ONTAP SAN Host Utilities
NVMe/FC host configuration for RHEL 8.1 with ONTAP
Contributors netapp-ranuk netapp-aherbin netapp-sarajane netapp-pcarriga netapp-aoife ciarm
Beginning with ONTAP 9.6, NVMe/FC is supported for Red Hat Enterprise Linux (RHEL) 8.1. A RHEL 8.1 host can run both NVMe and SCSI traffic through the same FC initiator adapter ports. See the Hardware Universe for a list of supported FC adapters and controllers.
See the Interoperability Matrix Tool for the current list of supported configurations.
Known limitations
  • Native NVMe/FC auto-connect scripts are not available in the nvme-cli package. You can use the host bus adapter (HBA) vendor-provided external auto-connect script.
  • NVMe multipath is disabled by default. Therefore, you need to enable it manually.
  • By default, round-robin load balancing is not enabled. You can enable this functionality by writing a udev rule.
  • SAN booting using the NVMe-oF protocol is currently not supported.
Enable SAN booting
You can configure your host to use SAN booting to simplify deployment and improve scalability.
Before you begin
Use the Interoperability Matrix Tool to verify that your Linux OS, host bus adapter (HBA), HBA firmware, HBA boot BIOS, and ONTAP version support SAN booting.
Steps
  1. Create a SAN boot namespace and map it to the host.
  2. Enable SAN booting in the server BIOS for the ports to which the SAN boot LUN is mapped.
    For information on how to enable the HBA BIOS, see your vendor-specific documentation.
  3. Verify that the configuration was successful by rebooting the host and verifying that the OS is up and running.
Enable NVMe/FC
You can use the following procedure to enable NVMe/FC.
Steps
  1. Install Red Hat Enterprise Linux 8.1 on the server.
  2. After the installation is complete, verify that you are running the specified RHEL kernel:
    # uname -r
    4.18.0-147.el8.x86_64
    See the Interoperability Matrix Tool for the current list of supported versions.
  3. Install the nvme-cli-1.8.1-3.el8 package:
    # rpm -qa|grep nvme-cli
    nvme-cli-1.8.1-3.el8.x86_64
  4. Enable in-kernel NVMe multipath:
    # grubby –args=nvme_core.multipath=Y –update-kernel /boot/vmlinuz-4.18.0-147.el8.x86_64
  5. Add the following string as a separate udev rule at /lib/udev/rules.d/71-nvme-iopolicy-netapp-ONTAP.rules. This enables round-robin load balancing for NVMe multipath:
    # Enable round-robin for NetApp ONTAP
    ACTION==”add”, SUBSYSTEM==”nvme-subsystem”, ATTR{model}==”NetApp ONTAP Controller”, ATTR{iopolicy}=”round-robin
  6. On the RHEL 8.1 host, check the host NQN string at /etc/nvme/hostnqn and verify that it matches the host NQN string for the corresponding subsystem on the ONTAP array:
    # cat /etc/nvme/hostnqn
    nqn.2014-08.org.nvmexpress:uuid:75953f3b-77fe-4e03-bf3c-09d5a156fbcd
    *> vserver nvme subsystem host show -vserver vs_nvme_10
    Vserver Subsystem Host NQN
    rhel_141_nvme_ss_10_0
    Note If the host NQN strings do not match, use the vserver modify command to update the host NQN string on your corresponding ONTAP array subsystem to match with the host NQN string from /etc/nvme/hostnqn on the host.
  7. Reboot the host.
Configure the Broadcom FC adapter for NVMe/FC
You can use the following procedure to configure a Broadcom FC adapter.
Steps
  1. Verify that you are using the supported adapter. See the Interoperability Matrix Tool for the current list of supported adapters.
    # cat /sys/class/scsi_host/host*/modelname
    LPe32002-M2
    LPe32002-M2
    # cat /sys/class/scsi_host/host*/modeldesc
    Emulex LightPulse LPe32002-M2 2-Port 32Gb Fibre Channel Adapter
  2. Copy and install the Broadcom lpfc outbox driver and auto-connect scripts:
    # tar -xvzf elx-lpfc-dd-rhel8-12.4.243.20-ds-1.tar.gz
    # cd elx-lpfc-dd-rhel8-12.4.2453.20-ds-1
    # ./elx_lpfc_install-sh -i -n
    Note The native drivers that are bundled with the OS are called the inbox drivers. If you download the outbox drivers (drivers that are not included with an OS release), an auto-connect script is included in the download and should be installed as part of the driver installation process.
  3. Reboot the host.
  4. Verify that you are using the recommended Broadcom lpfc firmware, outbox driver, and auto-connect package versions:
    # cat /sys/class/scsi_host/host*/fwrev
    12.4.243.20, sil-4.2.c
    # cat /sys/module/lpfc/version
    0:12.4.243.20
    # rpm -qa | grep nvmefc
    nvmefc-connect-12.6.61.0-1.noarch
  5. Verify that lpfc_enable_fc4_type is set to 3:
    # cat /sys/module/lpfc/parameters/lpfc_enable_fc4_type
    3
  6. Verify that the initiator ports are up and running:
    # cat /sys/class/fc_host/host*/port_name
    0x10000090fae0ec61
    0x10000090fae0ec62
    # cat /sys/class/fc_host/host*/port_state
    Online
    Online
  7. Verify that the NVMe/FC initiator ports are enabled, running, and you can see the target LIFs:
    # cat /sys/class/scsi_host/host*/nvme_info
    NVME Initiator Enabled
    XRI Dist lpfc0 Total 6144 NVME 2947 SCSI 2977 ELS 250
    NVME LPORT lpfc0 WWPN x10000090fae0ec61 WWNN x20000090fae0ec61 DID x012000 ONLINE
    NVME RPORT WWPN x202d00a098c80f09 WWNN x202c00a098c80f09 DID x010201 TARGET DISCSRVC ONLINE
    NVME RPORT WWPN x203100a098c80f09 WWNN x202c00a098c80f09 DID x010601 TARGET DISCSRVC ONLINE
    NVME Statistics
Enable 1MB I/O Size for Broadcom NVMe/FC
ONTAP reports an MDTS (Max Data Transfer Size) of 8 in the Identify Controller data. This means the maximum I/O request size can be up to 1MB. To issue I/O requests of size 1MB for a Broadcom NVMe/FC host, you should increase the lpfc value of the lpfc_sg_seg_cnt parameter to 256 from the default value of 64.
Note These steps don't apply to Qlogic NVMe/FC hosts.
Steps
  1. Set the lpfc_sg_seg_cnt parameter to 256:
    cat /etc/modprobe.d/lpfc.conf
    You should see an output similar to the following example:
    options lpfc lpfc_sg_seg_cnt=256
  2. Run the dracut -f command, and reboot the host.
  3. Verify that the value for lpfc_sg_seg_cnt is 256:
    cat /sys/module/lpfc/parameters/lpfc_sg_seg_cnt
Validate NVMe/FC
You can use the following procedure to validate NVMe/FC.
Steps
  1. Verify the following NVMe/FC settings.
    # cat /sys/module/nvme_core/parameters/multipath
    Y
    # cat /sys/class/nvme-subsystem/nvme-subsys*/model
    # cat /sys/class/nvme-subsystem/nvme-subsys*/iopolicy
    round-robin
    round-robin
  2. Verify that the namespaces are created.
    # nvme list
    Node SN Model Namespace Usage Format FW Rev
    /dev/nvme0n1 80BADBKnB/JvAAAAAAAC NetApp ONTAP Controller 1 53.69 GB / 53.69 GB 4 KiB + 0 B FFFFFFFF
  3. Verify the status of the ANA paths.
    # nvme list-subsys/dev/nvme0n1
    Nvme-subsysf0 – NQN=nqn.1992-08.com.netapp:sn.341541339b9511e8a9b500a098c80f09:subsystem.rhel_141_nvme_ss_10_0
    +- nvme0 fc traddr=nn-0x202c00a098c80f09:pn-0x202d00a098c80f09 host_traddr=nn-0x20000090fae0ec61:pn-0x10000090fae0ec61 live optimized
    +- nvme1 fc traddr=nn-0x207300a098dfdd91:pn-0x207600a098dfdd91 host_traddr=nn-0x200000109b1c1204:pn-0x100000109b1c1204 live inaccessible
    +- nvme2 fc traddr=nn-0x207300a098dfdd91:pn-0x207500a098dfdd91 host_traddr=nn-0x200000109b1c1205:pn-0x100000109b1c1205 live optimized
    +- nvme3 fc traddr=nn-0x207300a098dfdd91:pn-0x207700a098dfdd91 host traddr=nn-0x200000109b1c1205:pn-0x100000109b1c1205 live inaccessible
  4. Verify the NetApp plug-in for ONTAP devices.
    # nvme netapp ontapdevices -o column
    Device   Vserver  Namespace Path             NSID   UUID   Size
    /dev/nvme0n1   vs_nvme_10       /vol/rhel_141_vol_10_0/rhel_141_ns_10_0    1        55baf453-f629-4a18-9364-b6aee3f50dad   53.69GB
    # nvme netapp ontapdevices -o json
       "ONTAPdevices" : [
            Device" : "/dev/nvme0n1",
            "Vserver" : "vs_nvme_10",
            "Namespace_Path" : "/vol/rhel_141_vol_10_0/rhel_141_ns_10_0",
             "NSID" : 1,
             "UUID" : "55baf453-f629-4a18-9364-b6aee3f50dad",
             "Size" : "53.69GB",
             "LBA_Data_Size" : 4096,
             "Namespace_Size" : 13107200
