Configure Rocky Linux 10.0 for NVMe-oF with ONTAP storage
Red Hat Enterpirse Linux (RHEL) hosts support the NVMe over Fibre Channel (NVMe/FC) and NVMe over TCP (NVMe/TCP) protocols with Asymmetric Namespace Access (ANA). ANA provides multipathing functionality equivalent to asymmetric logical unit access (ALUA) in iSCSI and FCP environments.
Learn how to configure NVMe over Fabrics (NVMe-oF) hosts for Rocky Linux 10.0. For more support and feature information, see NVME-oF Overview.
NVMe-oF with Rocky Linux 10.0 has the following known limitations:
DM multipath support for NVMe-oF is not supported.
Avoid issuing the
nvme disconnect-allcommand on systems booting from SAN over NVMe-TCP or NVMe-FC namespaces because it disconnects both root and data filesystems and might lead to system instability.
Step 1: Optionally, enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability. Use the Interoperability Matrix Tool to verify that your Linux OS, host bus adapter (HBA), HBA firmware, HBA boot BIOS, and ONTAP version support SAN booting.
Enable SAN booting in the server BIOS for the ports to which the SAN boot namespace is mapped.
For information on how to enable the HBA BIOS, see your vendor-specific documentation.
Reboot the host and verify that the OS is up and running.
Step 2: Verify the software version and NVMe configuration
Check that your system meets software requirements and verify NVMe package installations and host configuration.
Install Rocky Linux 10.0 on the server. After the installation is complete, verify that you are running the required Rocky Linux 10.0 kernel:
uname -rExample Rocky Linux kernel version:
6.12.0-55.9.1.el10_0.x86_64
Install the
nvme-clipackage:rpm -qa|grep nvme-cliThe following example shows an
nvme-clipackage version:nvme-cli-2.11-5.el10.x86_64
Install the
libnvmepackage:rpm -qa|grep libnvmeThe following example shows an
libnvmepackage version:libnvme-1.11.1-1.el10.x86_64
On the host, check the hostnqn string at
/etc/nvme/hostnqn:cat /etc/nvme/hostnqnThe following example shows a
hostnqnvalue:nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0056-5410-8048-b9c04f425633
Verify that the
hostnqnstring matches thehostnqnstring for the corresponding subsystem on the ONTAP array:::> vserver nvme subsystem host show -vserver vs_nvme_194_rockylinux10Show example
Vserver Subsystem Priority Host NQN ------- --------- -------- ------------------------------------------------ vs_nvme_194_rockylinux10 nvme4 regular nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0056-5410-8048-c7c04f425633 nvme_1 regular nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0056-5410-8048-c7c04f425633 nvme_2 regular nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0056-5410-8048-c7c04f425633 nvme_3 regular nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0056-5410-8048-c7c04f425633 4 entries were displayed.If the hostnqnstrings do not match, use thevserver modifycommand to update thehostnqnstring on your corresponding ONTAP storage system subsystem to match thehostnqnstring from/etc/nvme/hostnqnon the host.
Step 3: Configure NVMe/FC and NVMe/TCP
Configure NVMe/FC with Broadcom/Emulex or Marvell/QLogic adapters, or configure NVMe/TCP using manual discovery and connect operations.
Configure NVMe/FC for a Broadcom/Emulex adapter.
Verify that you are using the supported adapter model:
Display the model names:
cat /sys/class/scsi_host/host*/modelnameYou should see the following output:
LPe36002-M64 LPe36002-M64
Display the model descriptions:
cat /sys/class/scsi_host/host*/modeldescYou should see output similar to the following example:
Emulex LightPulse LPe36002-M64 2-Port 64Gb Fibre Channel Adapter Emulex LightPulse LPe36002-M64 2-Port 64Gb Fibre Channel Adapter
Verify that you are using the recommended Broadcom
lpfcfirmware and inbox driver:-
Display the firmware version:
cat /sys/class/scsi_host/host*/fwrevThe command returns the firmware versions:
14.0.539.16, sli-4:6:d 14.0.539.16, sli-4:6:d
Display the inbox driver version:
cat /sys/module/lpfc/versionThe following example shows a driver version:
0:14.4.0.6
For the current list of supported adapter driver and firmware versions, see the Interoperability Matrix Tool.
Verify that
lpfc_enable_fc4_typeis set to3:cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type -
Verify that you can view your initiator ports:
cat /sys/class/fc_host/host*/port_nameYou should see output similar to:
0x2100f4c7aa0cd7c2 0x2100f4c7aa0cd7c3
Verify that your initiator ports are online:
cat /sys/class/fc_host/host*/port_stateYou should see the following output:
Online Online
Verify that the NVMe/FC initiator ports are enabled and that the target ports are visible:
cat /sys/class/scsi_host/host*/nvme_infoShow example
NVME Initiator Enabled XRI Dist lpfc2 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc2 WWPN x100000109bf044b1 WWNN x200000109bf044b1 DID x022a00 ONLINE NVME RPORT WWPN x202fd039eaa7dfc8 WWNN x202cd039eaa7dfc8 DID x021310 TARGET DISCSRVC ONLINE NVME RPORT WWPN x202dd039eaa7dfc8 WWNN x202cd039eaa7dfc8 DID x020b10 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000000810 Cmpl 0000000810 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000007b098f07 Issue 000000007aee27c4 OutIO ffffffffffe498bd abort 000013b4 noxri 00000000 nondlp 00000058 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 000013b4 Err 00021443 NVME Initiator Enabled XRI Dist lpfc3 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc3 WWPN x100000109bf044b2 WWNN x200000109bf044b2 DID x021b00 ONLINE NVME RPORT WWPN x2033d039eaa7dfc8 WWNN x202cd039eaa7dfc8 DID x020110 TARGET DISCSRVC ONLINE NVME RPORT WWPN x2032d039eaa7dfc8 WWNN x202cd039eaa7dfc8 DID x022910 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000000840 Cmpl 0000000840 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000007afd4434 Issue 000000007ae31b83 OutIO ffffffffffe5d74f abort 000014a5 noxri 00000000 nondlp 0000006a qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 000014a5 Err 0002149a
Configure NVMe/FC for a Marvell/QLogic adapter.
Verify that you are using the supported adapter driver and firmware versions:
cat /sys/class/fc_host/host*/symbolic_nameThe following example shows driver and firmware versions:
QLE2872 FW:v9.15.00 DVR:v10.02.09.300-k QLE2872 FW:v9.15.00 DVR:v10.02.09.300-k
Verify that
ql2xnvmeenableis set. This enables the Marvell adapter to function as an NVMe/FC initiator:cat /sys/module/qla2xxx/parameters/ql2xnvmeenableThe expected output is 1.
The NVMe/TCP protocol doesn't support the auto-connect operation. Instead, you can discover the NVMe/TCP subsystems and namespaces by performing the NVMe/TCP connect or connect-all operations manually.
Check that the initiator port can get the discovery log page data across the supported NVMe/TCP LIFs:
nvme discover -t tcp -w host-traddr -a traddrShow example
nvme discover -t tcp -w 192.168.20.1 -a 192.168.20.20 Discovery Log Number of Records 8, Generation counter 18 =====Discovery Log Entry 0====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 4 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.64e65e6caae711ef9668d039ea951c46:discovery traddr: 192.168.21.21 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 1====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 2 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.64e65e6caae711ef9668d039ea951c46:discovery traddr: 192.168.20.21 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 2====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 3 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.64e65e6caae711ef9668d039ea951c46:discovery traddr: 192.168.21.20 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 3====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 1 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.64e65e6caae711ef9668d039ea951c46:discovery traddr: 192.168.20.20 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 4====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 4 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.64e65e6caae711ef9668d039ea951c46:subsystem.rockylinux10_tcp_subsystem traddr: 192.168.21.21 eflags: none sectype: none =====Discovery Log Entry 5====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 2 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.64e65e6caae711ef9668d039ea951c46:subsystem.rockylinux10_tcp_subsystem traddr: 192.168.20.21 eflags: none sectype: none =====Discovery Log Entry 6====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 3 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.64e65e6caae711ef9668d039ea951c46:subsystem.rockylinux10_tcp_subsystem traddr: 192.168.21.20 eflags: none sectype: none =====Discovery Log Entry 7====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 1 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.64e65e6caae711ef9668d039ea951c46:subsystem.rockylinux10_tcp_subsystem traddr: 192.168.20.20 eflags: none sectype: none
Verify that the other NVMe/TCP initiator-target LIF combinations can successfully retrieve discovery log page data:
nvme discover -t tcp -w 192.168.20.1 -a 192.168.20.20 nvme discover -t tcp -w 192.168.21.1 -a 192.168.21.20 nvme discover -t tcp -w 192.168.20.1 -a 192.168.20.21 nvme discover -t tcp -w 192.168.21.1 -a 192.168.21.21
Run the
nvme connect-allcommand across all the supported NVMe/TCP initiator-target LIFs across the nodes:nvme connect-all -t tcp -w host-traddr -a traddrShow example
nvme connect-all -t tcp -w 192.168.20.1 -a 192.168.20.20 nvme connect-all -t tcp -w 192.168.21.1 -a 192.168.21.20 nvme connect-all -t tcp -w 192.168.20.1 -a 192.168.20.21 nvme connect-all -t tcp -w 192.168.21.1 -a 192.168.21.21
Beginning with Rocky Linux 9.4, the setting for the NVMe/TCP
Step 4: Optionally, enable 1MB I/O for NVMe/FC
ONTAP reports a Max Data Transfer Size (MDTS) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
These steps don't apply to Qlogic NVMe/FC hosts. |
Set the
lpfc_sg_seg_cntparameter to 256:cat /etc/modprobe.d/lpfc.confYou should see an output similar to the following example:
options lpfc lpfc_sg_seg_cnt=256
Run the
dracut -fcommand, and reboot the host. -
Verify that the value for
lpfc_sg_seg_cntis 256:cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Step 5: Verify NVMe boot services
The nvmefc-boot-connections.service and nvmf-autoconnect.service boot services included in the NVMe/FC nvme-cli package are automatically enabled when the system boots.
After booting completes, verify that the nvmefc-boot-connections.service and nvmf-autoconnect.service boot services are enabled.
Verify that
nvmf-autoconnect.serviceis enabled:systemctl status nvmf-autoconnect.serviceShow example output
nvmf-autoconnect.service - Connect NVMe-oF subsystems automatically during boot Loaded: loaded (/usr/lib/systemd/system/nvmf-autoconnect.service; enabled; preset: disabled) Active: inactive (dead) Jun 10 04:06:26 SR630-13-201.lab.eng.btc.netapp.in systemd[1]: Starting Connect NVMe-oF subsystems automatically during boot... Jun 10 04:06:26 SR630-13-201.lab.eng.btc.netapp.in systemd[1]: nvmf-autoconnect.service: Deactivated successfully. Jun 10 04:06:26 SR630-13-201.lab.eng.btc.netapp.in systemd[1]: Finished Connect NVMe-oF subsystems automatically during boot. -
Verify that
nvmefc-boot-connections.serviceis enabled:systemctl status nvmefc-boot-connections.serviceShow example output
nvmefc-boot-connections.service - Auto-connect to subsystems on FC-NVME devices found during boot Loaded: loaded (/usr/lib/systemd/system/nvmefc-boot-connections.service; enabled; preset: enabled) Active: inactive (dead) since Tue 2025-06-10 01:08:36 EDT; 2h 59min ago Main PID: 7090 (code=exited, status=0/SUCCESS) CPU: 30ms Jun 10 01:08:36 localhost systemd[1]: Starting Auto-connect to subsystems on FC-NVME devices found during boot... Jun 10 01:08:36 localhost systemd[1]: nvmefc-boot-connections.service: Deactivated successfully. Jun 10 01:08:36 localhost systemd[1]: Finished Auto-connect to subsystems on FC-NVME devices found during boot.
Step 6: Verify the multipathing configuration
Verify that the in-kernel NVMe multipath status, ANA status, and ONTAP namespaces are correct for the NVMe-oF configuration.
Verify that the in-kernel NVMe multipath is enabled:
cat /sys/module/nvme_core/parameters/multipathYou should see the following output:
Y
Verify that the appropriate NVMe-oF settings (such as, model set to NetApp ONTAP Controller and load balancing iopolicy set to round-robin) for the respective ONTAP namespaces correctly reflect on the host:
Display the subsystems:
cat /sys/class/nvme-subsystem/nvme-subsys*/modelYou should see the following output:
NetApp ONTAP Controller NetApp ONTAP Controller
Display the policy:
cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicyYou should see the following output:
round-robin round-robin
Verify that the namespaces are created and correctly discovered on the host:
nvme listShow example
Node SN Model --------------------------------------------------------- /dev/nvme4n1 81Ix2BVuekWcAAAAAAAB NetApp ONTAP Controller Namespace Usage Format FW Rev ----------------------------------------------------------- 1 21.47 GB / 21.47 GB 4 KiB + 0 B FFFFFFFF
Verify that the controller state of each path is live and has the correct ANA status:
NVMe/FCnvme list-subsys /dev/nvme5n1Show example
nvme-subsys5 - NQN=nqn.1992-08.com.netapp:sn.f7565b15a66911ef9668d039ea951c46:subsystem.nvme1 hostnqn=nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0056-5410-8048-c7c04f425633 \ +- nvme126 fc traddr=nn-0x2036d039ea951c45:pn-0x2038d039ea951c45,host_traddr=nn-0x2000f4c7aa0cd7c3:pn-0x2100f4c7aa0cd7c3 live optimized +- nvme176 fc traddr=nn-0x2036d039ea951c45:pn-0x2037d039ea951c45,host_traddr=nn-0x2000f4c7aa0cd7c2:pn-0x2100f4c7aa0cd7c2 live optimized +- nvme5 fc traddr=nn-0x2036d039ea951c45:pn-0x2039d039ea951c45,host_traddr=nn-0x2000f4c7aa0cd7c2:pn-0x2100f4c7aa0cd7c2 live non-optimized +- nvme71 fc traddr=nn-0x2036d039ea951c45:pn-0x203ad039ea951c45,host_traddr=nn-0x2000f4c7aa0cd7c3:pn-0x2100f4c7aa0cd7c3 live non-optimizedNVMe/TCPnvme list-subsys /dev/nvme4n2Show example
nvme-subsys4 - NQN=nqn.1992-08.com.netapp:sn.64e65e6caae711ef9668d039ea951c46:subsystem.nvme4 hostnqn=nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0035-5910-804b-c2c04f444d33 \ +- nvme102 tcp traddr=192.168.21.20,trsvcid=4420,host_traddr=192.168.21.1,src_addr=192.168.21.1 live non-optimized +- nvme151 tcp traddr=192.168.21.21,trsvcid=4420,host_traddr=192.168.21.1,src_addr=192.168.21.1 live optimized +- nvme4 tcp traddr=192.168.20.20,trsvcid=4420,host_traddr=192.168.20.1,src_addr=192.168.20.1 live non-optimized +- nvme53 tcp traddr=192.168.20.21,trsvcid=4420,host_traddr=192.168.20.1,src_addr=192.168.20.1 live optimized -
Verify that the NetApp plug-in displays the correct values for each ONTAP namespace device:
Columnnvme netapp ontapdevices -o columnShow example
Device Vserver Namespace Path ----------------------- ------------------------------------ /dev/nvme10n1 vs_tcp_rockylinux10 /vol/vol10/ns10 NSID UUID Size ----------------------- ------------------------------------ 1 bbf51146-fc64-4197-b8cf-8a24f6f359b3 21.47GB
JSONnvme netapp ontapdevices -o jsonShow example
{ "ONTAPdevices":[ { "Device":"/dev/nvme10n1", "Vserver":"vs_tcp_rockylinux10", "Namespace_Path":"/vol/vol10/ns10", "NSID":1, "UUID":"bbf51146-fc64-4197-b8cf-8a24f6f359b3", "Size":"21.47GB", "LBA_Data_Size":4096, "Namespace_Size":5242880 } ] }
Step 7: Set up secure in-band authentication
Beginning with ONTAP 9.12.1, secure in-band authentication is supported over NVMe/TCP between a Rocky Linux 10.0 host and an ONTAP controller.
Each host or controller must be associated with a DH-HMAC-CHAP key to set up secure authentication. A DH-HMAC-CHAP key is a combination of the NQN of the NVMe host or controller and an authentication secret configured by the administrator. To authenticate its peer, an NVMe host or controller must recognize the key associated with the peer.
Set up secure in-band authentication using the CLI or a config JSON file. If you need to specify different dhchap keys for different subsystems, you must use a config JSON file.
Set up secure in-band authentication using the CLI.
Obtain the host NQN:
cat /etc/nvme/hostnqn -
Generate the dhchap key for the Rocky Linux 10.0 host.
The following output describes the
gen-dhchap-keycommand parameters:nvme gen-dhchap-key -s optional_secret -l key_length {32|48|64} -m HMAC_function {0|1|2|3} -n host_nqn • -s secret key in hexadecimal characters to be used to initialize the host key • -l length of the resulting key in bytes • -m HMAC function to use for key transformation 0 = none, 1- SHA-256, 2 = SHA-384, 3=SHA-512 • -n host NQN to use for key transformationIn the following example, a random dhchap key with HMAC set to 3 (SHA-512) is generated.
nvme gen-dhchap-key -m 3 -n nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0035-5910-804b-c2c04f444d33 DHHC-1:03:7zf8I9gaRcDWH3tCH5vLGaoyjzPIvwNWusBfKdpJa+hia1aKDKJQ2o53pX3wYM9xdv5DtKNNhJInZ7X8wU2RQpQIngc=:
On the ONTAP controller, add the host and specify both dhchap keys:
vserver nvme subsystem host add -vserver <svm_name> -subsystem <subsystem> -host-nqn <host_nqn> -dhchap-host-secret <authentication_host_secret> -dhchap-controller-secret <authentication_controller_secret> -dhchap-hash-function {sha-256|sha-512} -dhchap-group {none|2048-bit|3072-bit|4096-bit|6144-bit|8192-bit} -
A host supports two types of authentication methods, unidirectional and bidirectional. On the host, connect to the ONTAP controller and specify dhchap keys based on the chosen authentication method:
nvme connect -t tcp -w <host-traddr> -a <tr-addr> -n <host_nqn> -S <authentication_host_secret> -C <authentication_controller_secret> -
Validate the
nvme connect authenticationcommand by verifying the host and controller dhchap keys:-
Verify the host dhchap keys:
cat /sys/class/nvme-subsystem/<nvme-subsysX>/nvme*/dhchap_secretShow example output for a unidirectional configuration
cat /sys/class/nvme-subsystem/nvme-subsys1/nvme*/dhchap_secret DHHC- 1:03:fMCrJharXUOqRoIsOEaG6m2PH1yYvu5+z3jTmzEKUbcWu26I33b93b il2WR09XDho/ld3L45J+0FeCsStBEAfhYgkQU=: DHHC- 1:03:fMCrJharXUOqRoIsOEaG6m2PH1yYvu5+z3jTmzEKUbcWu26I33b93b il2WR09XDho/ld3L45J+0FeCsStBEAfhYgkQU=: DHHC- 1:03:fMCrJharXUOqRoIsOEaG6m2PH1yYvu5+z3jTmzEKUbcWu26I33b93b il2WR09XDho/ld3L45J+0FeCsStBEAfhYgkQU=: DHHC- 1:03:fMCrJharXUOqRoIsOEaG6m2PH1yYvu5+z3jTmzEKUbcWu26I33b93b il2WR09XDho/ld3L45J+0FeCsStBEAfhYgkQU=:
Verify the controller dhchap keys:
cat /sys/class/nvme-subsystem/<nvme-subsysX>/nvme*/dhchap_ctrl_secretShow example output for a bidirectional configuration
cat /sys/class/nvme-subsystem/nvme-subsys6/nvme*/dhchap_ctrl_secret DHHC- 1:03:7zf8I9gaRcDWH3tCH5vLGaoyjzPIvwNWusBfKdpJa+hia 1aKDKJQ2o53pX3wYM9xdv5DtKNNhJInZ7X8wU2RQpQIngc=: DHHC- 1:03:7zf8I9gaRcDWH3tCH5vLGaoyjzPIvwNWusBfKdpJa+hia 1aKDKJQ2o53pX3wYM9xdv5DtKNNhJInZ7X8wU2RQpQIngc=: DHHC- 1:03:7zf8I9gaRcDWH3tCH5vLGaoyjzPIvwNWusBfKdpJa+hia 1aKDKJQ2o53pX3wYM9xdv5DtKNNhJInZ7X8wU2RQpQIngc=: DHHC- 1:03:7zf8I9gaRcDWH3tCH5vLGaoyjzPIvwNWusBfKdpJa+hia 1aKDKJQ2o53pX3wYM9xdv5DtKNNhJInZ7X8wU2RQpQIngc=:
When multiple NVMe subsystems are available on the ONTAP controller, you can use the /etc/nvme/config.json file with the nvme connect-all command.
Use the -o option to generate the JSON file. Refer to the NVMe connect-all man pages for more syntax options.
Configure the JSON file.
In the following example, dhchap_keycorresponds todhchap_secretanddhchap_ctrl_keycorresponds todhchap_ctrl_secret.Show example
cat /etc/nvme/config.json [ { "hostnqn":"nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0035-5910-804b-c2c04f444d33", "hostid":"4c4c4544-0035-5910-804b-c2c04f444d33", "dhchap_key":"DHHC-1:03:7zf8I9gaRcDWH3tCH5vLGaoyjzPIvwNWusBfKdpJa+hia1aKDKJQ2o53pX3wYM9xdv5DtKNNhJInZ7X8wU2RQpQIngc=:", "subsystems":[ { "nqn":"nqn.1992-08.com.netapp:sn.127ade26168811f0a50ed039eab69ad3:subsystem.inband_unidirectional", "ports":[ { "transport":"tcp", "traddr":"192.168.20.17", "host_traddr":"192.168.20.1", "trsvcid":"4420" }, { "transport":"tcp", "traddr":"192.168.20.18", "host_traddr":"192.168.20.1", "trsvcid":"4420" }, { "transport":"tcp", "traddr":"192.168.21.18", "host_traddr":"192.168.21.1", "trsvcid":"4420" }, { "transport":"tcp", "traddr":"192.168.21.17", "host_traddr":"192.168.21.1", "trsvcid":"4420" }] -
Connect to the ONTAP controller using the config JSON file:
nvme connect-all -J /etc/nvme/config.jsonShow example
traddr=192.168.20.20 is already connected traddr=192.168.20.20 is already connected traddr=192.168.20.20 is already connected traddr=192.168.20.20 is already connected traddr=192.168.20.20 is already connected traddr=192.168.20.20 is already connected traddr=192.168.20.20 is already connected traddr=192.168.20.20 is already connected traddr=192.168.20.21 is already connected traddr=192.168.20.21 is already connected traddr=192.168.20.21 is already connected traddr=192.168.20.21 is already connected traddr=192.168.20.21 is already connected traddr=192.168.20.21 is already connected traddr=192.168.20.21 is already connected traddr=192.168.20.21 is already connected
Verify that the dhchap secrets have been enabled for the respective controllers for each subsystem.
cat /sys/class/nvme-subsystem/nvme-subsys0/nvme0/dhchap_secretThe following example shows a dhchap key:
DHHC-1:03:7zf8I9gaRcDWH3tCH5vLGaoyjzPIvwNWusBfKdpJa+hia1 aKDKJQ2o53pX3wYM9xdv5DtKNNhJInZ7X8wU2RQpQIngc=:
cat /sys/class/nvme-subsystem/nvme-subsys0/nvme0/dhchap_ctrl_secretYou should see output similar to the following example:
DHHC-1:03:fMCrJharXUOqRoIsOEaG6m2PH1yYvu5+z3jT mzEKUbcWu26I33b93bil2WR09XDho/ld3L45J+0FeCsStBEAfhYgkQU=:
Step 8: Review the known issues
There are no known issues.
