NVMe-oF host configuration for RHEL 10 with ONTAP
NetApp SAN host configurations support the NVMe over Fabrics (NVMe-oF) protocol with Asymmetric Namespace Access (ANA). In NVMe-oF environments, ANA is equivalent to asymmetric logical unit access (ALUA) multipathing in iSCSI and FCP environments. ANA is implemented using the in-kernel NVMe multipath feature.
You can use the following support and features with the NVMe-oF host configuration for Red Hat Enterprise Linux (RHEL) 10. You should also review the known limitations before starting the configuration process.
Support available:
Support for NVMe over TCP (NVMe/TCP) in addition to NVMe over Fibre Channel (NVMe/FC). The NetApp plug-in in the native
nvme-cli
package displays ONTAP details for both NVMe/FC and NVMe/TCP namespaces. -
Running both NVMe and SCSI traffic on the same host. For example, you can configure dm-multipath for SCSI mpath devices on SCSI LUNs and use NVMe multipath to configure NVMe-oF namespace devices on the host.
Beginning with ONTAP 9.12.1, support for secure in-band authentication is introduced for NVMe/TCP. You can use secure in-band authentication for NVMe/TCP with RHEL 10.
For additional details on supported configurations, see the Interoperability Matrix Tool.
Features available:
Beginning with RHEL 10, native NVMe multipathing is always enabled, and DM multipath support for NVMe-oF is not supported.
Known limitations:
Avoid issuing the
nvme disconnect-all
command on systems booting from SAN over NVMe-TCP or NVMe-FC namespaces because it disconnects both root and data filesystems and might lead to system instability.
Step 1: Optionally, enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability.
Use the Interoperability Matrix Tool to verify that your Linux OS, host bus adapter (HBA), HBA firmware, HBA boot BIOS, and ONTAP version support SAN booting.
Enable SAN booting in the server BIOS for the ports to which the SAN boot namespace is mapped.
For information on how to enable the HBA BIOS, see your vendor-specific documentation.
Verify that the configuration was successful by rebooting the host and verifying that the OS is up and running.
Step 2: Validate software versions
Use the following procedure to validate the minimum supported RHEL 10 software versions.
Install RHEL 10 on the server. After the installation is complete, verify that you are running the specified RHEL 10 kernel:
uname -r
The following example shows a RHEL kernel version:
6.12.0-55.9.1.el10_0.x86_64
Install the
nvme-cli
package:rpm -qa|grep nvme-cli
The following example shows an
nvme-cli
package version:nvme-cli-2.11-5.el10.x86_64
Install the
libnvme
package:rpm -qa|grep libnvme
libnvme
package version:libnvme-1.11.1-1.el10.x86_64
On the host, check the hostnqn string at
/etc/nvme/hostnqn
:cat /etc/nvme/hostnqn
hostnqn
version:nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0056-5410-8048-b9c04f425633
Verify that the
hostnqn
string matches thehostnqn
string for the corresponding subsystem on the ONTAP array:::> vserver nvme subsystem host show -vserver vs_nvme_194_rhel10
Show example
Vserver Subsystem Priority Host NQN ------- --------- -------- ------------------------------------------------ vs_ nvme_194_rhel10 nvme4 regular nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0056-5410-8048- c7c04f425633 nvme_1 regular nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0056-5410-8048- c7c04f425633 nvme_2 regular nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0056-5410-8048- c7c04f425633 nvme_3 regular nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0056-5410-8048- c7c04f425633 4 entries were displayed.
If the hostnqn
strings do not match, use thevserver modify
command to update thehostnqn
string on your corresponding ONTAP array subsystem to match thehostnqn
string from/etc/nvme/hostnqn
on the host.
Step 3: Configure NVMe/FC
You can configure NVMe/FC with Broadcom/Emulex FC or Marvell/Qlogic FC adapters. For NVMe/FC configured with a Broadcom adapter, you can enable I/O requests of size 1MB.
Configure NVMe/FC for a Broadcom/Emulex adapter.
Verify that you are using the supported adapter model:
Display the model names:
cat /sys/class/scsi_host/host*/modelname
You should see the following output:
LPe36002-M64 LPe36002-M64
Display the model descriptions:
cat /sys/class/scsi_host/host*/modeldesc
You should see an output similar to the following example:
Emulex LightPulse LPe36002-M64 2-Port 64Gb Fibre Channel Adapter Emulex LightPulse LPe36002-M64 2-Port 64Gb Fibre Channel Adapter
Verify that you are using the recommended Broadcom
lpfc
firmware and inbox driver:-
Display the firmware version:
cat /sys/class/scsi_host/host*/fwrev
The following example shows firmware versions:
14.0.539.16, sli-4:6:d 14.0.539.16, sli-4:6:d
Display the inbox driver version:
cat /sys/module/lpfc/version
The following example shows a driver version:
0:14.4.0.6
For the current list of supported adapter driver and firmware versions, see the Interoperability Matrix Tool.
Verify that the expected output of
lpfc_enable_fc4_type
is set to3
:cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type
Verify that you can view your initiator ports:
cat /sys/class/fc_host/host*/port_name
The following example shows port identities:
0x2100f4c7aa0cd7c2 0x2100f4c7aa0cd7c3
Verify that your initiator ports are online:
cat /sys/class/fc_host/host*/port_state
Online Online
Verify that the NVMe/FC initiator ports are enabled and that the target ports are visible:
cat /sys/class/scsi_host/host*/nvme_info
Show example
NVME Initiator Enabled XRI Dist lpfc2 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc2 WWPN x100000109bf044b1 WWNN x200000109bf044b1 DID x022a00 ONLINE NVME RPORT WWPN x202fd039eaa7dfc8 WWNN x202cd039eaa7dfc8 DID x021310 TARGET DISCSRVC ONLINE NVME RPORT WWPN x202dd039eaa7dfc8 WWNN x202cd039eaa7dfc8 DID x020b10 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000000810 Cmpl 0000000810 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000007b098f07 Issue 000000007aee27c4 OutIO ffffffffffe498bd abort 000013b4 noxri 00000000 nondlp 00000058 qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 000013b4 Err 00021443 NVME Initiator Enabled XRI Dist lpfc3 Total 6144 IO 5894 ELS 250 NVME LPORT lpfc3 WWPN x100000109bf044b2 WWNN x200000109bf044b2 DID x021b00 ONLINE NVME RPORT WWPN x2033d039eaa7dfc8 WWNN x202cd039eaa7dfc8 DID x020110 TARGET DISCSRVC ONLINE NVME RPORT WWPN x2032d039eaa7dfc8 WWNN x202cd039eaa7dfc8 DID x022910 TARGET DISCSRVC ONLINE NVME Statistics LS: Xmt 0000000840 Cmpl 0000000840 Abort 00000000 LS XMIT: Err 00000000 CMPL: xb 00000000 Err 00000000 Total FCP Cmpl 000000007afd4434 Issue 000000007ae31b83 OutIO ffffffffffe5d74f abort 000014a5 noxri 00000000 nondlp 0000006a qdepth 00000000 wqerr 00000000 err 00000000 FCP CMPL: xb 000014a5 Err 0002149a
Configure NVMe/FC for a Marvell/QLogic adapter.
Verify that you are running the supported adapter driver and firmware versions:
cat /sys/class/fc_host/host*/symbolic_name
The follow example shows driver and firmware versions:
QLE2872 FW:v9.15.00 DVR:v10.02.09.300-k QLE2872 FW:v9.15.00 DVR:v10.02.09.300-k
Verify that
ql2xnvmeenable
is set. This enables the Marvell adapter to function as an NVMe/FC initiator:cat /sys/module/qla2xxx/parameters/ql2xnvmeenable
The expected ouptut is 1.
Step 4: Optionally, enable 1MB I/O
ONTAP reports an MDTS (Max Data Transfer Size) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc
value of the lpfc_sg_seg_cnt
parameter to 256 from the default value of 64.
These steps don't apply to Qlogic NVMe/FC hosts. |
Set the
lpfc_sg_seg_cnt
parameter to 256:cat /etc/modprobe.d/lpfc.conf
options lpfc lpfc_sg_seg_cnt=256
Run the
dracut -f
command, and reboot the host. -
Verify that the value for
lpfc_sg_seg_cnt
is 256:cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Step 5: Verify NVMe boot services
With RHEL 10, the nvmefc-boot-connections.service
and nvmf-autoconnect.service
boot services included in the NVMe/FC nvme-cli
package are automatically enabled when the system boots.
After booting completes, verify that the nvmefc-boot-connections.service
boot services are enabled.
Verify that
is enabled:systemctl status nvmf-autoconnect.service
Show example output
nvmf-autoconnect.service - Connect NVMe-oF subsystems automatically during boot Loaded: loaded (/usr/lib/systemd/system/nvmf-autoconnect.service; enabled; preset: disabled) Active: inactive (dead) Jun 10 04:06:26 SR630-13-201.lab.eng.btc.netapp.in systemd[1]: Starting Connect NVMe-oF subsystems automatically during boot... Jun 10 04:06:26 SR630-13-201.lab.eng.btc.netapp.in systemd[1]: nvmf-autoconnect.service: Deactivated successfully. Jun 10 04:06:26 SR630-13-201.lab.eng.btc.netapp.in systemd[1]: Finished Connect NVMe-oF subsystems automatically during boot.
Verify that
is enabled:systemctl status nvmefc-boot-connections.service
Show example output
nvmefc-boot-connections.service - Auto-connect to subsystems on FC-NVME devices found during boot Loaded: loaded (/usr/lib/systemd/system/nvmefc-boot-connections.service; enabled; preset: enabled) Active: inactive (dead) since Tue 2025-06-10 01:08:36 EDT; 2h 59min ago Main PID: 7090 (code=exited, status=0/SUCCESS) CPU: 30ms Jun 10 01:08:36 localhost systemd[1]: Starting Auto-connect to subsystems on FC-NVME devices found during boot... Jun 10 01:08:36 localhost systemd[1]: nvmefc-boot-connections.service: Deactivated successfully. Jun 10 01:08:36 localhost systemd[1]: Finished Auto-connect to subsystems on FC-NVME devices found during boot.
Step 6: Configure NVMe/TCP
The NVMe/TCP protocol doesn't support the auto-connect
operation. Instead, you can discover the NVMe/TCP subsystems and namespaces by performing the NVMe/TCP connect
or connect-all
operations manually.
Verify that the initiator port can fetch the discovery log page data across the supported NVMe/TCP LIFs:
nvme discover -t tcp -w host-traddr -a traddr
Show example
nvme discover -t tcp -w 192.168.20.1 -a 192.168.20.20 Discovery Log Number of Records 8, Generation counter 18 =====Discovery Log Entry 0====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 4 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.64e65e6caae711ef9668d039ea951c46:discovery traddr: 192.168.21.21 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 1====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 2 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.64e65e6caae711ef9668d039ea951c46:discovery traddr: 192.168.20.21 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 2====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 3 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.64e65e6caae711ef9668d039ea951c46:discovery traddr: 192.168.21.20 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 3====== trtype: tcp adrfam: ipv4 subtype: current discovery subsystem treq: not specified portid: 1 trsvcid: 8009 subnqn: nqn.1992-08.com.netapp:sn.64e65e6caae711ef9668d039ea951c46:discovery traddr: 192.168.20.20 eflags: explicit discovery connections, duplicate discovery information sectype: none =====Discovery Log Entry 4====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 4 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.64e65e6caae711ef9668d039ea951c46:subsystem.rhel10_tcp_subsystem traddr: 192.168.21.21 eflags: none sectype: none =====Discovery Log Entry 5====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 2 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.64e65e6caae711ef9668d039ea951c46:subsystem.rhel10_tcp_subsystem traddr: 192.168.20.21 eflags: none sectype: none =====Discovery Log Entry 6====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 3 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.64e65e6caae711ef9668d039ea951c46:subsystem.rhel10_tcp_subsystem traddr: 192.168.21.20 eflags: none sectype: none =====Discovery Log Entry 7====== trtype: tcp adrfam: ipv4 subtype: nvme subsystem treq: not specified portid: 1 trsvcid: 4420 subnqn: nqn.1992-08.com.netapp:sn.64e65e6caae711ef9668d039ea951c46:subsystem.rhel10_tcp_subsystem traddr: 192.168.20.20 eflags: none sectype: none
Verify that the other NVMe/TCP initiator-target LIF combinations can successfully fetch discovery log page data:
Show example
nvme discover -t tcp -w 192.168.20.1 -a 192.168.20.20 nvme discover -t tcp -w 192.168.21.1 -a 192.168.21.20 nvme discover -t tcp -w 192.168.20.1 -a 192.168.20.21 nvme discover -t tcp -w 192.168.21.1 -a 192.168.21.21
Run the
nvme connect-all
command across all the supported NVMe/TCP initiator-target LIFs across the nodes:nvme connect-all -t tcp -w host-traddr -a traddr
Show example
nvme connect-all -t tcp -w 192.168.20.1 -a 192.168.20.20 nvme connect-all -t tcp -w 192.168.21.1 -a 192.168.21.20 nvme connect-all -t tcp -w 192.168.20.1 -a 192.168.20.21 nvme connect-all -t tcp -w 192.168.21.1 -a 192.168.21.21
Beginning with RHEL 9.4, the setting for the NVMe/TCP
Step 7: Validate NVMe-oF
Verify that the in-kernel NVMe multipath status, ANA status, and ONTAP namespaces are correct for the NVMe-oF configuration.
Verify that the in-kernel NVMe multipath is enabled:
cat /sys/module/nvme_core/parameters/multipath
Y
Verify that the appropriate NVMe-oF settings (such as, model set to NetApp ONTAP Controller and load balancing iopolicy set to round-robin) for the respective ONTAP namespaces correctly reflect on the host:
Display the subsystems:
cat /sys/class/nvme-subsystem/nvme-subsys*/model
NetApp ONTAP Controller NetApp ONTAP Controller
Display the policy:
cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicy
round-robin round-robin
Verify that the namespaces are created and correctly discovered on the host:
nvme list
Show example
Node SN Model --------------------------------------------------------- /dev/nvme4n1 81Ix2BVuekWcAAAAAAAB NetApp ONTAP Controller Namespace Usage Format FW Rev ----------------------------------------------------------- 1 21.47 GB / 21.47 GB 4 KiB + 0 B FFFFFFFF
Verify that the controller state of each path is live and has the correct ANA status:
NVMe/FCnvme list-subsys /dev/nvme5n1
Show example
nvme-subsys5 - NQN=nqn.1992-08.com.netapp:sn.f7565b15a66911ef9668d039ea951c46:subsystem.nvme1 hostnqn=nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0056-5410-8048-c7c04f425633 \ +- nvme126 fc traddr=nn-0x2036d039ea951c45:pn-0x2038d039ea951c45,host_traddr=nn-0x2000f4c7aa0cd7c3:pn-0x2100f4c7aa0cd7c3 live optimized +- nvme176 fc traddr=nn-0x2036d039ea951c45:pn-0x2037d039ea951c45,host_traddr=nn-0x2000f4c7aa0cd7c2:pn-0x2100f4c7aa0cd7c2 live optimized +- nvme5 fc traddr=nn-0x2036d039ea951c45:pn-0x2039d039ea951c45,host_traddr=nn-0x2000f4c7aa0cd7c2:pn-0x2100f4c7aa0cd7c2 live non-optimized +- nvme71 fc traddr=nn-0x2036d039ea951c45:pn-0x203ad039ea951c45,host_traddr=nn-0x2000f4c7aa0cd7c3:pn-0x2100f4c7aa0cd7c3 live non-optimized
NVMe/TCPnvme list-subsys /dev/nvme4n2
Show example
nvme-subsys4 - NQN=nqn.1992-08.com.netapp:sn.64e65e6caae711ef9668d039ea951c46:subsystem.nvme4 hostnqn=nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0035-5910-804b-c2c04f444d33 \ +- nvme102 tcp traddr=192.168.21.20,trsvcid=4420,host_traddr=192.168.21.1,src_addr=192.168.21.1 live non-optimized +- nvme151 tcp traddr=192.168.21.21,trsvcid=4420,host_traddr=192.168.21.1,src_addr=192.168.21.1 live optimized +- nvme4 tcp traddr=192.168.20.20,trsvcid=4420,host_traddr=192.168.20.1,src_addr=192.168.20.1 live non-optimized +- nvme53 tcp traddr=192.168.20.21,trsvcid=4420,host_traddr=192.168.20.1,src_addr=192.168.20.1 live optimized
Verify that the NetApp plug-in displays the correct values for each ONTAP namespace device:
Columnnvme netapp ontapdevices -o column
Show example
Device Vserver Namespace Path ----------------------- ------------------------------ /dev/nvme10n1 vs_tcp_rhel10 /vol/vol10/ns10 NSID UUID Size ----------------------- ------------------------------ 1 bbf51146-fc64-4197-b8cf-8a24f6f359b3 21.47GB
JSONnvme netapp ontapdevices -o json
Show example
{ "ONTAPdevices":[ { "Device":"/dev/nvme10n1", "Vserver":"vs_tcp_rhel10", "Namespace_Path":"/vol/vol10/ns10", "NSID":1, "UUID":"bbf51146-fc64-4197-b8cf-8a24f6f359b3", "Size":"21.47GB", "LBA_Data_Size":4096, "Namespace_Size":5242880 } ] }
Step 8: Set up secure in-band authentication
Beginning with ONTAP 9.12.1, secure in-band authentication is supported over NVMe/TCP between a RHEL 10 host and an ONTAP controller.
Each host or controller must be associated with a DH-HMAC-CHAP
key to set up secure authentication. A DH-HMAC-CHAP
key is a combination of the NQN of the NVMe host or controller and an authentication secret configured by the administrator. To authenticate its peer, an NVMe host or controller must recognize the key associated with the peer.
Set up secure in-band authentication using the CLI or a config JSON file. If you need to specify different dhchap keys for different subsystems, you must use a config JSON file.
Set up secure in-band authentication using the CLI.
Obtain the host NQN:
Generate the dhchap key for the RHEL 10 host.
The following output describes the
gen-dhchap-key
command paramters:nvme gen-dhchap-key -s optional_secret -l key_length {32|48|64} -m HMAC_function {0|1|2|3} -n host_nqn • -s secret key in hexadecimal characters to be used to initialize the host key • -l length of the resulting key in bytes • -m HMAC function to use for key transformation 0 = none, 1- SHA-256, 2 = SHA-384, 3=SHA-512 • -n host NQN to use for key transformation
In the following example, a random dhchap key with HMAC set to 3 (SHA-512) is generated.
nvme gen-dhchap-key -m 3 -n nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0035-5910-804b-c2c04f444d33 DHHC-1:03:7zf8I9gaRcDWH3tCH5vLGaoyjzPIvwNWusBfKdpJa+hia1aKDKJQ2o53pX3wYM9xdv5DtKNNhJInZ7X8wU2RQpQIngc=:
On the ONTAP controller, add the host and specify both dhchap keys:
vserver nvme subsystem host add -vserver <svm_name> -subsystem <subsystem> -host-nqn <host_nqn> -dhchap-host-secret <authentication_host_secret> -dhchap-controller-secret <authentication_controller_secret> -dhchap-hash-function {sha-256|sha-512} -dhchap-group {none|2048-bit|3072-bit|4096-bit|6144-bit|8192-bit}
A host supports two types of authentication methods, unidirectional and bidirectional. On the host, connect to the ONTAP controller and specify dhchap keys based on the chosen authentication method:
nvme connect -t tcp -w <host-traddr> -a <tr-addr> -n <host_nqn> -S <authentication_host_secret> -C <authentication_controller_secret>
Validate the
nvme connect authentication
command by verifying the host and controller dhchap keys:-
Verify the host dhchap keys:
cat /sys/class/nvme-subsystem/<nvme-subsysX>/nvme*/dhchap_secret
Show example output for a unidirectional configuration
cat /sys/class/nvme-subsystem/nvme-subsys1/nvme*/dhchap_secret DHHC- 1:03:fMCrJharXUOqRoIsOEaG6m2PH1yYvu5+z3jTmzEKUbcWu26I33b93b il2WR09XDho/ld3L45J+0FeCsStBEAfhYgkQU=: DHHC- 1:03:fMCrJharXUOqRoIsOEaG6m2PH1yYvu5+z3jTmzEKUbcWu26I33b93b il2WR09XDho/ld3L45J+0FeCsStBEAfhYgkQU=: DHHC- 1:03:fMCrJharXUOqRoIsOEaG6m2PH1yYvu5+z3jTmzEKUbcWu26I33b93b il2WR09XDho/ld3L45J+0FeCsStBEAfhYgkQU=: DHHC- 1:03:fMCrJharXUOqRoIsOEaG6m2PH1yYvu5+z3jTmzEKUbcWu26I33b93b il2WR09XDho/ld3L45J+0FeCsStBEAfhYgkQU=:
Verify the controller dhchap keys:
cat /sys/class/nvme-subsystem/<nvme-subsysX>/nvme*/dhchap_ctrl_secret
Show example output for a bidirectional configuration
cat /sys/class/nvme-subsystem/nvme-subsys6/nvme*/dhchap_ctrl_secret DHHC- 1:03:7zf8I9gaRcDWH3tCH5vLGaoyjzPIvwNWusBfKdpJa+hia 1aKDKJQ2o53pX3wYM9xdv5DtKNNhJInZ7X8wU2RQpQIngc=: DHHC- 1:03:7zf8I9gaRcDWH3tCH5vLGaoyjzPIvwNWusBfKdpJa+hia 1aKDKJQ2o53pX3wYM9xdv5DtKNNhJInZ7X8wU2RQpQIngc=: DHHC- 1:03:7zf8I9gaRcDWH3tCH5vLGaoyjzPIvwNWusBfKdpJa+hia 1aKDKJQ2o53pX3wYM9xdv5DtKNNhJInZ7X8wU2RQpQIngc=: DHHC- 1:03:7zf8I9gaRcDWH3tCH5vLGaoyjzPIvwNWusBfKdpJa+hia 1aKDKJQ2o53pX3wYM9xdv5DtKNNhJInZ7X8wU2RQpQIngc=:
When multiple NVMe subsystems are available on the ONTAP controller configuration, you can use the /etc/nvme/config.json
file with the nvme connect-all
command.
Use the -o
option to generate the JSON file. See the NVMe connect-all manual pages for more syntax options.
Configure the JSON file.
In the following example, dhchap_key
corresponds todhchap_secret
anddhchap_ctrl_key
corresponds todhchap_ctrl_secret
.Show example
cat /etc/nvme/config.json [ { "hostnqn":"nqn.2014-08.org.nvmexpress:uuid:4c4c4544-0035-5910-804b-c2c04f444d33", "hostid":"4c4c4544-0035-5910-804b-c2c04f444d33", "dhchap_key":"DHHC-1:03:7zf8I9gaRcDWH3tCH5vLGaoyjzPIvwNWusBfKdpJa+hia1aKDKJQ2o53pX3wYM9xdv5DtKNNhJInZ7X8wU2RQpQIngc=:", "subsystems":[ { "nqn":"nqn.1992-08.com.netapp:sn.127ade26168811f0a50ed039eab69ad3:subsystem.inband_unidirectional", "ports":[ { "transport":"tcp", "traddr":"192.168.20.17", "host_traddr":"192.168.20.1", "trsvcid":"4420" }, { "transport":"tcp", "traddr":"192.168.20.18", "host_traddr":"192.168.20.1", "trsvcid":"4420" }, { "transport":"tcp", "traddr":"192.168.21.18", "host_traddr":"192.168.21.1", "trsvcid":"4420" }, { "transport":"tcp", "traddr":"192.168.21.17", "host_traddr":"192.168.21.1", "trsvcid":"4420" }]
Connect to the ONTAP controller using the config JSON file:
nvme connect-all -J /etc/nvme/config.json
Show example
traddr=192.168.20.20 is already connected traddr=192.168.20.20 is already connected traddr=192.168.20.20 is already connected traddr=192.168.20.20 is already connected traddr=192.168.20.20 is already connected traddr=192.168.20.20 is already connected traddr=192.168.20.20 is already connected traddr=192.168.20.20 is already connected traddr=192.168.20.21 is already connected traddr=192.168.20.21 is already connected traddr=192.168.20.21 is already connected traddr=192.168.20.21 is already connected traddr=192.168.20.21 is already connected traddr=192.168.20.21 is already connected traddr=192.168.20.21 is already connected traddr=192.168.20.21 is already connected
Verify that the dhchap secrets have been enabled for the respective controllers for each subsystem.
cat /sys/class/nvme-subsystem/nvme-subsys0/nvme0/dhchap_secret
The following example shows a dhchap key:
DHHC-1:03:7zf8I9gaRcDWH3tCH5vLGaoyjzPIvwNWusBfKdpJa+hia1 aKDKJQ2o53pX3wYM9xdv5DtKNNhJInZ7X8wU2RQpQIngc=:
cat /sys/class/nvme-subsystem/nvme-subsys0/nvme0/dhchap_ctrl_secret
DHHC-1:03:fMCrJharXUOqRoIsOEaG6m2PH1yYvu5+z3jT mzEKUbcWu26I33b93bil2WR09XDho/ld3L45J+0FeCsStBEAfhYgkQU=:
Step 9: Review the known issues
There are no known issues.
