Configure RHEL 8.1 for NVMe-oF with ONTAP storage
Red Hat Enterpirse Linux (RHEL) hosts support the NVMe over Fibre Channel (NVMe/FC) and NVMe over TCP (NVMe/TCP) protocols with Asymmetric Namespace Access (ANA). ANA provides multipathing functionality equivalent to asymmetric logical unit access (ALUA) in iSCSI and FCP environments.
Learn how to configure NVMe over Fabrics (NVMe-oF) hosts for RHEL 8.1. For more support and feature information, see NVME-oF Overview.
NVMe-oF with RHEL 8.1 has the following known limitations:
SAN booting using the NVMe-oF protocol is not currently supported.
In-kernel NVMe multipath is disabled by default on NVMe-oF hosts in RHEL 8.1, so you must enable it manually.
The native
nvme-clipackage does not includenvme-fc auto-connectscripts. You can use the host bus adapter (HBA) vendor-provided external auto-connect script. -
By default, round-robin load balancing is not enabled. You can enable it by writing a
udevrule.
Step 1: Optionally, enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability. Use the Interoperability Matrix Tool to verify that your Linux OS, host bus adapter (HBA), HBA firmware, HBA boot BIOS, and ONTAP version support SAN booting.
Enable SAN booting in the server BIOS for the ports to which the SAN boot namespace is mapped.
For information on how to enable the HBA BIOS, see your vendor-specific documentation.
Reboot the host and verify that the OS is up and running.
Step 2: Verify the software version and NVMe configuration
Check that your system meets software requirements and verify NVMe package installations and host configuration.
Install RHEL 8.1 on the server. After the installation is complete, verify that you are running the required RHEL 8.1 kernel:
uname -rExample RHEL kernel version:
4.18.0-147.el8.x86_64
Install the
nvme-cli-1.8.1-3.el8package:rpm -qa|grep nvme-cliThe following example shows an nvme-cli package version:
nvme-cli-1.8.1-3.el8.x86_64
Enable in-kernel NVMe multipath:
grubby –args=nvme_core.multipath=Y –update-kernel /boot/vmlinuz-4.18.0-147.el8.x86_64 -
Add the following string as a separate udev rule at
/lib/udev/rules.d/71-nvme-iopolicy-netapp-ONTAP.rules. This enables round-robin load balancing for NVMe multipath:Enable round-robin for NetApp ONTAP ACTION==”add”, SUBSYSTEM==”nvme-subsystem”, ATTR{model}==”NetApp ONTAP Controller”, ATTR{iopolicy}=”round-robin -
On the RHEL 8.1 host, check the host NQN string at
/etc/nvme/hostnqn:cat /etc/nvme/hostnqnThe following example shows a hostnqn string:
nqn.2014-08.org.nvmexpress:uuid:75953f3b-77fe-4e03-bf3c-09d5a156fbcd
Verify that the host NQN string matches the host NQN string for the corresponding subsystem on the ONTAP array:
vserver nvme subsystem host show -vserver vs_nvme_10Show example
*> vserver nvme subsystem host show -vserver vs_nvme_10 Vserver Subsystem Host NQN ------- --------- -------------------------------------- ----------- rhel_141_nvme_ss_10_0 nqn.2014-08.org.nvmexpress:uuid:75953f3b-77fe-4e03-bf3c-09d5a156fbcd
If the host NQN strings do not match, use the vserver modifycommand to update the host NQN string on your corresponding ONTAP array subsystem to match with the host NQN string from/etc/nvme/hostnqnon the host. -
Reboot the host.
Step 3: Configure NVMe/FC for Broadcom/Emulex
You can configure NVMe/FC for Broadcom/Emulex.
Verify that you are using the supported adapter model:
Display the model names:
cat /sys/class/scsi_host/host*/modelnameYou should see the following output:
LPe32002-M2 LPe32002-M2
Display the model descriptions:
cat /sys/class/scsi_host/host*/modeldescYou should see output similar to:
Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter
Copy and install the Broadcom lpfc outbox driver and auto-connect scripts:
tar -xvzf elx-lpfc-dd-rhel8-12.4.243.20-ds-1.tar.gz cd elx-lpfc-dd-rhel8-12.4.2453.20-ds-1 ./elx_lpfc_install-sh -i -nThe native drivers that are bundled with the OS are called the inbox drivers. If you download the outbox drivers (drivers that are not included with an OS release), an auto-connect script is included in the download and should be installed as part of the driver installation process. -
Reboot the host.
Verify that you are using the recommended Broadcom configurations.
Verify the lpfc firmware:
cat /sys/class/scsi_host/host*/fwrevYou should see the following output:
12.4.243.20, sil-4.2.c 12.4.243.20, sil-4.2.c
Verify the outbox driver:
cat /sys/module/lpfc/versionYou should see the following output:
0:12.4.243.20
Verify the auto-connect package versions:
rpm -qa | grep nvmefcYou should see the following output:
nvmefc-connect-12.6.61.0-1.noarch
Verify that the expected output of
lpfc_enable_fc4_typeis set to3:cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type -
Verify that the initiator ports are up and running and can see the target LIFs:
cat /sys/class/fc_host/host*/port_nameYou should see output similar to:
0x10000090fae0ec61 0x10000090fae0ec62
Verify that your initiator ports are online:
cat /sys/class/fc_host/host*/port_stateYou should see the following output:
Online Online
Verify that the NVMe/FC initiator ports are enabled and that the target ports are visible:
cat /sys/class/scsi_host/host*/nvme_infoShow example
NVME Initiator Enabled XRI Dist lpfc0 Total 6144 NVME 2947 SCSI 2977 ELS 250 NVME LPORT lpfc0 WWPN x10000090fae0ec61 WWNN x20000090fae0ec61 DID x012000 ONLINE NVME RPORT WWPN x202d00a098c80f09 WWNN x202c00a098c80f09 DID x010201 TARGET DISCSRVC ONLINE NVME RPORT WWPN x203100a098c80f09 WWNN x202c00a098c80f09 DID x010601 TARGET DISCSRVC ONLINE NVME Statistics
Step 4: Optionally, enable 1MB I/O for NVMe/FC
ONTAP reports a Max Data Transfer Size (MDTS) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
These steps don't apply to Qlogic NVMe/FC hosts. |
Set the
lpfc_sg_seg_cntparameter to 256:cat /etc/modprobe.d/lpfc.confYou should see an output similar to the following example:
options lpfc lpfc_sg_seg_cnt=256
Run the
dracut -fcommand, and reboot the host. -
Verify that the value for
lpfc_sg_seg_cntis 256:cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Step 5: Validate NVMe-oF
Verify that the in-kernel NVMe multipath status, ANA status, and ONTAP namespaces are correct for the NVMe-oF configuration.
Verify that the in-kernel NVMe multipath is enabled:
cat /sys/module/nvme_core/parameters/multipathYou should see the following output:
Y
Verify that the appropriate NVMe-oF settings (such as, model set to NetApp ONTAP Controller and load balancing iopolicy set to round-robin) for the respective ONTAP namespaces correctly reflect on the host:
Display the subsystems:
cat /sys/class/nvme-subsystem/nvme-subsys*/modelYou should see the following output:
NetApp ONTAP Controller NetApp ONTAP Controller
Display the policy:
cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicyYou should see the following output:
round-robin round-robin
Verify that the namespaces are created and correctly discovered on the host:
nvme listShow example
Node SN Model Namespace Usage Format FW Rev ---------------- -------------------- ----------------------- /dev/nvme0n1 80BADBKnB/JvAAAAAAAC NetApp ONTAP Controller 1 53.69 GB / 53.69 GB 4 KiB + 0 B FFFFFFFF
Verify that the controller state of each path is live and has the correct ANA status:
nvme list-subsys /dev/nvme0n1Show example
Nvme-subsysf0 – NQN=nqn.1992-08.com.netapp:sn.341541339b9511e8a9b500a098c80f09:subsystem.rhel_141_nvme_ss_10_0 \ +- nvme0 fc traddr=nn-0x202c00a098c80f09:pn-0x202d00a098c80f09 host_traddr=nn-0x20000090fae0ec61:pn-0x10000090fae0ec61 live optimized +- nvme1 fc traddr=nn-0x207300a098dfdd91:pn-0x207600a098dfdd91 host_traddr=nn-0x200000109b1c1204:pn-0x100000109b1c1204 live inaccessible +- nvme2 fc traddr=nn-0x207300a098dfdd91:pn-0x207500a098dfdd91 host_traddr=nn-0x200000109b1c1205:pn-0x100000109b1c1205 live optimized +- nvme3 fc traddr=nn-0x207300a098dfdd91:pn-0x207700a098dfdd91 host traddr=nn-0x200000109b1c1205:pn-0x100000109b1c1205 live inaccessible
Verify that the NetApp plug-in displays the correct values for each ONTAP namespace device:
Columnnvme netapp ontapdevices -o columnShow example
Device Vserver Namespace Path NSID UUID Size ------- -------- ------------------------- ------ ----- ----- /dev/nvme0n1 vs_nvme_10 /vol/rhel_141_vol_10_0/rhel_141_ns_10_0 1 55baf453-f629-4a18-9364-b6aee3f50dad 53.69GB
JSONnvme netapp ontapdevices -o jsonShow example
{ "ONTAPdevices" : [ { Device" : "/dev/nvme0n1", "Vserver" : "vs_nvme_10", "Namespace_Path" : "/vol/rhel_141_vol_10_0/rhel_141_ns_10_0", "NSID" : 1, "UUID" : "55baf453-f629-4a18-9364-b6aee3f50dad", "Size" : "53.69GB", "LBA_Data_Size" : 4096, "Namespace_Size" : 13107200 } ]
Step 6: Review the known issues
There are no known issues.
