instability.
Step 1: Optionally, enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability. Use the Interoperability Matrix Tool to verify that your Linux OS, host bus adapter (HBA), HBA firmware, HBA boot BIOS, and ONTAP version support SAN booting.
Enable SAN booting in the server BIOS for the ports to which the SAN boot namespace is mapped.
For information on how to enable the HBA BIOS, see your vendor-specific documentation.
Reboot the host and verify that the OS is up and running.
Step 2: Validate software versions
Use the following procedure to validate the minimum supported Oracle Linux 9.5 software versions.
Install Oracle Linux 9.5 on the server. After the installation is complete, verify that you are running the specified Oracle Linux 9.5 kernel.
uname -rThe following example shows an Oracle Linux kernel version:
5.15.0-302.167.6.el9uek.x86_64
Install the
nvme-clipackage:rpm -qa|grep nvme-cliThe following example shows an
nvme-clipackage version:nvme-cli-2.9.1-6.el9.x86_64
Install the
libnvmepackage:rpm -qa|grep libnvmeThe following example shows an
libnvmepackage version:libnvme-1.9-3.el9.x86_64
On the Oracle Linux 9.5 host, check the
hostnqnstring at/etc/nvme/hostnqn:cat /etc/nvme/hostnqnThe following example shows an
hostnqnversion:nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0050-3410-8035-c2c04f4a5933
Verify that the
hostnqnstring matches thehostnqnstring for the corresponding subsystem on the ONTAP array:vserver nvme subsystem host show -vserver vs_213_36002Show example
Vserver Subsystem Priority Host NQN ------- --------- -------- ------------------------------------------------ vs_coexistence_LPE36002 nvme1 regular nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0050-3410-8035-c2c04f4a5933 nvme2 regular nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0050-3410-8035-c2c04f4a5933 nvme3 regular nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0050-3410-8035-c2c04f4a5933 nvme4 regular nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0050-3410-8035-c2c04f4a5933 4 entries were displayed.If the hostnqnstrings don't match, you can use thevserver modifycommand to update thehostnqnstring on your corresponding ONTAP array subsystem to match thehostnqnstring from/etc/nvme/hostnqnon the host.
Step 3: Configure NVMe/FC
Configure NVMe/FC with Broadcom/Emulex FC or Marvell/Qlogic FC adapters.
Configure NVMe/FC for a Broadcom/Emulex adapter.
Verify that you're using the supported adapter model:
Display the model names:
cat /sys/class/scsi_host/host*/modelnameYou should see the following output:
LPe36002-M64 LPe36002-M64
Display the model descriptions:
cat /sys/class/scsi_host/host*/modeldescYou should see an output similar to the following example:
Emulex LightPulse LPe36002-M64 2-Port 64Gb Fibre Channel Adapter Emulex LightPulse LPe36002-M64 2-Port 64Gb Fibre Channel Adapter
Verify that you are using the recommended Broadcom
lpfcfirmware and inbox driver:-
Display the firmware version:
cat /sys/class/scsi_host/host*/fwrevThe following example shows firmware versions:
14.4.393.25, sli-4:6:d 14.4.393.25, sli-4:6:d
Display the inbox driver version:
cat /sys/module/lpfc/versionThe following example shows a driver version:
0:14.4.0.2
For the current list of supported adapter driver and firmware versions, see the Interoperability Matrix Tool.
Verify that
lpfc_enable_fc4_typeis set to3:cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type -
Verify that you can view your initiator ports:
cat /sys/class/fc_host/host*/<port_name>The following example shows port identities:
0x100000620b3c089c 0x100000620b3c089d
Verify that your initiator ports are online:
cat /sys/class/fc_host/host*/port_stateYou should see the following output:
Online Online
Verify that the NVMe/FC initiator ports are enabled and that the target ports are visible:
cat /sys/class/scsi_host/host*/nvme_infoShow example
NVME Initiator Enabled XRI Dist lpfc0 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc0 WWPN x100000620b3c089c WWNN x200000620b3c089c DID x081300 ONLINE NVME RPORT WWPN x2001d039eab0dadc WWNN x2000d039eab0dadc DID x080101 TARGET DISCSRVC ONLINE NVME RPORT WWPN x2003d039eab0dadc WWNN x2000d039eab0dadc DID x080401 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 00000002e9 Cmpl 00000002e9 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 0000000000078742 Issue 0000000000078740 OutIO fffffffffffffffe abort 000000c2 noxri 00000000 nondlp 00000a23 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 000000c2 Err 00000238 NVME Initiator Enabled XRI Dist lpfc1 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc1 WWPN x100000620b3c089d WWNN x200000620b3c089d DID x081900 ONLINE NVME RPORT WWPN x2002d039eab0dadc WWNN x2000d039eab0dadc DID x080201 TARGET DISCSRVC ONLINE NVME RPORT WWPN x2004d039eab0dadc WWNN x2000d039eab0dadc DID x080301 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 00000002d9 Cmpl 00000002d9 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000000007754f Issue 000000000007754f OutIO 0000000000000000 abort 000000c2 noxri 00000000 nondlp 00000719 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 000000c2 Err 0000023d
Configure NVMe/FC for a Marvell/QLogic adapter.
Verify that you are running the supported adapter driver and firmware versions:
cat /sys/class/fc_host/host*/symbolic_nameThe follow example shows driver and firware versions:
QLE2772 FW:v9.15.03 DVR:v10.02.09.300-k-debug
Verify that
ql2xnvmeenableis set. This enables the Marvell adapter to function as an NVMe/FC initiator:cat /sys/module/qla2xxx/parameters/ql2xnvmeenableThe value
1verifies thatql2xnvmeenableis set.
Step 4: Optionally, enable 1MB I/O for NVMe/FC
ONTAP reports a Max Data Transfer Size (MDTS) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
These steps don't apply to Qlogic NVMe/FC hosts. |
Set the
lpfc_sg_seg_cntparameter to 256:cat /etc/modprobe.d/lpfc.confYou should see an output similar to the following example:
options lpfc lpfc_sg_seg_cnt=256
Run the
dracut -fcommand, and reboot the host. -
Verify that the value for
lpfc_sg_seg_cntis 256:cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Step 5: Verify NVMe boot services
With Oracle Linux 9.5, the nvmefc-boot-connections.service and nvmf-autoconnect.service boot services included in the NVMe/FC nvme-cli package are automatically enabled when the system boots.
After booting completes, verify that the nvmefc-boot-connections.service and nvmf-autoconnect.service boot services are enabled.
Verify that
nvmf-autoconnect.serviceis enabled:systemctl status nvmf-autoconnect.serviceShow example output
nvmf-autoconnect.service - Connect NVMe-oF subsystems automatically during boot Loaded: loaded (/usr/lib/systemd/system/nvmf-autoconnect.service; enabled; preset: disabled) Active: inactive (dead) since Wed 2025-07-02 16:46:37 IST; 1 day 3h ago Main PID: 2129 (code=exited, status=0/SUCCESS) CPU: 121ms Jul 02 16:46:37 interop-13-175 nvme[2129]: Failed to write to /dev/nvme-fabrics: Invalid argument Jul 02 16:46:37 interop-13-175 nvme[2129]: Failed to write to /dev/nvme-fabrics: Invalid argument Jul 02 16:46:37 interop-13-175 nvme[2129]: Failed to write to /dev/nvme-fabrics: Invalid argument Jul 02 16:46:37 interop-13-175 nvme[2129]: Failed to write to /dev/nvme-fabrics: Invalid argument Jul 02 16:46:37 interop-13-175 nvme[2129]: Failed to write to /dev/nvme-fabrics: Invalid argument Jul 02 16:46:37 interop-13-175 nvme[2129]: Failed to write to /dev/nvme-fabrics: Invalid argument Jul 02 16:46:37 interop-13-175 nvme[2129]: Failed to open ctrl nvme0, errno 2 Jul 02 16:46:37 interop-13-175 nvme[2129]: failed to get discovery log: Bad file descriptor Jul 02 16:46:37 interop-13-175 systemd[1]: nvmf-autoconnect.service: Deactivated successfully. Jul 02 16:46:37 interop-13-175 systemd[1]: Finished Connect NVMe-oF subsystems automatically during boot.
Verify that
nvmefc-boot-connections.serviceis enabled:systemctl status nvmefc-boot-connections.serviceShow example output
nvmefc-boot-connections.service - Auto-connect to subsystems on FC-NVME devices found during boot Loaded: loaded (/usr/lib/systemd/system/nvmefc-boot-connections.service; enabled; preset: enabled) Active: inactive (dead) since Wed 2025-07-02 16:45:46 IST; 1 day 3h ago Main PID: 1604 (code=exited, status=0/SUCCESS) CPU: 32ms Jul 02 16:45:46 interop-13-175 systemd[1]: Starting Auto-connect to subsystems on FC-NVME devices found during boot... Jul 02 16:45:46 interop-13-175 systemd[1]: nvmefc-boot-connections.service: Deactivated successfully. Jul 02 16:45:46 interop-13-175 systemd[1]: Finished Auto-connect to subsystems on FC-NVME devices found during boot.
Step 6: Configure NVMe/TCP
The NVMe/TCP protocol doesn't support the auto-connect operation. Instead, you can discover the NVMe/TCP subsystems and namespaces by performing the NVMe/TCP connect or connect-all operations manually.
Verify that the initiator port can fetch the discovery log page data across the supported NVMe/TCP LIFs:
nvme discover -t tcp -w host-traddr -a traddrShow example
nvme discover -t tcp -w 192.168.165.3 -a 192.168.165.8 Discovery Log Number of Records 8, Generation counter 8 =====Discovery Log Entry 0====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 4 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.4f7af2bd221811f0afadd039eab0dadd:discovery traddr: 192.168.166.9 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 1====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 2 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.4f7af2bd221811f0afadd039eab0dadd:discovery traddr: 192.168.165.9 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 2====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 3 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.4f7af2bd221811f0afadd039eab0dadd:discovery traddr: 192.168.166.8 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 3====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 1 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.4f7af2bd221811f0afadd039eab0dadd:discovery traddr: 192.168.165.8 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 4====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 4 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.4f7af2bd221811f0afadd039eab0dadd:subsystem.nvme traddr: 192.168.166.9 eflags: none sectype: none =====Discovery Log Entry 5====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 2 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.4f7af2bd221811f0afadd039eab0dadd:subsystem.nvme traddr: 192.168.165.9 eflags: none sectype: none =====Discovery Log Entry 6====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 3 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.4f7af2bd221811f0afadd039eab0dadd:subsystem.nvme traddr: 192.168.166.8 eflags: none sectype: none =====Discovery Log Entry 7====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 1 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.4f7af2bd221811f0afadd039eab0dadd:subsystem.nvme traddr: 192.168.165.8 eflags: none sectype: none
Verify that the other NVMe/TCP initiator-target LIF combinations can successfully fetch discovery log page data:
nvme discover -t tcp -w host-traddr -a traddrYou should see an output similar to the following example:
nvme discover -t tcp -w 192.168.166.4 -a 192.168.166.8 nvme discover -t tcp -w 192.168.165.3 -a 192.168.165.8 nvme discover -t tcp -w 192.168.166.4 -a 192.168.166.9 nvme discover -t tcp -w 192.168.165.3 -a 192.168.165.9
Run the
nvme connect-allcommand across all the supported NVMe/TCP initiator-target LIFs across the nodes:nvme connect-all -t tcp -w host-traddr -a traddrYou should see an output similar to the following example:
nvme connect-all -t tcp -w 192.168.165.3 -a 192.168.165.8 nvme connect-all -t tcp -w 192.168.165.3 -a 192.168.165.9 nvme connect-all -t tcp -w 192.168.166.4 -a 192.168.166.8 nvme connect-all -t tcp -w 192.168.166.4 -a 192.168.166.9
Beginning with Oracle Linux 9.4, the setting for the NVMe/TCP
ctrl_loss_tmo timeoutis automatically set to "off". As a result:-
There are no limits on the number of retries (indefinite retry).
You don't need to manually configure a specific
ctrl_loss_tmo timeoutduration when using thenvme connectornvme connect-allcommands (option -l ). -
The NVMe/TCP controllers don't experience timeouts in the event of a path failure and remain connected indefinitely.
Step 7: Validate NVMe-oF
Verify that the in-kernel NVMe multipath status, ANA status, and ONTAP namespaces are correct for the NVMe-oF configuration.
Verify that the in-kernel NVMe multipath is enabled:
cat /sys/module/nvme_core/parameters/multipathYou should see the following output:
Y
Verify that the appropriate NVMe-oF settings (such as, model set to NetApp ONTAP Controller and load balancing iopolicy set to round-robin) for the respective ONTAP namespaces correctly reflect on the host:
Display the subsystems:
cat /sys/class/nvme-subsystem/nvme-subsys*/modelYou should see the following output:
NetApp ONTAP Controller NetApp ONTAP Controller
Display the policy:
cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicyYou should see the following output:
round-robin round-robin
Verify that the namespaces are created and correctly discovered on the host:
nvme listShow example
Node Generic SN Model Namespace Usage Format FW Rev ------------- ------------- -------------------- ------------------------- ---------- ----------------------- -------------- -------- /dev/nvme1n1 /dev/ng1n1 81Mc4FXd1tocAAAAAAAC NetApp ONTAP Controller 0x1 0.00 B / 10.74 GB 4 KiB + 0 B 9.16.1
Verify that the controller state of each path is live and has the correct ANA status:
NVMe/FCnvme list-subsys /dev/nvme4n5Show example
nvme-subsys7 - NQN=nqn.1992-08.com.netapp:sn.7d37987be3cb11ef8948d039eab0dadd:subsystem.nvme6 hostnqn=nqn.2014-08.org.nvmexpress:uuid:2831093d-fa7f-4714-a6bf-548796e82053 iopolicy=round-robin \ +- nvme103 fc traddr=nn-0x202cd039eab0dadc:pn-0x202fd039eab0dadc,host_traddr=nn-0x200034800d767bb0:pn-0x210034800d767bb0 live optimized +- nvme153 fc traddr=nn-0x202cd039eab0dadc:pn-0x202ed039eab0dadc,host_traddr=nn-0x200034800d767bb1:pn-0x210034800d767bb1 live non-optimized +- nvme55 fc traddr=nn-0x202cd039eab0dadc:pn-0x202dd039eab0dadc,host_traddr=nn-0x200034800d767bb0:pn-0x210034800d767bb0 live non-optimized +- nvme7 fc traddr=nn-0x202cd039eab0dadc:pn-0x2030d039eab0dadc,host_traddr=nn-0x200034800d767bb1:pn-0x210034800d767bb1 live optimizedNVMe/TCPnvme list-subsys /dev/nvme1n1Show example
nvme-subsys1 - NQN=nqn.1992-08.com.netapp:sn.4f7af2bd221811f0afadd039eab0dadd:subsystem.nvme hostnqn=nqn.2014-08.org.nvmexpress:uuid:9796c1ec-0d34-11eb-b6b2-3a68dd3bab57 iopolicy=round-robin\ +- nvme1 tcp traddr=192.168.165.8,trsvcid=4420,host_traddr=192.168.165.3, src_addr=192.168.165.3 live optimized +- nvme2 tcp traddr=192.168.165.9,trsvcid=4420,host_traddr=192.168.165.3, src_addr=192.168.165.3 live non-optimized +- nvme3 tcp traddr=192.168.166.8,trsvcid=4420,host_traddr=192.168.166.4, src_addr=192.168.166.4 live optimized +- nvme4 tcp traddr=192.168.166.9,trsvcid=4420,host_traddr=192.168.166.4, src_addr=192.168.166.4 live non-optimized -
Verify that the NetApp plug-in displays the correct values for each ONTAP namespace device:
Columnnvme netapp ontapdevices -o columnShow example
Device Vserver Namespace Path NSID UUID Size ---------------- ------------------------- -------------------------------------------------- ---- -------------------------------------- --------- /dev/nvme1n1 vs_tcpinband /vol/volpdc/ns1 1 80eec226-6987-4eb4-bf86-65bf48c5372d 10.74GB
JSONnvme netapp ontapdevices -o jsonShow example
{ "ONTAPdevices":[ { "Device":"/dev/nvme1n1", "Vserver":"vs_tcpinband", "Namespace_Path":"/vol/volpdc/ns1", "NSID":1, "UUID":"80eec226-6987-4eb4-bf86-65bf48c5372d", "Size":"10.74GB", "LBA_Data_Size":4096, "Namespace_Size":2621440 } ] }
Step 8: Set up secure in-band authentication
Beginning with ONTAP 9.12.1, secure in-band authentication is supported over NVMe/TCP between an Oracle Linux 9.5 host and an ONTAP controller.
To set up secure authentication, each host or controller must be associated with a DH-HMAC-CHAP key, which is a combination of the NQN of the NVMe host or controller and an authentication secret configured by the administrator. To authenticate its peer, an NVMe host or controller must recognize the key associated with the peer.
You can set up secure in-band authentication using the CLI or a config JSON file. If you need to specify different dhchap keys for different subsystems, you must use a config JSON file.
Set up secure in-band authentication using the CLI.
Obtain the host NQN:
cat /etc/nvme/hostnqn -
Generate the dhchap key for the Linux host.
The following output describes the
gen-dhchap-keycommand paramters:nvme gen-dhchap-key -s optional_secret -l key_length {32|48|64} -m HMAC_function {0|1|2|3} -n host_nqn • -s secret key in hexadecimal characters to be used to initialize the host key • -l length of the resulting key in bytes • -m HMAC function to use for key transformation 0 = none, 1- SHA-256, 2 = SHA-384, 3=SHA-512 • -n host NQN to use for key transformationIn the following example, a random dhchap key with HMAC set to 3 (SHA-512) is generated.
# nvme gen-dhchap-key -m 3 -n nqn.2014-08.org.nvmexpress:uuid:9796c1ec-0d34-11eb-b6b2-3a68dd3bab57 DHHC-1:03:Y5VkkESgmtTGNdX842qemNpFK6BXYVwwnqErgt3IQKP5Fbjje\/JSBOjG5Ea3NBLRfuiAuUSDUto6eY\/GwKoRp6AwGkw=:
On the ONTAP controller, add the host and specify both dhchap keys:
vserver nvme subsystem host add -vserver <svm_name> -subsystem <subsystem> -host-nqn <host_nqn> -dhchap-host-secret <authentication_host_secret> -dhchap-controller-secret <authentication_controller_secret> -dhchap-hash-function {sha-256|sha-512} -dhchap-group {none|2048-bit|3072-bit|4096-bit|6144-bit|8192-bit} -
A host supports two types of authentication methods, unidirectional and bidirectional. On the host, connect to the ONTAP controller and specify dhchap keys based on the chosen authentication method:
nvme connect -t tcp -w <host-traddr> -a <tr-addr> -n <host_nqn> -S <authentication_host_secret> -C <authentication_controller_secret> -
Validate the
nvme connect authenticationcommand by verifying the host and controller dhchap keys:-
Verify the host dhchap keys:
cat /sys/class/nvme-subsystem/<nvme-subsysX>/nvme*/dhchap_secretShow example output for a unidirectional configuration
cat /sys/class/nvme-subsystem/nvme-subsys1/nvme*/dhchap_secret DHHC-1:03:Y5VkkESgmtTGNdX842qemNpFK6BXYVwwnqErgt3IQKP5Fbjje\/JSBOjG5Ea3NBLRfuiAuUSDUto6eY\/GwKoRp6AwGkw=: DHHC-1:03:Y5VkkESgmtTGNdX842qemNpFK6BXYVwwnqErgt3IQKP5Fbjje\/JSBOjG5Ea3NBLRfuiAuUSDUto6eY\/GwKoRp6AwGkw=: DHHC-1:03:Y5VkkESgmtTGNdX842qemNpFK6BXYVwwnqErgt3IQKP5Fbjje\/JSBOjG5Ea3NBLRfuiAuUSDUto6eY\/GwKoRp6AwGkw=: DHHC- 1:03:Y5VkkESgmtTGNdX842qemNpFK6BXYVwwnqErgt3IQKP5Fbjje\/JSBOjG5Ea3NBLRfuiAuUSDUto6eY\/GwKoRp6AwGkw=:
Verify the controller dhchap keys:
cat /sys/class/nvme-subsystem/<nvme-subsysX>/nvme*/dhchap_ctrl_secretShow example output for a bidirectional configuration
cat /sys/class/nvme-subsystem/nvme-subsys6/nvme*/dhchap_ctrl_secret DHHC-1:03:frpLlTrnOYtcWDxPzq4ccxU1UrH2FjV7hYw5s2XEDB+lo+TjMsOwHR\/NFtM0nBBidx+gdoyUcC5s6hOOtTLDGcz0Kbs=: DHHC-1:03:frpLlTrnOYtcWDxPzq4ccxU1UrH2FjV7hYw5s2XEDB+lo+TjMsOwHR\/NFtM0nBBidx+gdoyUcC5s6hOOtTLDGcz0Kbs=: DHHC-1:03:frpLlTrnOYtcWDxPzq4ccxU1UrH2FjV7hYw5s2XEDB+lo+TjMsOwHR\/NFtM0nBBidx+gdoyUcC5s6hOOtTLDGcz0Kbs=: DHHC-1:03:frpLlTrnOYtcWDxPzq4ccxU1UrH2FjV7hYw5s2XEDB+lo+TjMsOwHR\/NFtM0nBBidx+gdoyUcC5s6hOOtTLDGcz0Kbs=:
When multiple NVMe subsystems are available on the ONTAP controller configuration, you can use the /etc/nvme/config.json file with the nvme connect-all command.
Use the -o option to generate the JSON file. See the NVMe connect-all manual pages for more syntax options.
Configure the JSON file:
Show example
cat /etc/nvme/config.json [ { "hostnqn":"nqn.2014-08.org.nvmexpress:uuid:9796c1ec-0d34-11eb-b6b2-3a68dd3bab57", "hostid":"9796c1ec-0d34-11eb-b6b2-3a68dd3bab57", "dhchap_key":"DHHC-1:03:Y5VkkESgmtTGNdX842qemNpFK6BXYVwwnqErgt3IQKP5Fbjje\/JSBOjG5Ea3NBLRfuiAuUSDUto6eY\/GwKoRp6AwGkw=:", "subsystems":[ { "nqn":"nqn.1992-08.com.netapp:sn.4f7af2bd221811f0afadd039eab0dadd:subsystem.nvme", "ports":[ { "transport":"tcp", "traddr":"192.168.165.9", "host_traddr":"192.168.165.3", "trsvcid":"4420", "dhchap_key":"DHHC-1:03:Y5VkkESgmtTGNdX842qemNpFK6BXYVwwnqErgt3IQKP5Fbjje\/JSBOjG5Ea3NBLRfuiAuUSDUto6eY\/GwKoRp6AwGkw=:", "dhchap_ctrl_key":"DHHC-1:03:frpLlTrnOYtcWDxPzq4ccxU1UrH2FjV7hYw5s2XEDB+lo+TjMsOwHR\/NFtM0nBBidx+gdoyUcC5s6hOOtTLDGcz0Kbs=:" }, { "transport":"tcp", "traddr":"192.168.166.9", "host_traddr":"192.168.166.4", "trsvcid":"4420", "dhchap_key":"DHHC-1:03:Y5VkkESgmtTGNdX842qemNpFK6BXYVwwnqErgt3IQKP5Fbjje\/JSBOjG5Ea3NBLRfuiAuUSDUto6eY\/GwKoRp6AwGkw=:", "dhchap_ctrl_key":"DHHC-1:03:frpLlTrnOYtcWDxPzq4ccxU1UrH2FjV7hYw5s2XEDB+lo+TjMsOwHR\/NFtM0nBBidx+gdoyUcC5s6hOOtTLDGcz0Kbs=:" }, { "transport":"tcp", "traddr":"192.168.166.8", "host_traddr":"192.168.166.4", "trsvcid":"4420", "dhchap_key":"DHHC-1:03:Y5VkkESgmtTGNdX842qemNpFK6BXYVwwnqErgt3IQKP5Fbjje\/JSBOjG5Ea3NBLRfuiAuUSDUto6eY\/GwKoRp6AwGkw=:", "dhchap_ctrl_key":"DHHC-1:03:frpLlTrnOYtcWDxPzq4ccxU1UrH2FjV7hYw5s2XEDB+lo+TjMsOwHR\/NFtM0nBBidx+gdoyUcC5s6hOOtTLDGcz0Kbs=:" }, { "transport":"tcp", "traddr":"192.168.165.8", "host_traddr":"192.168.165.3", "trsvcid":"4420", "dhchap_key":"DHHC-1:03:Y5VkkESgmtTGNdX842qemNpFK6BXYVwwnqErgt3IQKP5Fbjje\/JSBOjG5Ea3NBLRfuiAuUSDUto6eY\/GwKoRp6AwGkw=:", "dhchap_ctrl_key":"DHHC-1:03:frpLlTrnOYtcWDxPzq4ccxU1UrH2FjV7hYw5s2XEDB+lo+TjMsOwHR\/NFtM0nBBidx+gdoyUcC5s6hOOtTLDGcz0Kbs=:" } ] } ] } ]In the preceding example, dhchap_keycorresponds todhchap_secretanddhchap_ctrl_keycorresponds todhchap_ctrl_secret. -
Connect to the ONTAP controller using the config JSON file:
nvme connect-all -J /etc/nvme/config.json -
Verify that the dhchap secrets have been enabled for the respective controllers for each subsystem:
cat /sys/class/nvme-subsystem/nvme-subsys0/nvme0/dhchap_secretThe following example shows a dhchap key:
cat /sys/class/nvme-subsystem/nvme-subsys0/nvme0/dhchap_ctrl_secretYou should see an output similar to the following example:
Step 9: Review the known issues
There are no known issues.
